[IN] garage cleanout! must go, and looking for parts in trade(UPDATED) LINK TO PICS!!!!!
Old Sep 7, 2009 | 10:27 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
I have many many 82-92 (few 93-02) camaro and firebird parts from cars ive dissassembled over the years and its time to clean out the garage. including
many interior trim pieces
82-92 camaro fenders $50 each
82-92 firebird drivers side fender $50
85-92 camaro z28 hood with provisions for blisters or louvers (not included) great shape $75
pair of iroc hood louvers, missing tabs so ill let them both go for $40
hatch motors: 1 early style, and 2 92 style $45 each or 50 shipped
blower motors $20 each or 25 shipped
ac delete heater box $ 100 shipped
red lower console $40
manual trans shifter plates $55 shipped
lower trans shifter boots $25 shipped
crossmembers for 700r4 or t5 $25
driveshafts (both stock and aluminum) $40 for a steel shaft/$125 for a aluminum shaft
interior plastics in black and red
4th gen black/grey 4th gen seats. no significant damage, good bolsters, front and rear seats. No front tracks, but you would use your existing tracks from a 3rd or 4th gen as they are the same and are a direct bolt in. Only reason im selling is i bought a set of sparco buckets. Same reason im holding onto the tracks $250/set
clutch pedals for ls1 style t56 $50
89 camaro engine harness, and light harness. basically the complete harness for underhood all the way to the firewall and to the computer $60
87 iroc 305 carb auto ecm $40
89 iroc 305 tbi auto ecm $40
serpentine belt engine brackets $60
ac compressor for serpentine car in working order, no clutch noise $50
smog pump for serpentine car $30
ac condensor with lines for a serpentine car. car had a charge when removed $75
radiator $75
single electric fan assembly $75
camaro drivers side quarter panel complete and no rust $100
seat belt assemblys in black color
lots of under car plastic pieces for the front end
chin spoiler 85-90 z28/iroc/rs style $50
side rocker ground effects 85-90 style rs/z28/iroc $25/side 91-92 z28/rs $30/side
camaro rear bumper covers 85-90 style rs/z28/iroc $50 each 91-92 z28/rs style $60
set of used edelbrock valve covers $20 can have finish sandblasted for additional $10 for perimeter bolt heads
th350 trans mounted torque arm bracket $30
torque arm assemblys $20 for non g92 setup (have holes in center) $50 for g92 solid torque arm with a poly bushing $60
brake master cylinders $25 each
brake boosters $25 each
grid style taillight assemblies $20 each or 35/pr
early style coolant bottle (will work on all) like new (used for less than 200 miles) $20 or $30 shipped
ls1 exhaust manifolds $40
ls1 heads 853 casting with valves and springs, no retainers 30k miles $60
underdash covers and kick panels
low tension hood shocks (good for cowl hoods, or any aftermarket lighter hood) $50
good hatch shocks $40
horns $20 or 25 shipped
fan mounting brackets
tpi lower airboxes $30
fuel doors $10 each
clutch resevoir with hose to master $20
dash bezel covers
6 350tpi injectors $25
oem roller lifters with dogbones and spider $50
front license plate holder $15
rear trunk weatherstripping $20
third brake light assemblies
black sun visors in good shape for a hardtop car (will work in either) fabric not sagging, and they stayed in place in the car $40 or 45 shipped
taillight wiring harness $20
strut mounts $20
tbi/carb air cleaner with hose $30
used firestone firehawk sz50 ep 245/50/16 tire $25
automatic pedal assembly $30 or $40 shipped
ttop glass
wiper motors $25 or $35 shipped
93 z28 150 mph speedo cluster $60
big brake upgrade parts
98-02 front calipers $75 or $80 shipped
firebird/trans am dash map pocket good shape, doesnt hang open $40
2 gold dimpled style gta 16x8 wheels. good shape, no significant damage. Lightest factory thirdgen wheel, perfect for drag radials $125 can ship also
im sure
all pictures can be seen at this link 13 pages of photos
parts for sale pictures by randy87iroc - Photobucket
I am not a business, merely a thirdgen fanatic who has personally owned all of the cars these parts have came off of. I have accumulated these parts over the years and its time for them to go so i can have garage room. Im sure there are pieces not listed up there that i have or that i have pictures of. If you dont see it, just ask, alot of the small miniscule stuff is the stuff sometimes forgotten
if there is a shipped price, it is for the continetal US only
located on the southside of indianapolis for pickup, can meet or deliver for fuel compensation (reasonable distance), or can ship at buyers expense
email: streetracer420@hotmail.com or randyirocz@aol.com
ask for randy
thanks and have a great day
Old Sep 11, 2009 | 02:53 PM
Rocket-Doc's Avatar
Car: 1990 RS/SS modified
Engine: 355ci, 113 heads, LT4 hotcam
Axle/Gears: 3.73 Eaton posi
Re: garage cleanout! must go, and looking for parts in trade
Can I get pics of the serp brackets...
and could you take 75 shipped??
