[NY] Berlinetta DIGITAL Parts and dark blue interior
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Selling off all of my berlinetta stuff. Would like to hold onto it but it's useless as i only plan on having two cars and i just picked up a 1992 Heritage RS so here goes.
4bbl V8 Digital Gauge cluster, everything works
http://i283.photobucket.com/albums/k...bblV8Dash1.jpg
http://i283.photobucket.com/albums/k...bblV8Dash2.jpg
http://i283.photobucket.com/albums/k...104091639b.jpg
It says error in the first picture and shows the tach like it does in the second pictures because i have it plugged into a v6 car, so the tach signal is wrong for the dash, so thats why it's displaying what it is with a confused signal. Shows 52,761 Miles!! All features of the dash work as they should. Came out of an '85 or '86, can't remember. Oil pressure is shown as 0-60, and the tach is lower redline than the v6 cars. $100
MPFI v6 Digital Gauge Cluster, everything works
http://i283.photobucket.com/albums/k...PFIV6Dash1.jpg
http://i283.photobucket.com/albums/k...PFIV6Dash2.jpg
http://i283.photobucket.com/albums/k...1104091639.jpg
Everything works as it should. Even worked being plugged into an '84 harness that was carbureted. Dash came out of an '86. Shows 117,935 miles. Oil pressure is 0-80 with higher redline than the 2bbl v6 dash and the v8 dash. $75
2bbl V6 Digital Gauge Cluster. Everything did work, put the wrong size fuse in and it then went dim, never came to full brightness. Plugged it in yesterday and the displays didn't show anything. Unclear of the condition, but was and still is good for rebuild. Had ~125,000 Miles on it. Someone with circuit knowledge could bring this unit back. $25
http://i283.photobucket.com/albums/k...104091639a.jpg
Headlight pods. Have two available. Everything works except i can't get the turn signal lever to activate. They did work until i let the car sit and i have a feeling the mice in the car ate the rest of the harness. One turn signal lever is kinda loose, the other one is tight and responsive and springs back perfectly. I do believe these will work with no problem, just think my donor car is defective. Everything else on the units work without a problem including 4 way hazards. $50 each.
http://i283.photobucket.com/albums/k...dlightPods.jpg
Wiper/HVAC pods. Everything works on the units. Three available. $50 each.
http://i283.photobucket.com/albums/k...r-HVACPods.jpg
Radio Pods. Radios work nicely, tape decks are shot. One of them the tape deck activated and then stopped, so that one probably has promise of an easy rebuild. Have three of these available, only one of them is missing the face of the tape deck unit. $40 each, $25 for the one missing the tape deck face.
http://i283.photobucket.com/albums/k...out/Radios.jpg
Radio pod bases. All of them work perfectly. At least three available. $25 a piece.
http://i283.photobucket.com/albums/k...oBaseUnits.jpg
Headlight control modules (mounted against the ECU). Have at least two available. One is perfect to my knowledge, one, the interior lights don't light up, gotta check the relay to see if it's a simple fix, and the third one i haven't tested yet. $50 each.
2 berlinetta specific wiper motors, 2 for the price of one, as one is unknown status and one is known working when pulled. $40 for both.
Berlinetta Specific Grill $25 for both pieces, perfect condition. Non-Fog Lights.
Berlinetta specific front parking lights for 84, $50 for the pair. Perfect condition.
Two sets of berlinetta tail lights, $50 per set, both excellent shape.
Two berlinetta dashes, one 84 and one 86, with the new improved ball bearings to help the pods move smoother. $50 per dash.
Two berlinetta center consoles, one carmine red from an '86 and one from this '84, dark blue. Have one shifter panel assembly available. $50 complete, $30 without shifter panel.
Complete set of gold Berlinetta wheels, $25 a piece, $75 for the whole set, and as per the set, it includes the two center caps i have.
Also have one gray LT wheel if interested. $25 as well.
Berlinetta Badge kits (both missing front bumper emblem). Have an '84 set and an '86 set, both fender emblems, both sail panel emblems, and the rear bumper emblem. All in excellent shape. '84 set is made of metal! $50 per set.
2 berlinetta steering columns, one with an '84 horn button and one with an '86 horn button. Work perfectly with tilt. $50 each.
Interior or engine bay harness is available. Need to know asap on this otherwise it's getting taken to the yard. $25 for everything to a 84 2bbl v6 car including ECU.
