VORTEC head setup with GMPP hot cam and install parts $500.00.SOLD!!
Old Nov 1, 2007 | 09:48 PM
espirocz's Avatar
Car: CTS-V & 89 Z28 vortech charged
Engine: LS6 & 383 charged stroker
Transmission: 6-speed & 5 speed
I have for sale a set of VORTEC heads packaged together with a GMPP HOT cam and alot of parts to install heads.
Included are :
Pair of 10239906 casting Vortec heads machined to accept LT4 springs and clearanced for lift of hot cam. Machined for screw in rocker studs. Pushrod slots clearanced for 1.6 rockers. With factory valves.
General Motors Performance Parts HOT CAM .525/.525 lift
GM LT4 valve springs, caps, and retainers (same springs that come on ZZ4 engine)
GM screw in rocker studs set
GM head gaskets (pair) 10105117 compressed thickness of .035
GM head bolt kit with preapplied sealer.
GM roller cam timing chain kit
Front cover gasket kit for L98
GM thick style dual bolt pattern intake manifold gaskets
GM Factory vortec gaskets
$500.00 takes it all.
I dont know how much it would be to ship but I would be willing to ship these if someones intrested. I dont want to part any of this out just yet, if you have any questions feel free to PM me or email me at tjsh@verizon.net
Thanks, Tim.
Attached Thumbnails VORTEC head setup with GMPP hot cam and install parts 0.00.SOLD!!-dsc00760.jpg   VORTEC head setup with GMPP hot cam and install parts 0.00.SOLD!!-dsc00769.jpg   VORTEC head setup with GMPP hot cam and install parts 0.00.SOLD!!-dsc00770.jpg
Old Nov 1, 2007 | 09:51 PM
espirocz's Avatar
Re: VORTEC head setup with GMPP hot cam and install parts $500.00.
more pics
Attached Thumbnails VORTEC head setup with GMPP hot cam and install parts 0.00.SOLD!!-dsc00761.jpg   VORTEC head setup with GMPP hot cam and install parts 0.00.SOLD!!-dsc00762.jpg   VORTEC head setup with GMPP hot cam and install parts 0.00.SOLD!!-dsc00763.jpg
Old Nov 1, 2007 | 10:06 PM
espirocz's Avatar
and some more pics
Attached Thumbnails VORTEC head setup with GMPP hot cam and install parts 0.00.SOLD!!-dsc00765.jpg   VORTEC head setup with GMPP hot cam and install parts 0.00.SOLD!!-dsc00766.jpg   VORTEC head setup with GMPP hot cam and install parts 0.00.SOLD!!-dsc00767.jpg
Old Nov 1, 2007 | 10:32 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
PM and Email sent
Old Nov 2, 2007 | 12:44 AM
Aceprowler's Avatar
Bump for great price!
Old Nov 2, 2007 | 02:09 AM
rhit_rs's Avatar
Re: VORTEC head set with GMPP hot cam and install parts $500.00.
Can I be second in line behind Mkos? I'll PM you shortly.
Old Nov 2, 2007 | 07:25 AM
espirocz's Avatar
You are second in line! But right now money talks!
Old Nov 2, 2007 | 07:50 AM
SteelTownMadDog's Avatar
So, this does NOT include valves, correct?
Old Nov 2, 2007 | 08:21 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
How did they go about fixing the stud boss? How far did it crack down when removing the studs? Is it flush? thanks!
Old Nov 2, 2007 | 03:44 PM
espirocz's Avatar
This set includes stock valves. The set is a complete set, I was going to upgrade to race valves, but ran out of money, that is the only reason they are not assembled.
STOCK VALVES ARE INCLUDED WITH THESE HEADS.
TO ALL WHO LOOK AT THIS AD : Go back to the close up picture of the head and look above the casting number. One of the rocker stud bosses broke when the machine shop pulled out the rocker stud. They added metal to make a flat surface to cut where the screw in rocker stud screws down to. The depth of the bottom screw portion, of the screw in stud, goes below the crack and repair. I will try to get a closer shot to show what I am describing.
Tim.
Old Nov 2, 2007 | 06:14 PM
espirocz's Avatar
bump
Old Nov 2, 2007 | 07:02 PM
espirocz's Avatar
Until I have cash in hand these are still for sale!!!
Old Nov 3, 2007 | 11:27 AM
espirocz's Avatar
bump
Old Nov 3, 2007 | 03:18 PM
85_SS's Avatar
Car: 1985 Monte Carlo SS
Engine: 5.7L
Transmission: WC T-5
Axle/Gears: 3.73:1
If you end up splitting up the kit I may be interested in everything (if you'll ship to Canada through United States Postal) with the exception of the cam and timing chain since I do not have a roller block.
Old Nov 4, 2007 | 02:36 PM
rabrand's Avatar
Should have made the machine shop buy you another head.
Old Nov 8, 2007 | 07:57 AM
espirocz's Avatar
SOLD
Thanks to all who held interest in these heads, Tim.
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
