[CA] 115mph and 145mph Camaro clusters
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
I have a set of camaro clusters. The 115mph cluster came out of my 89 camaro. Everything works. Im asking $50+shipping for it
145mph Cluster has been SOLD!!
The 145mph i bought awhile back wanting to do a cluster swap. Just never got around to doing it. I will let that go for $75+shipping. Please let me know
Thanks Very much
Joey J.
Thanks Very much
Joey J.
Car: Camaro RS/SS
Engine: 5.7 LS1
Re: 115mph and 145mph Camaro clusters
morning bump
Car: Camaro RS/SS
Engine: 5.7 LS1
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
really? I've only seen the 80psi gauge on v6 cars... all v8's are 60psi
I'm pretty sure that if you use a v6 tach on a v8 car, the tach will be off
Car: Camaro RS/SS
Engine: 5.7 LS1
The white sticker came like that. You right it did show only 60psi. The sticker just shows more lol
so it's a v6 sticker on a V8 tach? i'm glad I didn't buy it. I was thinking about it and I would have been disappointed
Car: Camaro RS/SS
Engine: 5.7 LS1
I don't know why you would of disappointed.... The tach is the same the only difference is that the oil pressure. Which if you look at it it's more over to one side. So if the v8 had 80psi it would be correct.
wrong. the tach is calibrated for a v8. it wouldnt work properly with a v6
Car: Camaro RS/SS
Engine: 5.7 LS1
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
the resistors are different for the two engines. they are only interchangable if you dont care about them working LOL
Engine: L03, LB9
as long as the RPM range is the same, when the Dizzy is reading a certain RPM(i.e. 1000) it should show up as 1000 on either tach because 1000 is in the same position on both tach's, and 1000 RPM is 1000 RPM in any motor, again just as long as the tach's match perfectly, if they dont match or if they were mechanical i could understand them not reading correctly
Car: Camaro RS/SS
Engine: 5.7 LS1
Car: 82 Z28
Engine: Vortec headed 350, lightly worked
Axle/Gears: LS style 7.5, torsen 3.42 disc
Put me in line for the 115 if all other guages work. If you can get a shipping quote to 65584, thanks.
Car: Camaro RS/SS
Engine: 5.7 LS1
Sale is pending on the 115mph cluster
Car: Camaro RS/SS
Engine: 5.7 LS1
115 mph cluster is Sold!!
Thanks everyone for looking!!
Joey J.
Joey J.
