[VA] F/S-Serpentine-SYS/alt/w-p/smog-pump
Old Jun 4, 2010 | 02:12 AM
Sinister87s's Avatar
Car: A cherry Yugo
(SOLD)
I'm selling my serpentine system I had on my t/a. This kit includes all the brackets/pulleys/bolts/new alt/alum-w-p/smog-pump and a/c delete pulley. When I purchased this kit I had all the pulleys and brackets ceramic coated so the finish would last unlike paint, it still looks great. I'm asking $300.00 for everything together. This would be a great buy for someone wanting to switch over from the older V/belt setup to the newer serpentine system.
The alternator is a Powermaster, part#47861, it's a 140/80A 12V, 3-wire OEM hookup, with less than 10 miles of use. This alternator can be used on serpentine systems or V/belt drives, Link below,
http://www.jegs.com/i/Powermaster/713/47861/10002/-1
The water pump is an aluminum Edelbrock Part #8881, that is in great condition with about 2500 miles along with the smog pump and a/c delete pulley.Link below,
http://www.summitracing.com/parts/EDL-8881/
I believe I purchased the A/C delete pulley from PACE, link below
http://paceperformance.com/index.asp...D&ProdID=36126
Old Jun 4, 2010 | 02:16 AM
Car: A cherry Yugo
Re: F/S-Serpentine-SYS/alt/w-p/smog-pump
Just wanted to add, that the a/c pulley and belt tensioner are painted. Also, the kit comes with the crank pulley which is not pictured, as it is still on the car.
Old Jun 4, 2010 | 03:45 PM
jvirocz's Avatar
do you have the ac unit
Old Jun 4, 2010 | 04:26 PM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Is it $300 for everything? Or just the bracket and pulleys?
I'm curious as to the price of the water pump?
Old Jun 5, 2010 | 12:15 AM
Car: A cherry Yugo
Yes, I still have the A/C comp, although its for a V/belt setup. My link below,
https://www.thirdgen.org/forums/engi...-c-comp-l.html
Old Jun 5, 2010 | 12:17 AM
Car: A cherry Yugo
Yes, $300.00 takes it all I'm going to wait a little while longer until I split up everything.
Old Jun 5, 2010 | 01:50 AM
Stangski09's Avatar
$300 for all of that?
Holy **** is that ever a fricken steal!
Really wish I had that money to spend. Damn!
Old Jun 6, 2010 | 12:34 AM
Car: A cherry Yugo
I agree stang, just wanted to add sale is pending on the system from another member.
Old Jun 6, 2010 | 02:18 AM
Stangski09's Avatar
I actually still can't get over that. Alternator and delete pulley alone is worth more than that!
Old Jun 8, 2010 | 11:22 PM
Car: A cherry Yugo
The system has been sold, thanks Clint.
