LS1 and T56, plus other parts
I need to get this stuff sold so I can get another vehicle. If you feel the price is too high, do not be afraid to shoot me an offer. There is a reason why it says "obo". Please don't ask me what my bottom dollar is, because I'll tell you to read the ad.
LS1/T56 setup, I do not wish to seperate the following parts - $4500 obo:
2000 Camaro SS LS1 Engine
2000 Camaro SS T56 Transmission
2000 Camaro SS LS1 ECU, tuned
2000 Camaro SS LS1 Engine Harness
Ported MAF Ends
Fluidamper Underdrive Harmonic Balancer
MSD 8.5mm plug wires
GMPP LS6 Camshaft
6.0L Exhaust Manifolds (currently not installed on the engine, but they do go with it)
LS2 Flywheel
LS2 Clutch and Pressure plate
B&M short throw shifter
Cold Air Intake setup
9" K&N Conical Filter
2000 Camaro Clutch master cylinder
Braided line from master to slave
2000 Camaro brake and clutch pedal assembly
2000 Camaro brake booster and master cylinder assembly
2000 Camaro dual electric fan setup
Everything else:
2000 Camaro rearend, 3.73 gears, complete disc-to-disc - $300
2000 Camaro fuel tank, 255lph Walbro, complete with sending unit - $100
C5 Z06 wheels, 17x9.5/18x10.5, blacked out, tires are pretty worn - $600
Skulte wheel adapters, had them on the front of the car for the Z06 wheels - $100
Borla muffler with a portion of the over-axle pipe and SLP tips - $75
Custom made y-pipe, I spent $270 on this to clear the Spohn crossmember and to tie in with the 3" I pipe running to the muffler. - $150
82-92 dash pad, small crack on drivers side corner - $60
82-92 shifter bezel, with 6-spd logo applied - $40
82-92 center console, armrest cracked, everything else in good shape - $50
82-92 dash, great shape, no cracks not broken anywhere - $125
82-92 gauge cluster, 145mph speedo - $65
82-92 custom gauge bezel with all Autometer Ultralite gauges - $500
- 3 3/8" 200mph tach, setup for digital signal
- 3 3/8" 10k RPM tach
- 2 1/16" Fuel Level
- 2 1/16" Voltage
- 2 1/16" Oil Pressure 0-100
- 2 1/16" Water Temp 100-250
Pictures of all parts can be seen at:
http://s402.photobucket.com/albums/p...0Camaro%20Z28/
Ported MAF Ends
GMPP LS6 Camshaft
LS2 Flywheel
Everything else:
- 2 1/16" Voltage
Re: LS1 and T56, plus other parts
If I remember right, it weighs around 240lbs, I can check what freight charges will be for it.
If I don't get this stuff sold, it's going to find a new home in my '83 Capri RS. Please help me unload it :P
EDIT: According to UPS, almost $300 to ship it.
Car: 86 Z28
Engine: 385
Transmission: T5 (soon to be in pieces)
Axle/Gears: 3.73 POSI Disc
i belive there is a company called r&l cariers that will do it for around 140 (ups and fedex are always overpriced) if you could get it to me for 400 including shipping i would take it
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Highly interested in the '82-'92 shifter bezel. How is the boot on it?
Do you also have the rubber boot that mounts to the floor pan?
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Hey I asked you about the gauges a while back, but never got a response. Still interested in selling them?
Car: 1991 Camaro Z28
Engine: 305 LB9 5.0L
Axle/Gears: POSI 2.73
Hey saleen, did you ever get the engine dyno'd, if so could you post some numbers of it...how many miles are on the engine and tranny?
I never did get the engine dyno'd, I would estimate around 320whp in it's current form. There was ~75k on it when I got it, and I put another 8k on it, so I would say it's close to 90k miles on everything.
Engine: 355, 408
I'm interested in the complete set of autometer gauges, sending units and the panel that houses them. My zip is 12054, whats the best you can do shipped to my door?
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
how much to crate and ship the engine/trans setup to 98270
Car: 86 Z28
Engine: 385
ok sorry to bug you about it im just anxious to get rid of my stupid 2.77 open rear end when you got that qoute did they happen to say what terminal it would be shipping into?
Ok, got a new battery on the way to work this morning. Updated the pictures at http://s402.photobucket.com/albums/p...0Camaro%20Z28/
I do not remember what terminal it was going to come in at, however, I can check again. If you PM'ed me your zip code, I'll check when I get off work this afternoon.
bump TTT.
If this stuff is still here by income tax time, it's going into my '83 Capri RS. I know someone is looking for an LS1/T56 setup.
Car: '87 Camaro
Engine: Stock 88 roller 350 w/ nice heads
Car: 1987 Chevrolet Monte Carlo SS
Engine: ZZ4 - 350
Transmission: 700 - r4
Axle/Gears: 3.73 posi
Is just the tranny still available? Looking for a unit for my 87 Monte project. What is the low dollar w/ shipping to Spencer, MA 01562
If willing to seperate please get back to me
If interested please email @ zz4monte@charter.net
Thank you
Ron
Thank you
Ron
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
Would you be willing to do a trade for the autometer speedo? Cash + ultralite mech. 160 speedo for your elec. autometer speedo?
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
any interest in a running driving vehicle, in trade, for the stuff you didn't want to seperate?
namely the red t/a below in the sig
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Price shipped on the LS1 fuel tank /. pump to K7R3L1 ON, Canada? PM Me, thanks!
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Do still have the LS1 or the T56? Let me know, interested in both or separate.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Digging up threads that are 2 and 3 years old isn't going to get you the results you're after. If anything was a bargain, it's not going to be for sale 3 years later. Try finding some more recent threads, or go the tried & true route by contacting your local junk yard.
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
