New stuff mostly
Old Jun 17, 2007 | 05:36 PM
cocacolakidd's Avatar
Car: 84Z & Porsche
Engine: 427sbc - 471 - 850 Demon Claw
Transmission: Bowtie stage II TH700R4 - 10" 3000
Axle/Gears: 9 Bolt w/ 3:45's
New stuff mostly
1.) Hawk’s 5” rear spoiler for third gen. New in box never modified or mounted. Original price was around $300.00. On sale here at $150.00 + Shipping. _ SOLD _
2.)28mm Rear Sway Bar for third gen - That’s right 28mm, very rare - Also adjustable for street or racing. Used but excellent shape - $50.00 + shipping
3.) AJE Dropped Spindles - 1.8” drop, standard OEM steering and 1LE or standard brakes (May be modified for the larger brake package by drilling the holes larger and adding backing nuts). These are new units never mounted. These are also the later model with all of the bugs worked out. Cost $345.00 new - on sale $135.00 +shipping.
_ SOLD _
4.) Complete Street/Race Motor - 405ci Small block (400 block at .020 over) - 511 cast 400 block , 4 bolt mains - ARP Main Studs - forged Eagle 4130 crank 3.75 stroke - Forged Eagle 4130 6“ “I” beam cap screw floated rods - Melling 155HVhigh volume high pressure oil pump - Oil passages on block drilled and honed and blue printed all angles radius - Kevko 6qt Oil pan for road race, full baffled and screened with scrapers and bung for oil temp sender - Cloyes true roller timing chain - Comp Cam XR288HR10 Hydraulic Roller - Comp Cam Hydraulic Roller Lifters - Matching Comp Cam spring kit - Aluminum Timing cover, polished - High rise oil drain back inserts - Aluminum Polished hi flo Dart water pump - AFR Aluminum heads 64cc chambers 2.05 & 1.65 S.S. Valves, exhaust valves sodium filled, heads full ported and polished exhaust runners, and chamber equalized - Comp Cam roller rockers, self aligning - Edelbrock 2975 Victor Jr. manifold - Barry Grant Street Demon 850 Carb - MSD SLP 1 ¾” x 3” S.S. Headers, no air tubes (Headers only Used part here). MSD HEI Distributor blue printed and curved 50K coil with internal computer and internal rev limiter - Many many extras on this motor not listed - New motor never installed, no expense spared, completely balanced and blue printed every detail covered , all fasteners ARP - Over $12,000.00 invested, sale at $5500.00+ shipping (Prefer pick up).
5.) BBK Adjusable Caster/Camber Plates #2527 new - Powder coated Red/Black - cost $210.00 - sale $100.00+ship
_ SOLD _
6.) GM Performance parts Windage Tray - GM p/n 3927136 - new never used - can be modified to fit 400ci blocks by elongating stud holes - $15.00
7.) TA Performance 9 Bolt Cover/Girdle with Stud kit - new never used - paid $155.00 and $25.00 for studs- sale $100.00 +shipping - SOLD - SOLD -
8.) Does your rear window defrost? Maybe some of the wires back there need help. Especially the braided ones? Complete set of used rear deck window defrost wiring loom complete in absolutely great condition - $25.00 + shipping
9.) Complete front steering rebuild parts - Tie rod ends (4 Moog) - Idler arm - Center link - Ball Joints - Heavy duty tie rod link/adjusters aluminum - S/T (Spring Tech) Heavy Duty Gas Racing type Front Struts and Rear Shocks- Polyurethane bump stops - Complete Energy Suspension Polyurethane Package Components on all - Paid over $750.00 for parts, now on sale $150.00+ Ship. All parts new never used, most not even out of box.
_ SOLD _
10.) Edelbrock Jr. 2975 Air Gap single plane Manifold - used very little - sat in garage for the last year - never ground on or even gasket matched - all standard - all threads excelent - excellent condition overall - $100.00+ship
11.) Complete in Dash Air Vent System for AC Delete (Out of B4C State trooper car, actually from state garage/motor pool). Even has pull ***** for outside air vents - all plastic parts like new (May be new -not verified?) no flex duct with (Easy to get generic flex ducting at auto parts store). $35.00+ship
12.) Panhard Bar - new - Ploy inserts greaseable - adjustable bar length - Black powder coat - $75.00+ship
13.) Corvette GM mini 3hp starter $75.00+ship
14.) 400CI SBC Splayed Main Caps - 1050 Steel - with 200,000psi 12 pt. Splay Bolts $35.00+ship
15.) 400CI SBC bare block - 511 2 bolt truck replacement block - $125.00 buyer must inspect before pickup, needs .020 over bore + other work. No cracks. These replacement blocks are very rare - higher silicon content, larger oil passages, and better cooling passages than standard or 4bolt blocks - can be honed for 4 bolt caps (Above).
