complete Holley Stealth Ram#7540 non-vortec
Car: 1990 GTA
Engine: stock L98(being pulled for rebuild)
Transmission: stock 700R4
I bought this a couple months ago from a fellow TGO member and never installed it. He claimed to have put a few hundred miles on it and judging by it's looks, I'd say that is accurate. Please note, this is not compatible with vortec heads, despite the description on many websites, including Holley's. I've decided to stay with a LTR set-up for the time being.
Included are the complete manifold and plenum, adjustable FPR and fuel rails, positionable waterneck, and braided fuel lines. GASKETS ARE NOT INCLUDED.Basically everything you see in the pics.
Asking $500 plus shipping. Paypal preferred.
Car: 1990 GTA
Re: complete Holley Stealth Ram#7540 non-vortec
Your stock ECM and chip will work fine, but you will see the most gain if you learn to burn your own chips. Lots of the good advice in the DIY Prom section.
Car: 91 Trans Am GTA
Engine: 5.7 TPI
Axle/Gears: 373 posi disk brake
damn just when im broke cause if im right this will bold and run off all my stock stuff right?
Car: 1990 GTA
It is designed to be a direct bolt to a stock TPI engine. I don't know exactly what set-up you are running so I don't want make promises about fit and compatibility, if you know what I mean. Your best bet would be to contact Holley, give them your specs, and ask them if part#7540 is the correct application for your ride. Just an FYI tho, Stealth Rams don't have EGR passages so might not be emission compliant.
Car: 1989 firebird gta
Engine: sbc 355 hsr 280xfi 58mm tb
Transmission: raptor 700r-4, 2800 stall
how much shipped to 29153 ?
Car: 1990 GTA
that is correct, this is NOT the vortec version of the Stealth Ram
/pm sent
/pm sent
Car: 1990 GTA
Stealth Ram is sold.
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
it looks like someone made the center bolt holesOblong to fit late model or vortech heads Do you have a close shot of the center bolt holes
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
