CAM+SPRINGS,BALANCER,INJECTORS FOR SALE
Car: 87 GTA
Engine: 5.0 LB9
Transmission: 700-r
New Engine Works #135284HR Hydraulic Roller Camshaft for Chevrolet 305 350 383 stroker small blocks 1987and up blocks.This is an upgrade for the HO Roller.Good everyday performance with increased HP and Torque in midrange.Will work with stock computer.It does have a fuel pump ecentric. Made in USA,NEW in Factory sealed Box
$150+shipping
* 1800 to 6000 RPM Range
* 288 / 284 advertised duration
* 210 / 215 duration @ .050"
* .462 / .470 valve lift
* 106 / 114 centerline
* 110 lobe separation WITH
New Engine Works Valve Spring Kit #SRK927 for Chevrolet 302DZ 305 327 350 383 stroker 400 small blocks.These are 1.260" diameter,145 lbs @ 1.750 and .600" max lift.For Hydraulic or Solid Roller application.Includes Engine works Xtreeme Duty valve springs,Chrome Moly 4140 machined retainers,and 7 degree machined valve locks MADE IN USA
new in factory sealed box $100.00 + SHIPPING
PROFESSIONAL PRODUCTS POWER FORCE BALANCER FOR SBC CHEVY ENGINES 6.75" NEUTRAL, (INTERNAL BALANCED) 40.00+SHIPPING new in box sealed
USED Ford Racing "blue top" 24# fuel injectors mildly used ,,,id slap em in but you may want too send them off for rebuild i saw it was 100.00 too rebuild them from a sponsor on this site 60.00$ + SHIPPING
I accept paypal im a verified user if you are a bit uneasy because im newer here then i can do a fleabay auction where i have 592 100% positive Feedback
Rail
$150+shipping
Rail Last edited by Railguy; Sep 13, 2008 at 12:09 PM.
Car: 87 GTA
Engine: 5.0 LB9
Transmission: 700-r
Re: CAM+SPRINGS,BALANCER,INJECTORS FOR SALE
NO idea on the mileage ,,Id say he had about 100 hours on them before he gave up ,the screens look new the tips look new,,all of them ohm out to 14.6 exactly ,,,
regards Rail
regards Rail
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
recieved above mentioned injectors recently, excellent buying experience would reccomend seller to others
Car: 86 iroc-z, 78 z28, 91 z28
Engine: 355-carb, 350-carb, 350-TPI
Transmission: 5speed, at, 5 speed
Axle/Gears: 3.42, 3.42-stock, 3.42-1LE
is that harmonic ballancer sfi aproved?
let me know asap
thx
let me know asap
thx
still waiting on answer
LT1Formula
Nov 16, 2015 01:13 PM
New2Chevy
Oct 4, 2015 11:27 PM