16.) 140MPH Speedo + 8K Tack for Bird - great condition looks new - $40.00 + ship
17.) 88 Camaro IROC (Fits firebirds also) Quick Ratio Steering Box - in good shape no leaks, and tight - 2 1/3 turns stop to stop - marked with the infamous “Z“ - $70.00 + shipping.
Pay Pal preferred -
Girlfriend wrecked the 88IROC, not continuing with project.
Contact:
Ed Young (AKA: Cocacolakidd)
Rogue Valley, Oregon
nushi@charter.net
541-776-9919
Old Jun 17, 2007 | 07:30 PM
luke4907's Avatar
Car: '89 Trans Am GTA
Engine: TPI350
Axle/Gears: BW 3.27s
Re: New stuff mostly
you have a PM
Old Jun 17, 2007 | 07:51 PM
CRFred's Avatar
Car: 84 Z28
Engine: 383
Transmission: LT1 6 speed
Axle/Gears: 4:11
PM sent
Old Jun 17, 2007 | 08:41 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
I wanted to see if some parts were still available.
can you send pics and give me dibs on this stuff if not called for already,
Old Jun 17, 2007 | 08:50 PM
Xilr8n 91 Z28's Avatar
Car: 1991 Camaro Z28, Bright Red on Flam
Engine: L98 350
Transmission: t-56
If the AJE dropped spindles are still available, or if the sale falls through, I have cash in hand. Let me know. Could you send pics too, c.zella@umiami.edu
Old Jun 17, 2007 | 10:10 PM
luke4907's Avatar
Engine: TPI350
fyi I've called the dropped spindles in the PM I sent him, but also was asking more info on the swaybar, rear hatch wiring or whatever, and the starter so I can get whatever I need in 1 payment.
Old Jun 17, 2007 | 11:05 PM
Car: 84Z & Porsche
I have listed John as first dibbs on 3., 5., 9., & 11
I have luke as second on part 3. first on part 2. first on part .8 & second on part 11.
I have Xilr8n 91 Z28 as third on part 3.
I will now try to get pics. of parts sent to those who asked for them. If you know what a new part looks like then that's exactly what a picture will look like.
It's a sad day when the 88 IROC was crunched. Stupi9d Blo9nd was attacked by a itsy bitsy bee and she wraped it into a concrete bridge side.
Old Jun 17, 2007 | 11:38 PM
soultron's Avatar
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
Wow, I'm just too slow, but could I get second dibs on #5 please?
Thanks!
And #2.
edit - - -
The 2527 BBKs are listed as Mustang parts, did I miss something?
Old Jun 18, 2007 | 12:36 AM
luke4907's Avatar
Engine: TPI350
is John = jstoltz? unless he sent you a PM before I did at 8:30p, I should be first in line on those spindles. I don't mean to start a pi$$ing match, but I hope you see my point. His post here was at 9:41p. If we're talking about someone else or he did PM you before I did, then forgive me and ignore this post. Thanks
Old Jun 18, 2007 | 01:19 AM
Car: 84Z & Porsche
John sent me an email to my email address at 6:40 pm. That was my first contact. Then you Luke at 8:30 pm. then others shortly after. I have had four messages from John - email, pm's and on the listing at different times.
I hope all is well,
Ed.
Old Jun 18, 2007 | 02:52 AM
luke4907's Avatar
Engine: TPI350
cool
Old Jun 18, 2007 | 09:51 AM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
I'm interested in the spindles as well..
Old Jun 18, 2007 | 03:37 PM
Car: 84Z & Porsche
Hello All,
John has spoken for Items 3.) Dropped Spindles. 5.) BBK Caster Camber Plates. 9.) Complete front rebuild parts.
Luke send me your shipping info and I can work up a shipping and total for you. For #'s 2.) 28 mm rear Sway Bar 8.) Rear window defrost wire loom. 11.) AC Delete Dash air vents 13.) Corvette Starter
Will has asked for # 6.) - Still need shipping info from Australia - Thanks
It's amazing that no one has snapped up the TA 9 bolt rear cover/girdle - Oh well./
Thanks all...
Ed.
Old Jun 18, 2007 | 04:11 PM
luke4907's Avatar
Engine: TPI350
FYI I wasn't interested in the A/C delete dash air vents. I'll get back to you about the window defrost thing. My car is at a friend's house. Any pics of the starter and sway bar? Thanks
Old Jun 18, 2007 | 04:47 PM
Brisk's Avatar
cocacolakidd, are AJE drop spindles still avaliable new from a retailer?
