355 SBC - HSR setup - Will Seperate
Old Oct 21, 2006 | 11:35 PM
klumb15's Avatar
up for sale is my built 355, only has about 100 miles on the rebuild, if that...minimal runtime
Motor consists of:
1989 Corvette 350 2 Bolt Block - bored .030 over making it a 355
Corvette 113 Aluminum Heads - Ported
New Pistons/Rings and rods
Crank Turned .010"
New Crank/Cam Bearings
High Volume Oil Pump
High Flow Water Pump
Comp Cam 276HR - 224/230 Duration at .050"...503/.510 Lift
Heads:
New Manley High Lift Valves - Single grove on top of the valve allows for more lift
Comp Cams 1.450 Daul Springs - bored spring pockets
Shaved To Approx. 9.8 to 1 Compression
Port Job
Crane Energizer Roller Tipped Rockers 1.6 Ratio..Making Lift .536/.543 approximately
its a very stout motor yet streetable, my engine builder said its capable of 400 horse all though it was never dynoed, definately will get a car into 12's with the right suspension mods. Comes with all the accesories if you want them. Power steering, waterpump, altenator, starter.
asking $2000 for the long block with all the accessories
Intake:
Holley Stealth Ram (deribbed and polished)
Holley Fuel Rails W/Adjustable Regulator
Accel 26# Injectors
TPIS Twin 58MM Throttle Body
Stainless Steel Braided lines and adapters for stock fuel lines
Comes with distributor and accel coil
asking SOLD for the intake
Pictures:
Intake when it was Brand new http://memimage.cardomain.net/member...42_40_full.jpg
Heads http://memimage.cardomain.net/member...42_37_full.jpg
http://memimage.cardomain.net/member...42_38_full.jpg
Shortblock http://memimage.cardomain.net/member...42_42_full.jpg
http://memimage.cardomain.net/member...42_43_full.jpg
http://memimage.cardomain.net/member...42_44_full.jpg
http://memimage.cardomain.net/member...42_45_full.jpg
http://memimage.cardomain.net/member...42_46_full.jpg
Motor in the car http://memimage.cardomain.net/member...42_51_full.jpg
http://memimage.cardomain.net/member...42_52_full.jpg
thats all the pics I have as of right now, I can get up to date pics if you please, but it looks just like the last few pics I posted, just outside of the car.
Old Oct 22, 2006 | 06:14 AM
88BlackZ-51's Avatar
will u seperate the TB? if so how much?
Old Oct 22, 2006 | 10:31 AM
klumb15's Avatar
i'm not going to seperate that much as of right now. I'm just seperating the motor into 2 right now, induction system and long block.
I might decide to part out the intake further down the road, but not right now, sorry...
Old Oct 22, 2006 | 06:13 PM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
well if you are willing to separate, ill take the fuel lines and such lemme know if you decide to, thanks
Old Oct 22, 2006 | 10:53 PM
klumb15's Avatar
my mistake guys...i know 'will seperate' is vague, but what i meant is i will seperate the intake from the long block
i don't want to seperate it anymore than that right now...sorry
so if you want parts off the intake, you have to buy the complete induction setup..
just to clearify things up there
Old Oct 23, 2006 | 10:43 AM
Car: 91 z28
ok ill trade you my intake, tb and fuel rails + cash for your set up lol,
Old Oct 23, 2006 | 10:46 AM
klumb15's Avatar
lol, i'm getting out of project cars...I have enough parts to get rid of right now, I don't need anymore....haha
Old Oct 23, 2006 | 01:31 PM
Maroon89gta's Avatar
Car: 89 Trans Am GTA, 01 Ram, 01 Harley
Transmission: Worldclass T-5
How Much for the Holley Stealth Ram and Fuel rail setup?
Old Oct 23, 2006 | 03:32 PM
klumb15's Avatar
so everything minus the distributor, coil, and throttle body?
I'll do $750 with the lines and everything
Old Oct 26, 2006 | 03:41 PM
toogood002's Avatar
will the holly intake bolt right on to stock l98 heads or do they need modifiying
Old Oct 26, 2006 | 03:44 PM
klumb15's Avatar
yes it will, its a direct replacement. I have all the vacuum taps in it....if you have vortec heads, you'll obviously need the vortec stealth ram..but yes, this intake is made for the L98 heads...i have aluminum L98 heads..so its a direct bolt on, plug and play..
Old Nov 4, 2006 | 03:59 PM
klumb15's Avatar
to the top, I am negotiable on the prices guys...
Old Nov 7, 2006 | 10:53 AM
klumb15's Avatar
$2250 for the longblock with all the front mounted accessories
$750 for the intake (I can't go any lower on the complete induction, your getting alot for $750, its over 50% off retail)
anytakers?
Old Nov 12, 2006 | 05:35 PM
klumb15's Avatar
the intake sounds like its sold. But heres a bump for everything else.
Old Nov 21, 2006 | 02:15 PM
klumb15's Avatar
recieved the payment for the intake today. I still have the long block left, the distributor, an accel coil, and the accel 26# injectors...so that is still up for sale
Old Nov 22, 2006 | 10:01 AM
kammi10's Avatar
Car: 1989 camaro
damn it i wanted the stealth ram
Old Dec 2, 2006 | 05:16 AM
svgould's Avatar
What type of distributor is it? How much shipped to 83642?
Old Dec 2, 2006 | 10:55 AM
klumb15's Avatar
its just a stock style distributor, but its the small cap style, made for the remote mounted coil. I'll do $40 shipped for it, but I have to contact the person who bought the intake to make sure he doesn't need it..let me know if you want it
Old Dec 2, 2006 | 04:44 PM
svgould's Avatar
I'm going to pass for now. Thanks shane
Old Dec 10, 2006 | 06:38 PM
klumb15's Avatar
longblock down to $2000 with all the front mounted accessories..
Old Dec 12, 2006 | 11:12 PM
rmartin4677's Avatar
Car: 91 rs-02 blazer old john deer
Engine: 305-4.3
you still have the dist. will it work on 305
Old Dec 13, 2006 | 10:07 AM
klumb15's Avatar
yes I still have it. It should work fine with a 305.
Old Dec 13, 2006 | 03:35 PM
klumb15's Avatar
I know it is getting close to christmas and everybody has presents to buy. But I need to get rid of that motor soon. So the price is $2000 O.B.O. I will entertain any reasonable offers. No low balling though...Thanks guys
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