Dark blue interior plastics, carpet, sun visors, seat belts, ect are all available.
T-Tops and front and rear bumper are the only things not rusted on the car. This is what's left:
Let me know what you're interested in. All prices are before shipping, but I will combine shipping, and all prices are "or best offer," so make me an offer, especially if you want to combine and take more than one item. If you want all digital parts i can set up a deal for that too just to get rid of it in one shot. All parts will be tested to the best of my ability before shipment to confirm condition. May have a few more parts so i will be making updates to this if i find things. Looking to move these hard to find parts, and not looking for a pot of gold, so feel free to make offers. Anything else i can help you with, let me know! Thanks for looking.
Jon
Jon
Re: Berlinetta DIGITAL Parts and dark blue interior
I do not mind sending one to Australia for you providing you pay all the shipping charges incurred. If you would like any other parts, let me know and i will see what i can do for you. Shipping on a box less than 5 pounds appears to be about $50 to Australia unless i can fit it into an international flat rate box, then the cost goes down a little bit. I will have to look into this to see if it's the same as the regular flat rate boxes we have for domestic shipments. Priority international is 6-10 days unless you are interested in Express, which is $55, and it says that it should be there in 5 days. Let me know which means to shipping you are interested in and i can go from there. I do accept paypal to make this quick and easy for both of us. Thanks for your interest.
Jon
Jon
Seats are spoken for, everything else is available, let me know what you need. A couple sets of Berlinetta Tail Lights, 82-84 front and rear berlinetta bumpers, door skins look to be in perfect shape, defrost glass, you name it, it has it. Feel free to ask.
TTT, everything just about available!
Not a problem. Did both work after all that? Just wondering, curious if my harness was the problem or if it was actually the motor. Thanks again though and have a happy and safe holidays!
Car: VR6 jetta for commuting
Engine: VR6
Transmission: 5spd ZF lsd
Axle/Gears: ?
i need a blower motor resistor for my 84 z/28 do you ahve one that works?
I will have to check on that, i'm not sure if the resistor is the same for a berlinetta as a standard z28, but when the car was one piece, the blower did have all four functions of fan strength. I can pull it for you when i go back, but if you can make sure it's the same part at a parts store, then i would feel more confortable. $10 shipped unless your in upstate new york, we might be able to set up something. Thanks.
Jon
Jon
What condition is the carpet in and how much?
The set of the gold Berlinetta wheels come with all four for $75
Could you get pics thanks.
Carpet is now filled down with metal going to the scrap yard, so no good on the carpet. The set of berlinetta wheels is $75 for the complete set yes. I will try and get pictures soon, i should be by the shop later this week. I will keep you informed.
Berlinetta Tail lights with the gold bars are sold, but i do have a set of standard camaro tail lights with the black center bar. Let me know if you are interested.
Doors are rotted out, and i do believe i have a few light modules. Let me know zip codes.
Bringing this back, still have many parts, just sold the V8 cluster, sold the V6 cluster, only have the parts cluster available. Have many parts, all organized and put together, will be able to get these parts out fast! Light modules, headlight pods, climate pods, upper radios, dashes, center consoles, hard top overhead console, interior harness, badges, ect.
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
84redta is great person to buy from, gives an honest decription and great prices.
Thank you for the kind words.
Car: 1984 camaro berlinetta
Axle/Gears: 3.08
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
Is the blue interior good yet? I need some pieces..
email me pics and prices, kyle122591 @ gmail.com
can you send a photo showing the condition of the 2 grill pieces if there still available?
I'm interested those. you can post it here or I can private message my email if that works. thanks
Hey guys, sorry I've never responded, it never told me anyone was posting. I have light modules still I believe. Blue interior I belive is gone but I still have the locking cargo tray. Dash board I belive I had just gotten rid of this past summer. I still have radios and hvac and lighting pods, and lastly the grills I believe are gone, but I will check for you. I'm out of town right now and for the coming week, back next weekend, I'll check on the grills.
I'd have to check, business meeting for the week so I'm in Washington right now, will check when I get back.
Car: 96 Impala 84 berlinetta
Transmission: 4speed auto
I am looking for the hvac pod 1226879. my 84 berlinetta ac control pod intermittent on its operation then died total. any chance you still have it ?
email catrains2@hotmail.com thanks..
The_Phoenix
Feb 4, 2016 07:10 AM
Linson
Aug 21, 2015 02:12 PM