Old Jun 18, 2007 | 07:14 PM
Car: 84Z & Porsche
Brisk you can contact AJE Engineering for a new set of the spindles - they are now the only ones known to make the droped spindles for Third Gens. Belltech quit making them about 5 years ago.
Luck to all,
Ed.
Old Jun 18, 2007 | 07:31 PM
Car: 84Z & Porsche
Hello all,
Luke send me or PM me your email address so I can attach pics.
Thanks.
Old Jun 19, 2007 | 08:39 AM
emac2001's Avatar
Car: 86 z28
is the front end kit #9 still available, if so its mine
Old Jun 19, 2007 | 09:05 AM
paulbuiltbird's Avatar
Car: 1989 Formula 350
Engine: 350 fuel injected
Axle/Gears: 9 bolt w/370 gears
I'm interested in the Diff cover & studs (item#7),still for sale? if so can you give a price shipped to 60173.
Old Jun 19, 2007 | 09:27 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
If the deals on the camber plates or front end parts fall through, I would like an opportunity to purchase. Thanks
Old Jun 19, 2007 | 10:38 AM
lthrneck's Avatar
Car: 89 Iroc
Axle/Gears: 3.70 9bolt
I'll take the rear Diff cover and stud kit if it isn't alreayd spoken for. How much shipped to 29906. An if it has fallen through I'll take the panhard if ain't spoke for. (Wife gave me an allowance haha)
Semper Fi
lthrneck
Old Jun 21, 2007 | 04:35 PM
Car: 84Z & Porsche
Bumpity - Bump - Bump -
Old Jun 21, 2007 | 07:49 PM
jstoltz's Avatar
mine will be paid for in the morning.
Old Jun 22, 2007 | 07:16 AM
1987earthquake's Avatar
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
I sent a pm. I never got a reply. I was asking if the front end kit was still available.
Old Jun 22, 2007 | 11:49 AM
Car: 84Z & Porsche
Bump - Bump - Bump
Some parts are sold and are marked as such. Still many great items left.
Forgot one -
18.) S&W Strut Tower Brace - Triangled - To fit Carb. - Black Powder Coat
New not out of box - $179.95 new now $75.00 + Ship
Come get all else while they last - May go to eBay next
Thanks every one,
Ed.
Old Jun 22, 2007 | 05:05 PM
Legal Disaster's Avatar
Car: 1986 Iroc-Z
Hey Ed can you either send me some pics via PM or email at iroc-u@hotmail.com ? I tried to pm you but for some reason the message bar doesn't appear. I did a search but was unable to find a pic. Shoot me an email or pm and maybe I'll take that off your hands also.
I am talking about the STB by the way. Thanks man
Old Jun 23, 2007 | 02:05 AM
97ramsst's Avatar
Car: 2008 F350 SuperDuty & few F-Bodies
Engine: Twin Turbo 6.4L Power Stroke
Transmission: Yeah, it has one.
Axle/Gears: Yeah, some of those too.
Bump - Bump - Bump
Forgot one -
Thanks every one,
Ed.
I will take the STB .... please give me a total shipped to 31763.
Old Jun 23, 2007 | 12:27 PM
mightymouse383's Avatar
Car: 91 camaro
Engine: 383
Transmission: th350
Axle/Gears: 4:10
still have the vic jr intake?
Old Jun 25, 2007 | 03:38 PM
CRFred's Avatar
Car: 84 Z28
Engine: 383
Axle/Gears: 4:11
Ok, I have sent Paypal, two PM's and an email to Cocacolakidd and have yet to hear back in 4 days after having normal, timely exchanges. Anyone know if he is ok?
Fred
Old Jun 25, 2007 | 04:11 PM
I bought something from him in the past and off of this thread and have had no problems. The parts came on time & nicely packaged. He probably has a lot of PM's coming at him right now because of having a big for sale list.
Old Jun 25, 2007 | 06:52 PM
jstoltz's Avatar
he is probably busy I got an e-mail from yesterday. All mine is sent out already.
Old Jul 2, 2007 | 01:32 PM
luke4907's Avatar
Engine: TPI350
I just wanted to make sure the dropped spindles sold and are not available anymore... thanks
Old Jul 4, 2007 | 01:22 AM
jstoltz's Avatar
yeah they are sitting here waiting to be installed, thanks for the deal ed
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
anesthes
Sep 30, 2015 07:48 AM
