world class t-5 swap, posi unti pics inside
Car: 88 IROC-Z twin turbo
Engine: forged 383 8-1 compression
Transmission: t56
Axle/Gears: 9in 3.50's trac loc moser axles
Car: 1988 Camaro
Engine: 2.8L, soon to be 350/300HP
Re: world class t-5 swap, posi unti pics inside
what gears are in the rear, is it drum, how much and where are you located, thanks Brandon
Transmission: t56
Transmission: t56
Transmission: t56
POSI
Car: 83 Trans Am / 79 Camaro/dune buggy
Engine: 400 TPI/406 /1911
Transmission: WC T-5/ T-56 (looking)/bus trans
Axle/Gears: 3.42/3.73/4.56
Where in PA are you located?
Transmission: t56
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
the posi was from a 9 or 10 bolt? are the cones bottomed out?
Transmission: t56
10 bolt. cones ?
Transmission: t56
shouldnt be more then 100 I would think I can call ups on monday.
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
i could do 500 shipped ( trans assembly)
02333, for shipping now sure how much itll be
Transmission: t56
just the trans and shifter?
Axle/Gears: 3.23's
i was thinking of the whole thing u advertised, clutch flywheel, hydraulic, tranny, ( stocker shifter i dont care )
Transmission: t56
I have an offer on just the trans for 500
Axle/Gears: 3.23's
Well thats a little rich for my blood at this time
Good luck with the sale
Transmission: t56
I will keep every one posted I have no cash at this time only talk
Transmission: t56
bump
Transmission: t56
bump
flywheel, clutch and pressure plate, bellhousing, shifter still 4 sale
Car: 88 firebird
Transmission: t-5
Axle/Gears: 9 bolt 3.91
This was the response I got after asking a simple question as nice I could. Would you expect to pick a trans up for $450 that has a stripped drain plug that nobody mentioned. He didn't say anything about it, I saw it when I got there. I didn't think it was that bad until I got home, and the price of the drain plug isn't the question, it's whether or not you could get it out, and I did.
This is what I asked
"I wonder what else i'm going to find when I install the trans. I got the drain plug out, but I don't know why you wouldn't have let me know that it was stripped. When I saw it, I didn't think it was totally stripped. I wonder if it was rebuilt, and if it was behind a 305 after the rebuild like you said. But who cares now it's over and done with. thanks"
Then I get the response
"think what you want the trans was rebuilt.! I had the trans fluid changed at a shop when I didnt have time to do it and some moron stripped the plug. a plug costs what? 2 dollars maybe and it was behind a stock 305!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!"
I'm guessing he didn't want to admit he's a worse mechanic then I am. Take blame for your actions. How am I supposed to believe the trans was rebuilt if you didn't show a receipt, and you didn't tell me about the drain plug, because you are too embarrased to admit you didn't realize. Thank you
Transmission: t56
If you noticed the plug was stripped why didn't you mention it to me? were you scared? I'm not going to say this again the trans works perfectly if you know how to drive, which you probably do not. Anyone else would get frustrated if you keep getting asked the same ?'s over and over again, eventually a person will get pissed off.
Car: 88 firebird
Transmission: t-5
Torque arm threads were damaged also, but yes you are a good mechanic. Can't wait to see how long the trans lasts, thank you for a smooth transaction.
Transmission: t56
the threads were fine cry baby keep on whining!! waaaaaaaaa
Car: 1983 Camaro Z28/1999 Cavalier
Remind me to never buy anything from you, you freaking *******.
Jesus christ man, could you be any more childish about this? I didn't buy it from you and I want to punch you in the face for what you did, dipshit.
Transmission: t56
mind your own business *******!!!
why don't you come punch me then try it!!!
Last edited by j88l98irocz; Aug 19, 2007 at 01:19 PM. Reason: Automerged Doublepost
And no, I will not mind my own business. How you are acting right now will strongly affect the outcome of you trying to sell anything more, especially because of my new thread about you:
https://www.thirdgen.org/forums/clas...needs-see.html
Good luck, douchebag.
