(2) 15x10 Greg Weld Dragstar wheels and tires
Old Oct 3, 2008 | 11:30 PM
fireredz28's Avatar
Car: 1991 RS Camaro
Transmission: th350
Axle/Gears: Ford 9"
Ive got 2 Brand new 15x10 wheels and 2 brand new tires up for sale. I had bought these and mocked them up on my new 9" rearend but the disk brake setup is too big and these wont fit. They will fit the stock rearend with factory disc/drum brakes on thirdgen camaro/firebirds and look very agressive. These are the closest thing to chrome as a polished wheel gets. Specs on the wheels can be seen here:
http://store.summitracing.com/partde...0&autoview=sku.
The tires are 295/50/15's and also brand new. They are Grand Spirit Radial GT. Very similar to a BFgoodrich radial T/A. The wheels new are $155.95 each and the tires cost me $75 each. The total was around $470. I'll let these go for $400 shipped. PM me with an email addy and I can send you some pictures.
Old Oct 4, 2008 | 10:07 AM
gcpoland's Avatar
Car: 86 MCSS-87 Z28
Transmission: Auto OD-5spd
Axle/Gears: 3.73 both cars
Re: (2) 15x10 Greg Weld Dragstar wheels and tires
Would you be interested in selling just the rims?
Old Oct 4, 2008 | 10:45 AM
fireredz28's Avatar
Car: 1991 RS Camaro
Transmission: th350
Axle/Gears: Ford 9"
Id really like to sell them together since the tires have been mounted and balanced, but im sure somebody would be interested in the tires. $300 for the wheels and $100 for the tires then. Thanks
Old Oct 4, 2008 | 11:28 AM
gcpoland's Avatar
Car: 86 MCSS-87 Z28
I am not in a hurry. Try to sell them togrther and if you can't get back to me. I don't need them till next spring.
Gary
Old Oct 4, 2008 | 09:51 PM
fireredz28's Avatar
Car: 1991 RS Camaro
Transmission: th350
Axle/Gears: Ford 9"
back to the top
Old Oct 5, 2008 | 06:45 PM
fireredz28's Avatar
Car: 1991 RS Camaro
Transmission: th350
Axle/Gears: Ford 9"
SOLD
Old Oct 7, 2008 | 08:00 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Curious as to which brake system you had on the 9" rear, and what the backsapcing on the wheels were? I'm in the same boat, Moser 9" with LS1 rear brakes and looking for decent drag wheels i dont have to grind the calipers down for.
Old Oct 7, 2008 | 08:11 PM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
Not sure if they still make them, but weld drag star xp will clear. They clear my lt1 calipers on my moser 9". they look just like regular drag stars except the have a little more clearance on the inside..
Old Oct 7, 2008 | 08:41 PM
ditchbangr's Avatar
Car: One of 5
Engine: LB9
X2 on what rear brakes you were using. I have a moser 9" setup to use 93-97 LT1 style rear discs that will be swapped in this winter.
Old Oct 8, 2008 | 01:22 PM
fireredz28's Avatar
Car: 1991 RS Camaro
Transmission: th350
Axle/Gears: Ford 9"
I think you guys will be alright, I went with the same set-up our college uses on our Cobra kit car. It uses a 12" rotor with the front calipers from an 80's SS Monte carlo and cutom brackets. Alot of circle track guys use this same setup on street stocks. The greg welds are clearenced for larger calipers but this setup is a monster compared to anything stock, mainly because of the big calipers. Im just going to wait untill greg weld releases the 17" version of this wheel. The I did a little grinding (1/4") and needed to go about 1/2" more. Probly could of been done but the caliper would be somewhat thin, and I need a good reliable setup on this car with no worries.
Old Oct 9, 2008 | 02:16 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
how big is your brake setup compared to a ls1 rear setup?
Old Oct 10, 2008 | 03:37 PM
fireredz28's Avatar
Car: 1991 RS Camaro
Transmission: th350
Axle/Gears: Ford 9"
im not sure compaired side by side but I use a 12" rotor and the caliper sticks about an inch past that
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
overdriv
Aug 20, 2015 03:52 PM
forstral
Aug 19, 2015 03:20 PM
