Tons of aftermarket and performance parts
Old Oct 17, 2007 | 02:37 AM
Phatfiddler's Avatar
Hey guys. I'm selling my car and won't need all of the parts that I have collected over the past 3 years for it. I have been preparing for an engine build but plans have changed (AGAIN, ugh). My loss is your gain. I accept money order and PayPal, and cash for local buyers. Pictures upon request. You pay PayPal fees for items over $200. Thanks for looking!
I need to sell the block and stand locally since shipping will be outrageous. Everything else I can ship.
Brand new 4-bolt 350 block $650 - BRAND NEW from GM, never used, fully machined, cam bearings and freeze plugs installed, 1-piece RMS
Fold-up, 4-leg engine stand $120, $50 for whoever buys the block - summit brand, red, set of bolts for holding engine
Cutler (same as Holley) Single-Plane EFI intake $850 setup with 4-bbl billet throttle body, fuel rails and connectors, has progressive throttle linkage
Brodix IK200 aluminum cylinder heads $950 - 64cc chambers, fully assembled from Brodix. I also have guide plates for them. Never used.
Brodix natural aluminum valvecovers $100 - perimeter bolt, tall, all hardware, BRODIX logo on them, new in box and never used
Polished aluminum fabricated valvecovers $45 - perimeter bolt, medium height, never used but need a good polishing
Turbonetics aluminum carb-hat $75 - mounted on intake but new and never used
Aluminum intake $60 - for TBI/Carb/single-plane EFI setups - comes with huge K&N cone-type filter, clamps and silicone connectors
LS1 441' ECM $65 - was going to use for EFI setup on the 350
LS1 441' swap front timing chain cover $35 from Vortec engine - was going to use for EFI setup on 350. Never used.
ARP cylinder-head studs $80 - with nuts - allen head (6-side pattern) centers, never used
GM 1.6 aluminum full-roller rockers $220 - Complete set never used. Should fit both center and perimeter bolt patterns
LT4 HOT cam $180 - Brand New and never taken out of the box/tube.
Keith Black pistons $290 - FORGED 4.000", 10.2 cr with 64cc heads, flat-top, full floating or pressed fit - New in box never used
Keith Black pistons $190 - HYPER 4.000", 9.5 cr with 64cc heads, dished, full floating or pressed fit - New in box never used
Eagle cast steel crank $100 - 1-piece RMS, 3.48" stroke - never used, still in packaging
Eagle 4340 forged ESP H-beams $375 - 5.7", cap screw, for floating or bushed/pressed pistons, new in the box and never used
Serpentine setup $80 with bracket, belt, steering pump, smog, A/C, and pulleys
Sold Cam degreeing kit $35 - includes everything needed including carrying case, degree wheel, dial caliper, springs, piston stop. Does NOT have the magnetic base.
*** I also have brass freeze plugs, a set of piston rings for the sets listed above, and rod and crank bearings.
Last edited by Phatfiddler; Oct 18, 2007 at 09:35 PM. Reason: Updated information, prices added
Old Oct 17, 2007 | 08:19 AM
jrdrag's Avatar
Re: Tons of aftermarket and performance parts
Is there a billet rail on the fabricated valve covers?
Old Oct 17, 2007 | 08:43 AM
Not really sure. Heres 2 pictures to help you.
Attached Thumbnails Tons of aftermarket and performance parts-cover1.jpg   Tons of aftermarket and performance parts-cover2.jpg
Old Oct 17, 2007 | 09:07 AM
Bigseth's Avatar
Car: 86 Iroc 383 carb, 97 T/A WS6
PM sent on cam degreeing kit
Seth
Old Oct 17, 2007 | 09:42 AM
Here you go BigSeth. Cant seem to find the instructions, but those can be found in the forums and tons of other places online.
Old Oct 17, 2007 | 10:48 AM
manifoldsrme's Avatar
Car: 1985 IROC / 1986 SC
Engine: 305 TPI / 2.8 MFI
Transmission: 700R4's
Axle/Gears: 3.27 Posi / 3.42 Open
How much for the serpentine setup shipped to 06002?
Old Oct 17, 2007 | 11:10 AM
z28gsxr's Avatar
Car: 91 RS Vert/98 Sierra9
Engine: 5.7/5.0
Transmission: 5spd/auto
Axle/Gears: 4th gen rear with 3.73
pix of alluminum intake and how much shipped to 90262 also do u know if it'll fit vortec heads
Heres a pic for you. You're pretty far away, so I can do shipping for $25. Thanks for looking!
