[CO] 350 engine, TH700 trans, q-jet carb, etc.
Old Jul 7, 2010 | 06:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The 350/TH700 is coming out for an LS1/4L60E swap. All of the engine/trans/carb stuff is available. If I haven't listed it, ask (reply, PM, email). All prices plus shipping. Parts requiring freight shipment, buyer must arrange and pay for shipping in advance - I will strap to a pallet and deliver to dock in the Denver metro area. Pick-up preferred.
Engine, ~30k miles since rebuild in 2005:
ZZ3 shortblock, 4-bolt main 638 casting, +.030" 12cc Speed Pro hyper pistons, stock size journals one-piece rear main seal steel crank, Pink rods, ARP rod bolts, balanced. ZZ4 cam & factory roller lifters, ZZ4 oil pump. Nothing but AMSOIL since break-in. $500 SOLD
Ported World 305 heads, 1.94"/1.50" valves, "Z28" springs. Requires centerbolt valve covers (perimeter bolt bosses ground off). I'd recommend new valve stem seals (radiator fan failure incident). World calls them 58cc, but the shop that did the valves said they cc'd closer to 64cc. $300 SOLD
ZZ4/GMPP spreadbore/squarebore intake manifold. Will accommodate EGR and hot air choke. Basically the same thing as an Edelbrock Performer EGR for '86-earlier. $60 SOLD
CC q-jet carb, '86 model, rebuilt in 2005, daily driven. DR rods. $150
L69 HO dual snorkel air cleaner. Has good ducts. Only the right scoop is HO, the left is LG4. $125 SOLD
CC carb distributor with MSD Coil. $40 {corrected coil brand}
'83 TH700R-4 transmission converted to 30 spline converter/pump. Shift kit (unknown brand, it was installed by the PO), refreshed in '05. Aluminum pan (uses stock-type filter). Nothing but AMSOIL ATF (w/axillary cooler) since the refresh. Has worked great in daily driving. $300. SOLD
Re-stalled 30-spline TH700 lock-up torque converter, stalled at 2300 behind a 305, 2500 behind the above 350. Nothing but AMSOIL ATF since being rebuilt/re-stalled. $65 SOLD
The accessories are the combination flat multi-groove belt for the alternator, V-belt for the rest. All parts are available, including brackets. AC currently works with R134 (only the AC compressor will be sold, I will need the condenser and evaporator for the LS1 swap). Make offer.
If you want pics, I'll try to post as the disassembly/removal progresses.
Old Jul 8, 2010 | 01:52 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: 350 engine, TH700 trans, q-jet carb, etc.
AAAAARRRRRGGGGGHHHHH!!!!!! Why do these great deals on engines ALWAYS have to be a half a continent away?!?! I'd be peeling off $100 bills if I didn't have to worry about some trucking company demolishing that short block before it got here. Wish I had more time. I'd take the ride. To top it all off, it was built by someone who knows what he's doing and/or won't try to pull a scam. Rats! PM sent anyways.
Old Jul 12, 2010 | 01:39 PM
five7kid's Avatar
I have a commitment to buy the shortblock, tranny and converter.
Add to the list:
350 knock sensor and module, $50.
Old Jul 18, 2010 | 08:06 PM
five7kid's Avatar
Awaiting payment on the dual snorkel. Have a nibble on the AC compressor.
Still lots of good stuff available.
Old Jul 20, 2010 | 10:47 AM
five7kid's Avatar
Dual snorkel sold.
Old Jul 20, 2010 | 11:16 AM
likeyoumeanit's Avatar
Car: 87 GTA
Transmission: soon to be t56
Axle/Gears: 3.73 posi
can you pm me a shipped price to 17601 for the intake manifold?
Old Jul 21, 2010 | 07:25 PM
five7kid's Avatar
Intake sold.
Old Jul 21, 2010 | 07:30 PM
five7kid's Avatar
Other parts to consider:
Carb throttle cable, good shape. $10 shipped U.S. Cont.
Plastic MAP vacuum line (often broken cracked, etc.), both connecting ends in good shape. $10 shipped U.S. Cont.
Old Jul 21, 2010 | 10:59 PM
five7kid's Avatar
I'll make you a bang-up deal on the heads - $300 shipped anywhere in the continental U.S. I'll include the chrome centerbolt valve covers I used (forgot to mention that stock valve covers don't fit - the gasket rails are too close together on the heads), and if you like, the roller tip 1.5:1 Elgin rockers I have used. Again, they should have new valve stem seals installed.
Old Jul 28, 2010 | 02:49 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Axle/Gears: Zexel Torsen 3.73, 28-spline mosers
Distributor still for sale? Is it new/rebuilt or original?
Old Jul 28, 2010 | 08:33 AM
five7kid's Avatar
The distributor is still available. It is a stock '86 LG4 with Accel 7-pin module with an MSD coil (large cap). The gear shows a little wear, but is serviceable.
Old Jul 29, 2010 | 08:29 PM
five7kid's Avatar
Shortblock, torque converter, transmission sold.
Still more stuff.
Old Aug 4, 2010 | 08:29 AM
astre421's Avatar
PM sent.
Old Aug 4, 2010 | 08:52 AM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
is the distributor still up 4 sell?...do u havepics?...
Old Aug 13, 2010 | 12:26 AM
five7kid's Avatar
My apologies, got tied up with other stuff.
I'll throw in the MSD wires (have center-bolt "Made-4-U" top-of-covers wire clamps) for an extra $15.
Jorlain
Aug 24, 2022 05:11 PM
theshackle
Sep 17, 2020 08:26 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
