lots of tpi stuff--harnesses--computers--everything
Car: 89 iroc/90 iroc conv./06 ram
Axle/Gears: 3.27/3.27/3.91
have lots of parts from different cars.
86 iroc
87 iroc
89 ta
88 formula
all tpi stuff.
86 iroc
87 iroc
89 ta
88 formula
all tpi stuff.
Car: 1986 Trans Am
Transmission: auto
Re: lots of tpi stuff--harnesses--computers--everything
I need the air diverter valve for a 86 with a carb. The top TEE fitting is really what I need. Let me know and I can send you a picture to see if it is the same.
thanks,
Greg
thanks,
Greg
Car: 89 RS Red
Engine: 2.8L
Thanks for the 7730 comp. I just thought of something else. On the bottom TPI Base where the valley pan is, there is another part to the TPI base. I am unsure of the name of this part. Can you help me with this part too?
i do have a 7730 computer from a 92 5.7 car. $110 shipped
Car: 89 RS Red
Engine: 2.8L
Sorry. I bought one about two days ago. That went into the wrong post. Do you have a Speed Density harness?
Car: 78 camaro, 91 camaro both rs's
Engine: 78 has tpi 355, 91 has stock 305
Transmission: 78 has 700r4, 91 has t5
Axle/Gears: 78-2.73,91-3.08
how about a 7165 memcal for a tpi 350?
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
im looking for 92 computer, harness, and anything else i would need to swap my car from tbi to stealth ram. could you help me out
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
How much for an engine harness for a 5.7? I have a carbed 350 in my 87 trans am and i want to switch back to fuel injection. I have the computer, just need the sensors and harness. Thanks.
Engine: 383 Stroker
Transmission: t-56
Is this maf or map? I got the car with the carb already on it and the owner gave me the computer, so im not sure which is which.
Thats not a bad price. How much would you charge for all sensors, harness, computer, injectors, and upper and lower intake?
its maf. map was 90-92. whats your zip?
Engine: 383 Stroker
Transmission: t-56
oh okay awesome!, i was wanting maf. its 39531.
Engine: 383 Stroker
Transmission: t-56
thats not bad! could you send me a pic? i just woul like to see the overall condition, id really appreicate it. my email is muchmoney67@yahoo.com
How much for the 89 Trans am harness? I need it. I have an 89 iroc, previous owner cut out the tpi harness and went carb. Thanks!
Want a title? Post!
Car: 89 IROC
Engine: 5.0
Transmission: T-5 WC
Axle/Gears: 3.08
I'm looking for a 1989 IROC proportioning valve for standard disc/drum setup.
im looking for the throttle cable bracket and the hold down that goes on top of the middle bolt for the runners and the intake tube that comes off of the tbi. and the bolts that hold the runners to the intake manifold thanks
the harness came off a running --driving car. it does have a few flaws. the 4 ground wires that bolt to the back of the block are cut and a plug is broke as shown in pic. 2 wires near a sensor is cut but i think it goes to the fans?
Car: F- Body 1988-GTA 5.7 Litre TPI
Engine: 350-TPI L98
Transmission: 4 speed auto Overdrive
Axle/Gears: 3.27:1 rear gears
My 88GTA, 350 TPI, auto, w/vatts is giving me error code 5-1 using key slot for error codes, manual reads this is "ecm" malfunction or something. I recently overcharged my battery leaking acid down to a relay operating fog lites shorting out fog lites, and fog dash switch lite. This is when computer began giving me this error code, I replaced these, and still get 5-1 error code, plus engine starts sometimes, and runs fine for a few minutes upto 30-50 minutes then just dies suddenly leaving me stranded. Also computer will not always enter diagnostic mode after inserting key in slots, flipping ignition on/off several times may get it on or I have to undo battery & reconnect it. Do you or anyone you know, have any clues why? I am guessing here the computer because of the error codes. But guess this relay maybe shorted something else? Not knowing what is actually causing this, maybe to change out computers? Do you have working computer for this, & what would you want? Or is there an easier way to verify / check this 1st? Any help here?
Engine: 383 Stroker
Transmission: t-56
i recieved the pics in my email. I already just bought a new intake and getting another carb, efi was just going to cost to much. Thanks for the time though. Have a nice day.
Engine: 350-TPI L98
My 88GTA, 350 TPI, auto, w/vatts is giving me error code 5-1 using key slot for error codes, manual reads this is "ecm" malfunction or something. I recently overcharged my battery leaking acid down to a relay operating fog lites shorting out fog lites, and fog dash switch lite. This is when computer began giving me this error code, I replaced these, and still get 5-1 error code, plus engine starts sometimes, and runs fine for a few minutes upto 30-50 minutes then just dies suddenly leaving me stranded. Also computer will not always enter diagnostic mode after inserting key in slots, flipping ignition on/off several times may get it on or I have to undo battery & reconnect it. Do you or anyone you know, have any clues why? I am guessing here the computer because of the error codes. Do you have working Computer for this, how much you want, 64503?
Car: '87 Vette C4
Engine: 400 + .040 = 409 ci
Transmission: 700R4 built
Axle/Gears: Dana 44 w/3.42's
I need an EGR vacuum solenoid ... it attaches to the thermostat housing on TPI motors ... e-mail me at hyclfl@aol.com
Car: 89 Chevy Camaro IROC-Z Convertible
Engine: 350 Corvette Heads bored .30
Axle/Gears: 2.77
I also am looking for a EGR vacuum solenoid.
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
I am looking for the air tube that goes to the cat converter, you got one?
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Possibly interested in a 165 ECM... PM me if you still have one and how much.
specifically, is there a TPI system from 89 with MAF but without the cold start injector? *fingers crossed*
Car: 1991 red Z/28
Transmission: T5 swap
