tpi parts for sale
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
tpi parts for sale
Hello all,
<O>
</O>
Listed is all the parts from my 87 camaro. I just built this car last year. It snapped a rod about 500 miles after being built. So now I’m here selling all the parts from the engine. My plans are to go with a 5.3L lq4 and 4L60e trans.
<O>
</O>
Complete tpi setup - $400
Pistons and rods(need 1 piston and 2 rods to complete) - SOLD
Serpentine setup - SOLD!
Mini-High Torque Starter - $75
TPI base for vortec heads - $400
Stock centerbolt valve covers with chrome breather - SOLD!
TPI air ducts with K&N filters - $80
Stock crank(needs to be turned) - $65
New lower radiator hose - $5
Comp Cam 260H, lifters, pushrods, roller tip 1.5 rockers timing chain - $200
Melling High volume oil pump and HV/HP shaft - SOLD!
One piece rear main adaptor plate - $30
Timing Chain cover with bolts - $5
Oilpan stiffener bars and bolts - $5
MAF sensor( new unit not rebuilt) - $125
350 block bored 0.030 over - $250
Set of 3 aluminum Crank pulley spacers - $25
Accel Performance Coil Cap and rotor - $100
Flexplate for one piece block and arp bolts - SOLD!
Flowtech shorties with a custom 3" y-pipe - HEADERS SOLD! CUSTOM 3" Y-PIPE - $75
Vortec Heads(some polishing done) - SOLD!
700r4 Transmission(200 miles on rebuild, comes with stock converter) - $600
<O>
</O>
These parts only have 500 miles on them. I decided not to go back with tpi and chose the ls route. I need to get rid of these parts for my ls build. Feel free to make me a reasonable offer. I won’t ignore any REASONABLE offers. PM is best to contact me.
I will accept paypal.
Thanks,
Eric
<O>
</O>
<O>
</O>
<O>
</O>
Thanks,
Eric
Engine: 5.3L
Axle/Gears: 3.42LSD
Re: tpi parts for sale
Come on guys i know there is some people who want to convert to tpi from carb or build a tpi. When I had this engine assembled it pulled 350HP and 450 lb/ft of Torque! Most of these parts will fit carbed motor too!
Car: 91 Trans Am, 88 GTA, 90 Formula 350
Engine: 305TPI, 350TPI, 350TPI
Transmission: 700R-4
Axle/Gears: 3.27, 3.27, 3.23
Can you post the part number of the oil pump and shaft?
Engine: 5.3L
Axle/Gears: 3.42LSD
Engine: 5.3L
Axle/Gears: 3.42LSD
flat tappet. comes with lifters rockers pushrods and timing chain. All with less than 500 miles on it!
Engine: 5.3L
Axle/Gears: 3.42LSD
Both brackets, bolts, air compressor, brand new alt, new water pump, p/s pump, belt, tensioner, all pulleys. Basically everything but smog pump. parts have less than 500 miles on them. brackets were bead blasted before I installed them.
Engine: 5.3L
Axle/Gears: 3.42LSD
Come on guys! got a lot of great parts here. Trying to give everyone here a shot at them before they hit ebay.
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
what all parts off the TPI setup will work on a speed density setup for a 91 camaro?
Engine: 5.3L
Axle/Gears: 3.42LSD
Everything. harness and ecm can be modified to run speed density. there's a thread on this site telling how to modify the maf setup to speed density. I don't remember the link but you can do a search and find it rather easy. If you are wanting to convert your tbi to tpi tho. you can use the maf setup without having to modify anything. The setup I have comes with everything you need except the maf sensor and intake duct, but i have those for sale too. If you want I can do a package deal on all of this. Let me know.
Thanks,
Eric
P.S. I'll even include the book I created with details of how to do the swap. I created the book with information I got from this site. Tons of wiring info( diagrams and tables).
Thanks,
Eric
Car: 95 C1500 Ext. cab
Engine: 355 TPI running on the TBI ecm
Axle/Gears: 3.73 GM 10-bolt
would you part out the injectors?
what size are they looking for 22's?
Engine: 5.3L
Axle/Gears: 3.42LSD
don't want to part out the tpi. i would like to sell it as a complete setup.
400 with the the maf
And does the compu com with it
By complete do you mean all hoses and vac lines ?
acer1@videotron.ca
acer1@videotron.ca
Engine: 5.3L
Axle/Gears: 3.42LSD
Tpi setup is complete. comes with everything from intake base to tb, computer, and harness. I do have a maf that I bought new had it on the car for less than 500 miles. I will throw it in for an additional $50 if bought together. also if you have a camaro I have the intake duct that hold the two filters with two new K&N filters installed. I will add it for another $50 and throw in the rubber connectors I used to connect it all to the tb. So it would be $500 for everything plus shipping.
