WTB T-56 6-speed
Old Oct 5, 2008 | 02:06 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
WTB T-56 6-speed
I'm looking for a t-56 trans. I also need lt-1 bellhousing, clutch, flywheel, 4thgen pedals etc for a swap into my 85 T/A behind a gen 1 (2 pc rear main seal) sbc.
Thanks!
Old Oct 5, 2008 | 11:32 AM
JoeyG's Avatar
Car: 68 Chevelle w/ TPI, 87 Formula 350
Transmission: 700 R4
Axle/Gears: 3.55 / 3.42
Re: WTB T-56 6-speed
I got one. Im looking for $1700 for the complete setup. All you would need is a piot bearing, pedals and modify your crossmember. Included is a 4th gen crossmember. Might be able to do something with it.
Old Oct 5, 2008 | 01:24 PM
Thanks man! I'll pass. I'm lookin at one thats here local for around 800.oo. I appreciate it though.
Old Oct 5, 2008 | 02:38 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Do you have the flywheel and crossmember? I have a Centerforce conversion flywheel for a two-piece and a Spohn T56 crossmember. $300 plus shipping for the combo.
Old Oct 11, 2008 | 04:38 PM
Sorry it took so long to get back. I broke my right hand on the 6th and had it re-set on thurs. (outch!) I am interested, wesilva! send me pics? is the crossmember for the factory-length torque arm? Thanks!
Old Oct 12, 2008 | 12:03 PM
wesilva's Avatar
Transmission: 200R4
It only mounts the tranny. You'll have to hook up the torque arm to the transmission. Judging by the this article, it looks like a straight swap.
http://www.skulte.com/T56.html
I would do a search on the transmission board.
PM me your e-mail address if you still want pics.
Old Oct 14, 2008 | 04:46 PM
pm sent, wesilva.
Old Oct 18, 2008 | 03:51 PM
ragtopday_z28's Avatar
Car: 92 RS convertible
Engine: none...building a 407
Axle/Gears: 12 bolt w/4.10 gears
I have a slightly used Centerforce dual friction pressure plate and clutch setup for the T56. Part number DF039020. It sells new through Summit for $610. I'm looking for $250. The two photos show that the disc has quite a bit of pad left on each side. PM if you're interested. Thanks.
Well, I just noticed that you are putting this behind a 2-piece rear block. This setup is for the flywheel on a 1-piece block. I don't think it'll work for your situation.
Old Oct 29, 2008 | 04:46 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
pm me if you still need pedals.-art
88SS6SPEED
Nov 11, 2015 07:05 AM
tonys91rs
Oct 10, 2015 03:31 PM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