Would be purchasing as soon as I make sure they are the correct ones that I need...
Old Sep 11, 2009 | 09:43 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
due to their size i will decline on the shipped part. I can get pics, and a shipping quote if you would like
Randy
Old Sep 12, 2009 | 12:52 PM
kthxbai's Avatar
Car: 1985 Z28
Axle/Gears: fourth gen 3.42
can you grab a pic of one of the horns for me?
looking to wire one in
Old Sep 12, 2009 | 02:51 PM
spun350's Avatar
I'm looking for fuel lines for TPI Speed Density set-up - the two short ones that go up underneath the alternator that connect to the fuel rail. Also needing the mounts that hold the coil that bolt to the intake and distributor hold-down.Zip 72715Thanks!Spun350 !!!! I got the parts that i needed !!!!!!!!!!
Old Sep 12, 2009 | 04:00 PM
chevysquid's Avatar
Car: 1986 IROC T-TOP
Transmission: 700-R4
Do you have a rear bumper ground effect in good condition and is it feasable to ship one to Washington state?
Old Sep 22, 2009 | 10:13 PM
fergus's Avatar
Car: Project: 92 RS Camaro
Engine: 305 to 400RA3 Pontiac 400
Transmission: T5 to T56
Axle/Gears: 3:42 Detroit Tru Track
I need the doors, what shape are they in? Also I need a 92 chin spoiler. Where are you in Indiana?
Old Sep 22, 2009 | 10:39 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
no 91-92 chin spoilers.
i still have the doors, they are in good shape, no rust issues other than just needing to be painted to match whatever you may have. white in color
im pretty much right in indianapolis indiana.
Old Sep 23, 2009 | 08:26 AM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
is the starter good? do you have an automatic shifter w cable and shifter plate?
Old Sep 23, 2009 | 12:05 PM
fergus's Avatar
I want them. PM sent.
Old Sep 23, 2009 | 12:24 PM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
how much for the antenna shipped to 75228
Old Sep 24, 2009 | 01:36 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
yes the starter is good. came off a running car just sold the engine.
im sure i can scrape up a shifter plate, shifter and cable... what year car do you have (yellow letter or white?)
Old Sep 24, 2009 | 02:21 AM
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
you have a PM
Old Sep 24, 2009 | 01:46 PM
Engine: Built ls1
Axle/Gears: 3:42
I will take the starter, shipping is 11725. i have a 91 rs, i will just need the shifter plate if you have one in really good condition, no cracks or broken tabs.
Old Sep 24, 2009 | 03:09 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
You have a PM.
Old Sep 25, 2009 | 12:58 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
i think it can fit in a large flat rate box so 15 would do it... doesnt matter the weight if it it can fit in the box.
streetracer420@hotmail.com is my paypal for the starter.
the only yellow shifter plate i have has a crack... sorry. definately have a few manual ones though
Randy
Old Sep 25, 2009 | 03:44 AM
kmann101's Avatar
Car: 1984 Pontiac Trans Am
Axle/Gears: stock, for now
I need the door panels still got em any pics I'm up if fort wayne possible pick up
Old Sep 25, 2009 | 05:50 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
yes both sets are available, please specify which ones you are wanting
Old Sep 25, 2009 | 06:45 PM
kmann101's Avatar
some pics of both sets would be great not sure yet
Old Sep 25, 2009 | 10:19 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
all parts that i have pictures of now are available for viewing at the link below. I update this link with new parts every time i snap a pic or sell something.
http://smg.photobucket.com/albums/v3...%20for%20sale/
Old Sep 26, 2009 | 08:35 AM
kmann101's Avatar
looks like I will take the cloth door panels please call 260-580-9985
Old Sep 27, 2009 | 02:26 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Any pics of the rearview mirror yet? TTT
Old Sep 30, 2009 | 02:05 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
ttt
Old Oct 1, 2009 | 12:49 AM
rv34's Avatar
Car: 1992 Trans Am
Transmission: M21
Axle/Gears: 3.70 9 bolt
Looking for a Dash pad for my firebird..I have trans am wheels, I have to grab a pic. How much for a heater box?
Old Oct 1, 2009 | 12:52 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
pm sent
Old Oct 1, 2009 | 01:03 AM
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: garage cleanout! must go, and looking for parts in trade(UPDATED) LINK TO PICS!!!
how much are you asking for the hood blisters shiiped? and do they come with the mounting tabs>
Old Oct 1, 2009 | 01:22 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
hood blisters are 125. send me your zip code again. shouldnt be too much id say no more than 20 bucks. Yes all the mounting tabs are there and intact. not missing
Old Oct 1, 2009 | 01:37 AM
kmann101's Avatar
Randy I am still looking for door panels how much for the pair of black/ grey cloth shipped up to fort wayne
Old Oct 1, 2009 | 01:50 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
they arent cheap to ship really, plus you pretty much have to buy a box big enough to ship them in. Since you are closer id think it would be cheaper to get them personally
Old Oct 1, 2009 | 01:55 AM
kmann101's Avatar
give me a call and lets talk details # sent in pm
Old Oct 1, 2009 | 01:24 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
What brake upgrades do you have
Old Oct 1, 2009 | 08:03 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
i basically have a complete ls1 front brake upgrade kit spindles, hubs, pads, rotors, calipers, brackets, hoses.
