Parting out '92 Z28 tpi 5-speed
Car: '87 GTA hardtop, '86 IROC hardtop
Engine: 385 DFI, 350 carb
Transmission: T-56, T-5
Axle/Gears: ls1 torsen 10-bolt, 9-bolt disc
(SOLD) Parting out '92 Z28 tpi 5-speed (SOLD)
CAR IS GONE, ALL PARTS SOLD. CLOSE THREAD.
I am parting out a '92 Z28 that I just purchased. It is an original 5-speed car and tpi. has a 5.7L tpi in it now. original 5.0 car. t-tops in good shape, interior is ok, but it has been outside for 2 months with pass window down and not covered. some console trim panels are missing or broken. car was hit in RF, front nose is wasted, pass fender and door are trashed, ground effects are junk on pass side from rear tire forward. has good hood and "blisters". car is teal in color. rear bumper cover is good, paint is faded. interior is gray and black. REAR SPOILER IS SOLD. good tail lights, engine runs real strong, no smoke, fires right up, idles smooth. serp belt setup, wheels look pretty good, clearcoat is starting to flake a little. rf has very small lip damage, rf wheel has some cosmetic damage, took to a shop and had them check for out of round. all ok, true and straight. have many many pictures on photobucket. e-mail for other parts, whole car must go. will not sell as whole, unless price is right. NO TITLE.
http://s592.photobucket.com/albums/t...bum_view_click
serp belt setup with all accessories and pulleys. no smog pump pulley. $150
too much other stuff. shipping extra for larger stuff.
sold stuff; wheels, rear spoiler, tpi setup and harness, cooling fans and harness, radiator, emblem on top of nose, driveshaft, rear diff, t-tops, engine and trans assy, tail lights, pedals, hydraulics for clutch, rear emblems, rocker emblem.
ALL PRICES ARE NEG, MAKE OFFER. VERY MOTIVATED SELLER.
Re: Parting out '92 Z28 tpi 5-speed
Good shape, no cracks or anything, paint is faded on bowtie, has 2 holes drilled in back of bottom for fog lights. $40 plus shipping. One other guy asked about it locally, if I do not hear back from him it is yours, if price is ok. Previous owner also drilled 3 small screws into bottom edge of panel, you can see in pic.
Do you want the little cover "door" that comes off to get to fuses or the entire cover panel for under the dash? $10 shipped for first, $20 shipped for second.
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I'm looking for the bracket holding the ECM under the dash on the passenger's side, IF the car has or had the 730 ECM.
From: Under the hood trying to find where the motor goes!
Car: 89GhostRS
Engine: SB
Axle/Gears: Ford 9/4:10
Luke J, where in Indiana are you located? I need lower spoilers front and dr/pass side as well.
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Would you be willing to mail me the TTop hooks that attach to the very rear of the car for $4?
CamaroRUS- that sounds fine, as long as they are mounted to the body. the t-tops are sold.
Tail lights are sold, interior is gray cloth.
bcfipp-I have pics of them, pm me your e-mail addy.
tonymemphis-pm sent.
Car: 1991 Z28
Engine: 383
Thanks, they are not on the ttops. They are the 4 brackets the ttop bag mounts to in the rear hatch area.
Two on the "top" inside the car above the fuel tank and 2 at the very rear of the car. I can try to find a pic if you need clarification.
I appreciate it a lot, whats your Paypal?
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Drivers Door only GFX piece.
Also, behind the door handle on the inside is a little black appearence piece, need one of them.
Shipping to 72116 bis, or 72120 home.
The gfx on the driver's door is the wrong one, you can see it in the pictures. It is off of an '87ish car. The door handle piece I do have.
Engine: 350 S-TPI
I didnt see that in the pictures. Sorry.
Door handle piece is not worth shipping alone.
Thanks for the response.
Car: 1991 Z28
Engine: 383
Luke, I sent pmt a couple days ago. Did you have a chance to get the pieces shipped?
Sorry, I thought I replied to you already. I am shipping out today.
Car: 91 Red RS vert, 95 Silver B4C
Engine: 355 cubic inch, 350 LT1
Transmission: T56, T56
Axle/Gears: 3.42, 3.42
Have you sold the clutch and brake pedals? Is the shifter trim plate and shift bootfor sale? How much to 60435.
Car: 1992 Camaro "SS Z03"
Engine: 383 Stroker
Transmission: '96 1LE T-56
Axle/Gears: Borg-Warner 9-bolt
Hi, what shape are the carpet sides on the center console? It looked good on the drivers side. Cost and shipping to 33050, Florida? Thank you!
Only thing left is serp setup and some interior parts.
Car: 1992 25th Ann. Z28
Engine: 5.7 TPI - Stock
Transmission: th700 r4
Here are a cple things I need if u have them
Lower driver side GFX
Fuel tank
How much shipped to 77373?
Fuel tank
Actually, I got a better look at the gfx. It has some damage, If you want it, just pay for shipping. I will get some pics for you if you want.
I will check, but don't get your hopes up.
1992rs/ss
Jan 31, 2025 05:10 PM
Sanjay
Aug 12, 2015 03:41 PM
