[MD] 1991 R.S SUPERCHARGED F/S
350,Roller rockers arms,polished weiand 142 supercharger,600 cfm edelbrock carb. full msd ignition,pro billet distributor,msd 6 box. hooker comp. headers.new dynomax cat back. polished aluminum radiator with new 160 t-stat. recently rebuilt auto trans "700r-4" b&m ratchet shifter. newer paints, black metallic with 4 inch cowl induction hood."fiberglass" 17" iroc look a likes near new, very nice chrome wheels. tires are about 80% as well. kumho's. new carpet inside,new heater core,new front poly. sway bar mounts,and end links. also has a new battery. there is a little tear in the side of the drivers seat, and the dash pad has some cracks,the car needs a new idler arm, and some rear brake pads. it runs very good. i was told when i bought the car he ran a 12.4 with it.
the car came from the south. very nice underneath,and everywhere for that matter. there is absolutly no rust anywhere. very nice car, with little bit more work. i already have a 4th gen camaro, and i want another bike,so this car has to go.otherwise it wouldnt be going anywhere. asking price of $5500 o.b.o. might consider trades for newer r-1,gsxr 1000, or hayabusa. thanks.
the car is located in western md, 21530 right outside cumberland md.
Car: 89 iroc
Engine: beefed 355 for now
Transmission: 700r4 for now
Re: 1991 R.S SUPERCHARGED F/S
if he only ran a 12.4 he sucks as a driver. i run low 12s high 11s with my built 355 no heades and no supercharger
couldnt tell ya, just what he told me. ive never taken a car down the track personally, so i dont know. he supposedly did this down south,dont know if that made any difference either.
sorry,i dont know whats going on, when i reposted, and then previewed,my first post,and these worked. what might be the problem? i pulling the pics off my email under hotmail, is this the problem?
anyways if you give me your email,ill just email you some pics.
anyways if you give me your email,ill just email you some pics. Trending Topics
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
No offence, but these pics are awful and don't really show the car much at all. Do you have a link to full size photo's??? Thanx, Nitro
hi,
im just learning this pic thing on the net. i have these on my photobucket site, is there a way to link you to them? or how can i post them here,where you can open them up to full size? sorry just trying to learn
Car: Used to drive a camaro
Goto to your photobucket album, look under the pictures you want to insert here. There are 3 or 4 fields below each pic. You want the one that say image link or direct link. Copy and paste that entire line here in your post. Good luck.
**Price is Way to High...
Take it down to about 3K and you might get some hits.
Also,
The car seems slow for what it is, how many miles are on the "rebuilt Motor"?
Why are you running a "600CFM" Carb on a fully built motor with a blower?
You need to run at least a Holley 750 Mechanial DP, and remove emmisions / Ac equipment. Will run better with that!
Also,