Old Oct 1, 2009 | 08:27 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Do you have a direct bolt or would i have to get some custom work
Old Oct 1, 2009 | 10:21 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
its a bolt in
Old Oct 1, 2009 | 10:33 PM
basiccamaro's Avatar
What year or years does the chin spoiler fit? Thanks!
Old Oct 1, 2009 | 11:01 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
85-90
Old Oct 1, 2009 | 11:30 PM
1b rock's Avatar
Transmission: a4
how much for the iroc wheels and hatch motor shipped to 62970 and will you sell two rear wheels or just set
Old Oct 2, 2009 | 12:12 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
i really dont want to part the set since i have no use for them. i stripped the faces of 3 wheels and was working on the 4. i only want 100 for the wheels.
what year hatch motor do you need? i can get a shipping quote tomorrow
Old Oct 2, 2009 | 10:47 AM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
how much for an ac delete heater box, and shipping to 65301? thanks
Old Oct 2, 2009 | 11:52 AM
GREAT_WHITE's Avatar
Originally Posted by randy87iroc
all parts can be viewed at this link.... if the pictures are there, most likely its for sale. DONT SEE A PRICE PLEASE ASK. ALL has to go
please if you see something that doenst have a price pm me or email me.... it would take hours to figure out pricing on everything.
doors $75 each
fenders $50 each
hoods
louvers
blisters
hatch motors
fog lamps
blower motors,
ac delete heater boxes
console
crossmembers (both stock and aftermarket for t56 conversion)
rear 93-02 camaro firebird seats
door panels
underhood wiring harnesses for carb and throttle body cars
computers
serpentine belt assemblys
ac compressors
smog pumps
ac condensor
radiator
radiator fan assemblys
chin spoiler $50
firebird driver fender $50
camaro fenders $50
camaro ground effects (both 85-90 and 91-92)
rear camaro bumper covers (both 85-90 and 91-92)
tpi throttle bodies
brake boosters
washer fluid and antifreeze bottles new and used
ls1 heads
hood hinges
good like new hood shocks
good hatch shocks
horns $15/pr
fan mounting brackets $15
tpi lower airboxes $25
fuel doors $15
clutch resevoir $20
iroc wonderbar $40
dash bezel covers $15
black rear carpet $75
6 350tpi injectors $30
oem roller lifters with dogbones $50
rear trunk weatherstripping $25
third brake light assemblies $20
black sun visors $35
headlight wiring harness $20
strut mounts
tbi air cleaner $25
automatic pedal assembly $20
ttop glass
wiper motors $25
15" iroc-z wheels $100
speedometer clusters
wheel spacers
emblems.
LOOKING FOR TWO FRONT DIMPLED GTA WHEELS THAT WOULD BE CONSIDERED IN TRADE FOR THINGS I HAVE!!!
please post up or pm for a price, all parts are ready to be packed and shipped or picked up
thanks guys!
NO PRICE ON THE WHEEL SPACERS ? ARE THEY ALL THE SAME ? SIZE ?
Old Oct 2, 2009 | 08:10 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
85 shipped for the delete box and motor.
Old Oct 2, 2009 | 08:11 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
2 1 1/4 and 2 2"
60 shipped per pair
Old Oct 2, 2009 | 10:03 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
How much for the whole front brake upgrade kit then shipped to 90650 and can you send me some pics please
Old Oct 2, 2009 | 10:22 PM
1b rock's Avatar
Transmission: a4
my car is a 90 iroc with pull down hatch
Old Oct 3, 2009 | 09:44 AM
2 1 1/4 and 2 2"
60 shipped per pair
60.00 FOR ALL ?
HAVE TO ASK
Old Oct 3, 2009 | 12:32 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
You said you only want $100 for the iroc wheels can you check shipping to 90650 i am looking for some if its not too much for shipping i will take them
Old Oct 3, 2009 | 11:17 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
the whole front upgrade kit is pending local pickup.
Old Oct 3, 2009 | 11:18 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
these are also pending pickup tomorrow, if they dont go typically i can get wheels shipped at about 20 a piece
Old Oct 3, 2009 | 11:20 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
60.00 FOR ALL ?
HAVE TO ASK
no thanks.
doesnt hurt to ask though.
the 2" spacers only have maybe 100 miles on them... those alone costed more than what you offered
Old Oct 3, 2009 | 11:21 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
pretty sure i have one... all the hatch motors i have are in the pics... any of them look like yours??
