[IL] Cleaning out garage....
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Set of 186 heads, these are the original 68-72 "power-pack" heads. 1.94/1.50 valves. Completely stock and unmolested. $450.00
Set of ported 416 heads, these have 1.94/1.50 valves. These heads come complete with 981 CC valve springs with steel 7 degree locks and retainers. $400.00
Holley 650 DP choke horn has been milled off. $150.00
Weiand 7546 single plane intake $90.00 SOLD
(6) KB144 pistons These are a .030" 305 dome pistons they will come with a set of 5.7 stock rods still attached. $125.00
Black G-Force 5pt harness latch link $40.00 PENDING
Right interior arm rest $15.00 SOLD
Left interior arm rest $15.00 SOLD
Radio/HVAC bezel from 1984 $10.00
981 CC Valve Springs $20.00 These have break-in time only on a test stand.
(2) TH350's both need rebuilt have both a 6" and 9" tailshaft. $75.00 ea Could sell with complete rebuild for the right price.
Check back as more parts will be added later.
All prices are before shipping!
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
Re: Cleaning out garage....
I will have to check to be exact, they have 2 seasons on them though.
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
Will have pics tomorrow
The 416's with intake and carb and a Lunati Voodoo (60103) pushed the car in sig to low 12's @ 108. Should be good for high 11's with a better convertor and gears.
Car: 89 IROC-Z28
Engine: LS1 "ASA"
Also, my sunvisors (t-top) fall down as I drive due to a worn out pin that the screw rotates on and the fabric as come loose, so now it sags. You wouldn't happen to have a pair of black t-top sunvisors, mounts and all, would you?
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
Pics......
http://i739.photobucket.com/albums/x...n/IMG_2850.jpg
http://i739.photobucket.com/albums/x...n/IMG_2849.jpg
All original mounting harware will be included as well
Car: 89 IROC-Z28
Engine: LS1 "ASA"
I am still waiting on pictures of both the left and right arm rests. I am in desperate need of good condition ones. Both mine have the glue dried and curled up, up off of the door panel.
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
pictures wouldn't load on the page for some reason the photo bucket links are for the armrests. If you can't get those to work let me know and I will email them to ya.
sailtexas186548
Feb 17, 2017 03:07 PM
WhteRbt
Sep 21, 2015 09:48 AM
[/IMG]
[/IMG]
[/IMG]
