More great stuff
Old Sep 17, 2007 | 09:57 PM
cocacolakidd's Avatar
Car: 84Z & Porsche
Engine: 427sbc - 471 - 850 Demon Claw
Transmission: Bowtie stage II TH700R4 - 10" 3000
Axle/Gears: 9 Bolt w/ 3:45's
More great stuff
Cross flow aluminum radiator (Cool any beast) NASCAR special. Solid Polished Aluminum (No plastic tanks). This is a cross flow radiator and is 28”L x 20 ½ H. x 4” thk. It is equivalent to Two normal radiators (Ask about what is a cross flow). Used and from NASCAR #10 Car, garanteed not to leak (a few fin rubs only) - $150.00 + Shipping
Corvette mini starter, 3HP Summit Mini Geared Starter with multi position mounting block (Summit P/N SUM-G1660A). Will fit 153 and 168 tooth flywheels, will also fit 400ci small blocks - new never mounted cost 150.00 new - sale $75.00 + Ship
T-Top sun visors (Black in great condition- used) off of an 84 Z28 - $35.00 + Ship
AC Delete air vents for under dash (Pull cable system for fresh outside vent air - it's like 2 and 60 AC). Complete with pull **** panel, panel mounts below dash, and both firewall vent flappers - it’s all there. Looks new - from 88 B4C - rare - $50.00 +ship
Fantastic condition rear window de-fog braided wire connectors and complete wire loom - fantastic shape - $25.00 + ship..
Center console clock - almost perfect - keeps good time and with two others for extra parts. (Hard to find this good) $45.00 + ship
Z box quick ratio steering box. From 88 IROC - great used condition, smooth operating, and does not leak - 2 1/3 turns from lock to lock. $35.00 + ship
Auto Meter Carbon Fiber Trans Temp Gauge. Summit p/n ATM-4757 - New in box never mounted with sender and all - new $59.00 sale at $30.00 +ship.
Dual gauge A-Pillar Pod - black. Fits Thirdgens - $25.00 + ship
SLP stainless shorty headers 1 3/4 primaries. Used in good condition. Air tubes cut off and need to be welded or drilled and tapped and plugged. $150.00 + ship
Summit Chrome 100amp Alternator New in Box From Summit p/n SUM-G1667A - with fan and pulley - $115.00 new - sale $60.00 + ship.
Aluminum CNC Pulleys Crank 3 groove and water pump 2 groove, both new in box . Trans-dapt p/n TRD-9486 3 groove crank pulley ($62.00)and Trans-dapt p/n TRD-9479 two groove water pump pulley ($59.00) - Sale pair $60.00 + ship
1 1/2" or 2" wheel adapters (One or the other, 1 pair only). Trans-dapt Billet aluminum,
5 ¾ x 5 ¾ $130.00 pair new - $60.00sale +ship
Poly motor mounts, slightly used, and Poly trans mount New in box $35.00all +ship
Perma Cool adjustable dual fan thermostat set-up (Turn on/off each fan by a temp setting - screw in fittings/senders, not the bulb in the radiator style). For dual fans and has dual relays, complete set-up - $149.95 new - sale $60.00 + ship
Oil Cooler sandwich plate C-N-C aluminum, with thermostat for cold oil bypass at start. New in box - $25.00 + ship
Allot of other stuff - could go on and on - ask for what you may need.
Cocacolakidd
Ed
Rogue Valley, Oregon
nushi@q.com
541-664-4106
Old Sep 17, 2007 | 10:44 PM
87Formula391S/C's Avatar
Car: 87 Formula
Engine: L98-350
Transmission: 700-R4
Axle/Gears: 3:08 Posi (Disk)
Re: More great stuff
put me in line for the following.
Auto Meter Carbon Fiber Trans Temp Gauge. Summit p/n ATM-4757 - New in box never mounted with sender .
can get a look at a pic of them too..
Old Sep 17, 2007 | 10:52 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
pm sent
Old Sep 18, 2007 | 12:16 AM
cam383's Avatar
Car: 89 and 91 Camaro RS
Engine: 350ci TPI and 305ci TBI
Axle/Gears: 2.73 One-wheel wonder
PM Sent
Old Sep 18, 2007 | 01:22 AM
Car: 84Z & Porsche
Hello all,
I lost my digital camera battery charger in a recent move, and have not had decent time to replace it.
It is a black normal dual gauge pillar pod. Fits thirdgen A pillars, and matches black A pillar vinyl material. New, never mounted. Fits 2 1/16" gauges.
I am going to guess at about $10.00 for their minimum shipping to most 48 states (It's not that heavy). Have a couple of PM's also already for it.
Old Sep 18, 2007 | 01:33 AM
Car: 84Z & Porsche
Hello 87Formula391SC,
The AutoMeter CarbonFiber Trans Temp gauge is new in box never used or mounted, Out for inspection only. most all web sites have good pics. of the gauge (Jegs has a great close-up). Just look for AutoMeter CarbonFiber Trans Temp Gauge, 2 1/16", with electric sender. Guaranteed to be new.
Black normal dual gauge pillar pod. Fits thirdgen A pillars, and matches black A pillar vinyl material. New, never mounted. Fits 2 1/16" gauges. Guaranteed to be new, look new, is new. As good of top quality as can be found for Pillar pods.
Again I'll bet I can ship both the gauge and pillar pod to the 48 for $10.00 ( I think that is a minimum for most shippers).
Pay Pal at: nushi@q.com First come first serve.
Ed.
