[VA] converted lt1 intake for sbc, 24# injectors, 6.5" infinity speakers and some free stf
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
So i need this intake gone asap, it has been mildly ported and converted to fit our sbc's. I ran it on my old set up and picked up 4 tenths. The angle of the distributor is the same as on the tpi base,the way this one was modified it will fit heads that have egr ports. You will not be able to run egr due to the dist. coolant fittings are up front. $200 shipped to lower 48 states via ups
LT1 24# injectors $60 shipped
remote thermostat housing with neck $40 shipped
Re: converted lt1 intake for sbc, 24# injectors, 6.5" infinity speakers and some free
and i have 2 sets of infinity kappa series 6.5" speakers. they are 75w rms, $50 plus shipping per pair
FREE STUFF
I have a gta hood that is in pretty damn good shape, no grills. FREE. i will not ship so local pick up, im in Va 23111
I also have a strong running H.O. 305 that came out of my trans am, its a 1 pc rear, roller block, great shape less than 100k miles on it, no lifter or intake. great bottom end and heads, its been sitting in my shed for like 2 years. NO SHIPPING, Va 23111
I ACCEPT PAYPAL ONLY
FREE STUFF
PMs replied.
Hood is gone
Injectors<- Pending
Tstat housing<- Pending
****To the top****
Hood is gone
Injectors<- Pending
****To the top****
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
how much to pick up the intake?
to be clear, its a direct swap?
Yeah it is, you will need to modify your water lines and fuel lines. check out www.lt1intake.com for more info.
I can do 175 if you pick it up.
TSTAT HOUSING <- sold
to the top again
asdfjkl;
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
did the injectors sell?
everything is gone except for the intake 150 plus shipping takes it anyone??
everything is gone!!!
