[OK] FS: Non-WC T5 Transmission, Flywheel,Clutch,Shifter
Old Apr 9, 2010 | 07:17 PM
MPIpowered4x4's Avatar
For Sale, Borg Warner T5, Non-world class, Confirmed by ID tag, Shifted great, New fluid, Rebuilt 2 yrs ago, Clutch is not very old either, ID numbers on tag are 1352-072, Elec Speed Sensor, p/n 14084168. Located in Oklahoma City Oklahoma, Will meet locally or a few miles away. Will ship as well on a pallet on your dime. I am converting to a TH350
You also get the Flywheel for 87+ Engines,Clutch that works great, it held with 400hp in front of it. Bell housing.
Picture is what you get.
Everything you see here, $250 plus shipping. There is a shipping company that would probably ship for $150.
Old Apr 9, 2010 | 07:41 PM
89fbirdformula's Avatar
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
Re: FS: Non-WC T5 Transmission, Flywheel,Clutch,Shifter
willing to sell trans seperate? to busy to look up the id number, but its a 26 spline V8 trans correct?
i only need the trans, no shifter/bell/ etc etc...
Old Apr 9, 2010 | 09:41 PM
yes, its 26 spline, v8 tranny according to the ID number, it came out of a 92 WS-6 firebird, I thought it was a World Class because of the year, but apparently the drivetrain in this car was changed. I put it in front of a 383 stroker for 50 miles, pulled the engine due to low oil pressure. I decided I needed more power, so a supercharger is going on it. The car had a 305 TPI, the VIN is the same.
Old Apr 9, 2010 | 11:11 PM
On Probation
PM sent back, it being behind a 383 kinda bothers me, i replied to your PM before reading this post...
Old Apr 12, 2010 | 10:11 AM
it was behind the 383 for like 20 miles during breakin, it was not abused, I pulled it out after this due to oil PSI problems, decided to put a supercharger on it.
Bump, Still for sale. I will seperate the bellhousing from the trans, flywheel and clutch can be sold together.
Old Apr 12, 2010 | 11:05 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Is the Flywheel a 16 lb. version for a 1 piece RMS? Is it an "original factory installed" flywheel for a 1987+ 305 TPI LB9 engine?
Old Apr 12, 2010 | 11:10 AM
It is for a 1 piece rear main seal. I used it in a vortec motor with no problems. it is the period correct flywheel.
Old Apr 17, 2010 | 07:15 PM
Transmission,Bellhousing, and hydraulics are Sold. Lightweight flywheel and clutch is stil for sale. $75 shipped to anywhere in the lower 48. Price is firm.
Old May 17, 2010 | 12:57 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Is the shifter available?
Old May 17, 2010 | 01:55 AM
PMed
Old May 17, 2010 | 11:17 AM
shifter is sold Still have clutch and flywheel.
'86 350
Oct 10, 2008 09:21 AM
ES87iroc
Mar 22, 2008 10:58 AM
ES87iroc
Mid-Atlantic Region
Mar 22, 2008 10:57 AM
maroon88iroc
Sep 20, 2007 02:29 AM