Old Sep 18, 2007 | 09:25 AM
WhiskeyChick's Avatar
Car: 1987 Trans Am GTA
Engine: 305 V8
Transmission: 5spd
Axle/Gears: 9bolt
PM sent
Old Sep 18, 2007 | 10:16 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Can you tell me what shipping would be for the Steering Box to 87108? Also, would you consider selling just the poly transmission mount? I already have the engine mounts.
Old Sep 18, 2007 | 04:16 PM
Car: 84Z & Porsche
Hello Wesilva,
I will consider selling the Poly Trans Mount seperatly for $15.00, I will also throw in a poly torque arm poly mount to match. Quick Ratio Steering Box with poly mounts at $50.00 total. Shipping to 87108, 30# and 13x12x10 = $18.10 by Fed Ex Home delivery. $50.00 + $18.10 = $68.10 (
Be sure to send complete shipping info. by PM or email or with Pay Pal (nushi@q.com).
Thanks, Ed.
Old Sep 18, 2007 | 05:04 PM
Stevo's Avatar
Car: Pair of 92 Z28s
What color are the motor mounts? If red ill take them.
Old Sep 18, 2007 | 05:25 PM
Car: 87 Formula
Engine: L98-350
PM and payment sent
Old Sep 18, 2007 | 07:11 PM
Car: 84Z & Porsche
The Motor Mounts are slightly used black Poly Mounts - $20.00 + shipping
Old Sep 18, 2007 | 11:09 PM
wesilva's Avatar
Transmission: 200R4
Originally Posted by cocacolakidd
Hello Wesilva,
Thanks, Ed.
Great! Thanks!
Old Sep 20, 2007 | 02:08 PM
Car: 84Z & Porsche
Bump - Bumpety, bump, bump.
Old Sep 20, 2007 | 03:32 PM
FASTIROC's Avatar
Any pics of radiator.
Matt
Old Sep 20, 2007 | 05:27 PM
Car: 84Z & Porsche
Hello Matt,
I have just moved, still unloading boxes, and so far I have not found the battery charger for the camera. Tomorrow or Friday I will either have it found or go get another. I will send pics. of C&R Radiator to your email.
Thanks for the inquiry,
Ed.
Old Sep 21, 2007 | 06:26 PM
head's Avatar
Car: 1984 MSE #52
Transmission: TH700
Interested in perma cool adj thermostat and dual guage pod . Shipped to 44126 Thanx
Old Sep 21, 2007 | 07:12 PM
Car: 84Z & Porsche
Dual Gauge Pod is sold -
Perma Cool setup is still here and for sale. It is new never out of box. For complete set-up for dual fan control - set the on and off where you want it. Includes two relays and dual wiring complete with all instructions and every thing. Has the screw in block thermostat for better reliability, and not the old bulb in the radiator trick.
Shipping to 44126 is $7.80 by Fed Ex (1.5# and 9"x 7.5" x 3.25" from 97502)
Ed.
Old Sep 23, 2007 | 11:20 AM
Engine: 305 V8
Transmission: 5spd
Axle/Gears: 9bolt
PM sent again
Old Sep 23, 2007 | 05:33 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
Did the other guy buy the perma cool set-up? If not air mail cost to Australia 3199? Pay by paypal? thanks.
Old Sep 23, 2007 | 07:23 PM
Car: 84Z & Porsche
Yes the other guy did purchase the Perma Cool Set-up.
What else might you need? Many new and used parts here (Used parts are much better than normal otherwise they would not be here).
The poly motor mounts I listed as used- they are actually new I found out upon recent inspection - same price.
Power Antenna - new or used. New is excelent quality after market. Used is from a 90 Z28 in better condition and works excelently - $25.00 ea + ship
Ed.
Old Sep 25, 2007 | 02:48 PM
Car: 84Z & Porsche
Old Nov 23, 2007 | 09:21 AM
Ob_one's Avatar
Car: 89 T/A Blue/Gray T-Top
Engine: 5.7
Axle/Gears: 327
Are the headers still for sale?
Old Nov 23, 2007 | 07:00 PM
Car: 84Z & Porsche
Headers sold - Thanks for the inquiry though.
Old Nov 23, 2007 | 07:33 PM
dpmalibu's Avatar
Do you still have the chrome alternator and aluminum pulleys? PM me.Thanks
If you have pics of them please send them to dp30carsplus@optonline.net
Old Nov 27, 2007 | 08:45 AM
trtrader's Avatar
Do you still have the Trans-dapt crank and water pump pulleys?
Old Nov 27, 2007 | 09:07 AM
waite1of4's Avatar
Car: 93 Z28,83 Z28,07 Civic Si,04 Yukon
Engine: 355LT1, LU4 305, 2.0 200hp, 5.3
Transmission: A4, 700r4, 6sp, 4l80e
Axle/Gears: 410, 373, ?, 373
Do you still have the wheel adapters? Is this the right ones for 4th to 3rd gen wheel swaps?
Old Nov 27, 2007 | 02:34 PM
dpmalibu's Avatar
Check your email.
Old Nov 27, 2007 | 03:28 PM
83MonteSS's Avatar
Is the steering box stamped xh? If so how much shipped to 75224? And the wheel adapters, can you double check how wide they are? If they are 1 1/2 I may be intrested. Thanks.
db057
Sep 4, 2015 07:57 AM
camaroinmotion
Exterior Parts for Sale
Sep 2, 2015 08:25 AM
E Rod
Aug 28, 2015 05:17 AM
Winchester1094
Aug 18, 2015 10:23 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