Old Oct 17, 2007 | 11:14 AM
Heres a picture of the block, aluminum air intake, single-plane EFI setup, turbonetics carb hat, Brodix IK200 heads, and the 1.6 roller rockers for those interested. This is just a mock setup and nothing is bolted down. The EFI manifold is drilled for the standard bolt pattern (4 bolts on each side of the manifold, center two bolts on either side are angled, but can be drilled to fit older style heads).
Notice, the aluminum intake is the air intake, not the manifold, although the EFI is indeed aluminum. Sorry if I worded it confusingly.
Old Oct 17, 2007 | 01:35 PM
JR Performance's Avatar
Car: 89 Iroc-Z
I'll take the serpentine setup if its still for sale.
Old Oct 17, 2007 | 01:42 PM
Car: 89 Iroc-Z
so were you going to use a ls1 computer and harness to power this intake setup. would that work? and has anyone else ever done this?
Old Oct 17, 2007 | 03:06 PM
JR - yes, its been done many times. Look in the TPI forum for "TPI sequential" or something along those lines. S10 Wildslide also makes custom harnesses for the LS1 441' computer to be used., or you could rip a harness out of an Express Van that used the Vortec engine and the same ECM.
The serpentine is still available. I will need your zipcode for shipping price. PM me. Thanks!
***Updated first post. I cannot seem to find the magnetic base for the cam degreeing kit...
Old Oct 17, 2007 | 09:09 PM
400CI87Firebird's Avatar
Car: 1987 pontiac firebird formula ws6
Engine: chevy 400 cubic inch V8
Transmission: turbo 350
how tall is the carb hat from the mounting surface to the tallest point up top? i dont have much room off my edelbrock efi setup to the hood. Thanks-Tom
Old Oct 18, 2007 | 12:25 AM
Car: 89 Iroc-Z
The serpentine is still available. I will need your zipcode for shipping price. PM me. Thanks!My zip code is 19446
Old Oct 18, 2007 | 08:42 AM
Sonicbluecamaro's Avatar
Car: 84 camaro z28
Engine: 350 Carb
Transmission: Built 700 R4
is the sepretine setup still available if so , shipping to 88030.
if not the carb hat and the intake system shipping to 88030
Old Oct 18, 2007 | 09:45 AM
z28gsxr's Avatar
Engine: 5.7/5.0
thethe intake system does it fit any kind of carb? and I'm limited on clearence space so how tall is the part that goes over the carb
Old Oct 18, 2007 | 01:48 PM
The intake system will fit a carb, TBI, or EFI setup. The carb-hat is made for low-clearance places, so it has a good fit. The total height of the carb-hat is around 2.75 inches from where it sits on the base of the carb/TB/TBI etc. If using this setup on a stock TBI unit, the injector pod will hit slightly inside the carb-hat, so you will need to either use a spacer or double-stack the gaskets, no biggie.
I know for a fact that this setup will fit on a high-rise air-gap intake under a stock Camaro hood with some modifications to the hood brace, so any other type of shorter manifold (dual-plane, stock etc) should work just fine.
Sending PMs out to others.
Old Oct 18, 2007 | 01:54 PM
z28gsxr's Avatar
Engine: 5.7/5.0
how much shipped to 90262 for the intake system?
Old Oct 18, 2007 | 07:27 PM
the carb hat would actually be going on a 85 corvette im building. i am heading back home tomorrow and i will check to see if it will fit under the hood. Thanks-Tom
Old Oct 19, 2007 | 08:05 AM
***I cant edit my original post, so please read up-to-date posts to see what is still available!!***
I'm trying to get back to everyone in the order they inquired about parts, so if I have'nt responded to you yet, I'm not ignoring you :-)
Serpentine setup is pending JR
Carb-hat setup and intake/filter is SOLD
Cam Degree kit is SOLD
Fabricated valve covers are SOLD
Old Oct 19, 2007 | 11:12 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Its a phenominal upgrade over any chip based ecm. I couldnt imagine burning chips now with knowing this technology is available. Both my cars are living happy on it.
Old Oct 19, 2007 | 12:05 PM
Aweasel's Avatar
Car: Red '89 IROC-Z
Engine: 350, Patriot 195s,
Transmission: T56, Hurst Shifter, Alum. DS, 3.73
you have a pm
Old Oct 20, 2007 | 07:16 AM
Aweasel, I didn't receive your PM.
Thanks Mkos 1980! The 441' ecm swap is worth every penny.
Items that have been paid for are being shipped out today.
Alright, I need this stuff gone ASAP so I can make a down payment!
Buy the engine and you can have the stand, I wont need it!
FREE matching Fel-Pro 1206 gaskets if you buy the heads!
FREE cam bearings if you buy the LT4 HOT cam!
Heres more pictures of the EFI setup, bulletproof forged rods, and BRODIX covers, all ready for your project!