Transmission: t56
you cant even read correctly fagot!!! I do not care at this point everybody wants something for nothing anyway. I do not understand why Im getting crucified, This is a used t-5 not new. The transmission that I sold was rebuild around 3 years ago I only put around ten thousand miles on it. I told the guy that, it was also in a stock 88 Irocz with a stock 305 tpi. The oil drain plug is not even worth arguing about, I found the receipt yesterday. you try finding a receipt from 3 years ago. I do not sell junk If everyone thinks that I am such a scam artist then check out my ebay feedback it is all 100% positive with no negative and I sold engines, transmissions, and cars with all satisfied buyers. I have also bought and sold things from this site with no other problems until now. So dont jump on your boyfriends bandwagon ***!!
I'm not talking about the quality of your parts, or how good your feedback score is.. that has nothing to do with what I am talking about.
I am talking about how you are handling this situation, telling the guy who bought from you to "keep on whining!! waaaaaaaaa"
That is completely immature and childish, all of the name calling is ridiculous. I don't care if you are a good seller or not, your personality sucks. If that is how you are going to treat someone who buys from you, or better yet a customer, then no thank you, I will get better service somewhere else.
I believe others are going to feel the same way.
Car: 88 firebird
Transmission: t-5
Thanks at least someone agrees.
I've got screwed before worse then this. I'm used to it at this point. It's funny how i've only put about 25 miles on it, and when downshifting into third it doesn't want to go sometimes. My other t5 has a good ammount of mileage, and abuse, it's funny I never had one problem downshifting into third. It was also a NWC.
If he lived closer i'd probably get arrested, but I don't care anymore i'm over it. It's my fault for buying a used trans from a white trash person. But i'm the white trash one for driving a subaru. Remember, you are what you drive.
Car: 92 corvette
Engine: lt1
Axle/Gears: dana 36 with 3.73s
heres my 2 cents on this situation i actually went to buy this trans when it was in the car not to long ago but had money problems and deal fell through, and i drove it prolly 25 miles under exceleration and decel with no problems what so ever, it isnt a cable clutch maybe you have air in the system and need to bleed it correctly is what it sounds on why it is doing that as far as the other little problems not really a big deal easy cheap fix
Transmission: t56
Tom you would not be arrested you would be in the hospital.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Looks like all "little things" that have gotten blown out of proportion to me
If someone inspectes a part in person than hands over thier $$ than - that's it - done deal. If you inspect the part and pay for it than you thought it was worth the price. The plug and threads should have been spoted - the problems were not internal. All a person selling something can do is to inform the buyer of everything they know about the part, and not not omit any details.
Don't think I'm pointing a finger either way here,...... just seems like you guys had to big a chip on your shoulder and took "venting" a bit further than you should have. The buyer is right 'cause there was an unknown problem found after the purchase - the seller is right 'cause he didn't lie and gave you what you inspected. The buyer was wrong for questioning the claims after the sale and the seller was wrong for getting to mad - to fast.
There's talk about trading punches over this;
Come on guys - Chill out !
Transmission: t56
GOOD CALL John
Car: 88 firebird
Transmission: t-5
It has nothing to do with my hydraulic clutch. I took one trans out and put the other in, that's it. There was no problem with the other one, and the hydraulics weren't touched.
I'm wrong for questioning claims after the sale, ok. If someone fails to mention two small problems, how can you believe it has 10k on a rebuild?
And like I said before I would get arrested, your muscles mean nothing, you probably can't fight to save your life.
Transmission: t56
You still have to keep this going don't you!!! You fuc#ing as#hole!! You are pretty stupid. Never judge a book by its cover tough guy! IF you are so tough why don't you drive back up here and try to kick my as# you got my address. All you can do is run your mouth, you just cant back it up. So please drive up here!!!
Iroc8t8
Today 02:06 AM
ambainb
Apr 25, 2016 09:21 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
for such issues.
