tpi cams, edelbrock base
Old Sep 24, 2007 | 06:21 PM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
have comp cams part no. 12-365-4 new.
cs260 xfi h-13
duration is 216 @ .050 int. exh. is 223 @.050
valve lift is .499 int. .493 exh.
lobe sep is 113
flat tappet
$75.00
roller cam from slp used
duration is 218 @ .050 int 224 @ .050 exh
valove lift is .495 int. .502 exh
lobe sep is 114
great idle
$125.00
edelbrock base high flo ported some
ed-3860
egr block off included
works on centerbolt and early style heads
also has bottom plate already bolted on
$275.00
Old Sep 24, 2007 | 11:08 PM
camaroz2810's Avatar
Car: 1987 Camaro Z28 IROC
Re: tpi cams, edelbrock base
can i see picks of the edelbrock base please?
Old Sep 25, 2007 | 11:19 AM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
how would that slp cam work with a 89 lb9?
Old Sep 25, 2007 | 06:31 PM
old z mzn's Avatar
Car: 1992 z-28
Transmission: auto
Axle/Gears: 4.10
sold everything but the base on another post pics are there.
listed as tpi parts for sale
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
Can you get a shipping quote to Columbia, Mo 65202 and I can get a money order out to you friday!
Old Sep 25, 2007 | 06:37 PM
old z mzn's Avatar
Car: 1992 z-28
Transmission: auto
Axle/Gears: 4.10
knocked off 4 tenths on my 350. should help a 305 if your heads can handle the lift . I have a bin. for a 305 that will wake it up and work with this cam.
Old Sep 26, 2007 | 04:51 PM
I'll take the edelbrock base, how about $250 shipped, or is $275 shipped the minimum you'll go, I'll take it so don't get rid of it, thank you
Old Sep 26, 2007 | 05:56 PM
Car: '87 Iroc-Z
Yo bro I'll take that base. $300 sounds good to me. PM me so we can work out the details!!
Old Sep 28, 2007 | 02:16 PM
I will have the money sent out for the base tomorrow, thanks for the details.
Old Sep 29, 2007 | 12:20 AM
payment sent
Old Oct 3, 2007 | 04:50 PM
old z mzn's Avatar
Car: 1992 z-28
Transmission: auto
Axle/Gears: 4.10
base is sold
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
89-S-dime
Aug 12, 2015 11:57 AM
Fronzizzle
Aug 9, 2015 01:15 PM