Attached Thumbnails Tons of aftermarket and performance parts-pa200045.jpg   Tons of aftermarket and performance parts-pa200046.jpg   Tons of aftermarket and performance parts-pa200048.jpg
Old Oct 22, 2007 | 04:48 AM
Sent out the tracking numbers. I shipped everything UPS and will do so for the rest of the stuff as well since they give free tracking numbers with shipments.
Old Oct 22, 2007 | 06:49 AM
joeEZ's Avatar
If you still have the crank in a few weeks, shipping to Memphis, TN 38122?
Any pictures of it? I don't suppose theres any bearings that could be thrown in too? HEh..
Old Oct 22, 2007 | 07:12 AM
joeEZ, I do still have the crank. It is still packaged in the bag, but yes, I can get pictures for you. I'll PM you the shipping costs for it and have pictures today.
If you buy it, I will throw in some new bearings for you, no problem!
Old Oct 22, 2007 | 02:18 PM
joeEZ's Avatar
Most appreciated. Thanks!
Old Oct 22, 2007 | 05:33 PM
Heres a picture of the crank in the bag and the crank bearings. Shipping cost will be around $31 to your location.
Aweasel, the fabricated covers have been sold.
Old Oct 22, 2007 | 11:36 PM
irocman88's Avatar
Car: 88 IROC
Engine: carburated 350-- H/C
Axle/Gears: 10 bolt w/ auburn posi and 3.73s
still got the efi setup by chance?
Old Oct 23, 2007 | 01:00 AM
irocman88, I do have the EFI setup.
It is a single-plane, air-gap setup with a 4-bbl throttle body. The TB has a progressive linkage on it, much like 4-bbl carbs do. The setup includes the manifold, fuel rails, fuel rail plumbing, 1,000cfm billet throttle body, and the bracket to use the kickdown cable on automatic transmissions. It is assembled short the bracket, which I bought but never added on.
I can include the injectors as well for free if you want them. They are low-impedance injectors (4-5ohms each), and were installed on the system when I originally purchased it.
This setup will work with the stock TPI computer and wiring, or any aftermarket system you may choose, and uses all GM sensors.
Old Oct 23, 2007 | 01:57 PM
91chevz71's Avatar
take 200 shipped for the 1.6 rockers?
Old Oct 23, 2007 | 04:21 PM
91rst's Avatar
Car: 91RS
Engine: 3.1
Are you willing to cut a guy a deal for the block, crank, forged pistons, H-rods and the head bolts? I would pick up.
Old Oct 23, 2007 | 04:38 PM
joeEZ's Avatar
I'd take the crank, but if you can get it sold sooner, you needn't hold it for me.
Old Oct 24, 2007 | 12:48 AM
91chevz71's Avatar
pm sent
Old Oct 24, 2007 | 08:09 AM
PMs and posts replied to.
The serpentine setup is again for sale.
Old Oct 24, 2007 | 03:42 PM
Roller Rockers are now SOLD
Old Oct 26, 2007 | 07:05 AM
Rockers getting shipped today. Bumping the thread! Need parts gone, need to make a down payment!
Old Oct 27, 2007 | 05:49 AM
Car: 84 camaro z28
Engine: 350 Carb
recieved. thanks.
Old Oct 28, 2007 | 11:54 AM
irocman88's Avatar
Car: 88 IROC
hey man thanks for the info but unfortunately at this point the funds just aren't there. I sell cars for a living, and the business is unusually slow, even for this time of year.
Old Oct 28, 2007 | 11:59 PM
jay_d's Avatar
Car: 84 z28
Axle/Gears: one wheel peel
Do you still have the serp setup? If so shipping to 30577 plz
Old Oct 29, 2007 | 03:15 AM
Gonna try to get some PM replies out today. I've been doing a lot of overtime lately and havent been on much :-/
Old Oct 30, 2007 | 12:42 AM
*UPDATE*
I may have been overzealous with some of the prices, so I am willing to negotiate on the prices. I need the stuff gone so I am willing to deal.
EFI setup is now $700 plus shipping. Bolt on in place of your TPI!
Block is $650 plus the engine stand.
Fabricated covers are SOLD
Rocker arms are SOLD
Carb hat and tubing SOLD
Cam degree kit SOLD
FREE bearings with the crank!
FREE engine stand with the engine block!
FREE piston rings. First buyer of either set of pistons gets them.
Old Nov 6, 2007 | 02:49 AM
Hey guys. Cylinder heads, intake, both sets of pistons, camshaft, rods, and Brodix valve covers are now on ebay. If you're intereted, search for them there. Thanks for looking guys!
MantyZ28
Jan 18, 2016 08:30 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
92camaroJoe
Aug 13, 2015 06:07 AM
1nastygta
Aug 8, 2015 07:38 PM
