t-5 speed sensor
Car: 79, 85, 87,91 TRANS AM'S
Engine: 455,305TPI,350TPI,350TPI
Transmission: MUNCIE, T-5, 700R4'S
Axle/Gears: YEP
t-5 speed sensor
im looking for a speed sensor for a t-5 manual tranny please let me know thanks
Axle/Gears: YEP
Re: t-5 speed sensor
yes i do. i need an electric one thanks kevin
Axle/Gears: YEP
would you like to sell or trade for it?
Axle/Gears: YEP
i have a mechanical and need an electric want to trade 85_ss ??
Axle/Gears: YEP
mine is setup for a 3.23 gear (thats what was in it and was working fine) its in the tranny right now. with out the cable hooked up. as for the tabs to hold it in place i believe ide need them to switch from mechanical to electronic
Car: 1985 Monte Carlo SS
Engine: 5.7L
Transmission: WC T-5
Axle/Gears: 3.73:1
The electronic unit is molded with the tab built into the body (at least the one on my 92 T5 is) - I can send you a pic to show you what I mean. You should only need the small bolt and not the tab to mount it.
Axle/Gears: YEP
sounds good to me. i can send you the mecanical and the tab for your sensor. sound good to you??
