140mph gauge cluster (2) firebird 1986
Old Oct 21, 2008 | 04:14 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Transmission: gto t56 (mn12)
Selling two 1986 Firebird 140mph gauge clusters. They are both compatible with electric speedos. The first one is in great shape asking $30 plus shipping.
The second one is in ok shape. The glass has a small crack on the right side. Other than that good condition. Asking $20 plus shipping.
Old Oct 22, 2008 | 05:40 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Re: 140mph gauge cluster (2) firebird 1986
to the top
Old Oct 23, 2008 | 09:21 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
top side
Old Oct 23, 2008 | 09:49 PM
CAM_231's Avatar
Car: 87 Pontiac Firebird
Engine: Carbed LO5
Axle/Gears: 2.73 non-posi
PM Sent.
Old Oct 24, 2008 | 06:34 AM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Cluster with a crack is sold. One more to go.
Old Oct 26, 2008 | 08:27 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
to the ebay
Old Oct 26, 2008 | 08:54 PM
Stippy17's Avatar
Car: 1986 Trans Am, 1985 Trans Am
Engine: 400 SBC, H.O. 305
Transmission: TH400, 700R4
Axle/Gears: 10 Bolt/3.73s, 10 Bolt/3.73s
If you already put it on Ebay can you give me the url for the auction? Im looking for a V8 Cluster for my Swap.
Old Oct 26, 2008 | 10:18 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
http://cgi.ebay.com/ebaymotors/1982-...mZ200267548388
Old Oct 26, 2008 | 10:33 PM
Stippy17's Avatar
Thanks. What do you mean by Electronic Speedometer?
Old Oct 27, 2008 | 06:52 AM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Some gauges accpet a mechanical speedometer instead of the electronic speedo. All the firebirds I have owned run a wire from the trans to the gauge cluster that relays your speed. Some firebirds run a mechanical cable from the trans to the gauge instead. I am not 100% sure but if you have a mechanical cable originally I don't think you can swap to this one.
Old Oct 28, 2008 | 02:18 PM
Stippy17's Avatar
Probable need one thats mechanical then, Im going with a TH400 Tranny. :/
Old Oct 28, 2008 | 05:24 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
It all depends on what the trans you are using has. Some can be adapted to use the speed sensor. Some need a new tailshaft housing. It all depends on what you have. Im uncertain of the th400's.
Old Oct 29, 2008 | 12:38 PM
igotmailed's Avatar
Car: 1983 Firebird SE
Engine: 305 5.0 V8
so how can we tell if our trans has a mechanical or electrical speed sensor....
I'm running a automatic turbo350 from an 1982 Camaro Berlinetta in a 83 firebird se. I bought this same cluster from ebay seller i just dont know what steps to install on SE that has original cluster no tach and has dummy temp lights
Old Oct 29, 2008 | 12:43 PM
igotmailed's Avatar
Engine: 305 5.0 V8
I guess i'll also have to change out oil and temp sending units. Is that correct? Dont even know where to start, does look like it just plugs and plays...nothing can be that easy!
Old Oct 29, 2008 | 01:06 PM
igotmailed's Avatar
Engine: 305 5.0 V8
ok found the answer to the cable...it's mechanical speedo cable
Old Oct 31, 2008 | 06:22 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Yea you can tell by looking at the back of your cluster. I guess you already got the answer you needed though.
Old Oct 31, 2008 | 09:19 PM
blackroc68's Avatar
It gos from the speed sender on the tranny to a buffer box then to the speedometer
Old Nov 3, 2008 | 12:42 PM
igotmailed's Avatar
Engine: 305 5.0 V8
since the original is from the 1983 that had dummy lights what is required to have the 86 cluster installed....will i need new sending units for the temp and oil, are there an other necessary wiring or custom pieces i'll need...any info would be appreciated thanks again for ur help
Peace
Old Nov 3, 2008 | 06:44 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Sold on ebay for $5.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
