High Performance engine/Third gen parts
Old Jul 16, 2010 | 07:16 AM
IROC86350's Avatar
Car: 1986 IROC-Z
Engine: 383 TPI
Transmission: 700R4 2500 stall
Axle/Gears: 3.70 Moser 9in
52mm BBK/Edelbrock Throttle body for TPI
https://www.thirdgen.org/forums/pict...ictureid=16479
https://www.thirdgen.org/forums/pict...ictureid=16478
Billet Centerbolt Tall valve covers
https://www.thirdgen.org/forums/pict...ictureid=15883
Billet timing chain cover
billet wire holders
Moroso Deep Oil Pan
https://www.thirdgen.org/forums/pict...ictureid=15876
https://www.thirdgen.org/forums/pict...ictureid=15875
TPI SET UP could be sold Complete. Runners and intake and plenum are all port matched, Billet goose neck, Adj FPR, FP gauge on rail.
https://www.thirdgen.org/forums/pict...ictureid=15897
8 Red injectors which i think are 30lb or 36lb ill have too look
2500-2800 stall converter for 700r4 Tranny
https://www.thirdgen.org/forums/pict...ictureid=15866
700r4 built to handle 300hp- No shipping- Repaired housing
Everything is open for GOOD OFFERS. NO LOW BALLERS. Thanks!
Old Jul 16, 2010 | 07:28 AM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Re: High Performance engine/Third gen parts
What make are the Siamese runners
Old Jul 16, 2010 | 08:39 AM
IROC86350's Avatar
Car: 1986 IROC-Z
Engine: 383 TPI
I'll check when I get home later.
Old Jul 19, 2010 | 06:03 AM
IROC86350's Avatar
Car: 1986 IROC-Z
Engine: 383 TPI
The runners only have B B on them...No name, No #. They do have the option for the egr valve and it is currently plugged. Lmk If you want them! Thanks, Kenny
Old Jul 19, 2010 | 06:11 AM
Twin_Turbo's Avatar
pic of valve covers?
Old Jul 20, 2010 | 06:45 AM
Mr. Notorious's Avatar
Is the ARP hardware used? Do you have a pic of the timing chain cover?
Old Jul 20, 2010 | 11:49 AM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Pictures? Will this work with a post 87 block?
How much shipped to 22602?
Old Jul 20, 2010 | 07:10 PM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Price with shipping on the torque converter?
Old Aug 4, 2010 | 12:23 PM
IROC86350's Avatar
Car: 1986 IROC-Z
Engine: 383 TPI
PMS SENT! TTT
Old Aug 4, 2010 | 05:53 PM
Steve Mack's Avatar
Car: 87 Iroc
What will you take for the runners?Thanks
Old Aug 4, 2010 | 08:26 PM
Pat Hall's Avatar
Btw, the runners are probably SLP's. They have a "BB" cast into them usually.
Old Aug 4, 2010 | 10:01 PM
johnny090881's Avatar
Car: IROC
Engine: 383
Transmission: T-5 manual transmission
Axle/Gears: 3.45
how much for the distributor and the coil? and also how many miles on them? Price on the 24 lbs injectors and miles as well, please
Old Aug 5, 2010 | 06:56 AM
chrisr0315's Avatar
Car: Hot Wheels
Engine: Stroker 383
What are you looking for on the 24 # injectors , C/B Valve covers to 80915
Old Aug 5, 2010 | 08:30 AM
IROC86350's Avatar
Car: 1986 IROC-Z
Engine: 383 TPI
Thanks Pat yes they do have a BB cast into them. PMS will be sent.
Old Aug 6, 2010 | 12:35 PM
IROC86350's Avatar
Car: 1986 IROC-Z
Engine: 383 TPI
Sale pending on DIST, COIL, and RUNNERS.
Old Aug 9, 2010 | 11:53 AM
chrisr0315's Avatar
Car: Hot Wheels
Engine: Stroker 383
do you have a price on the 24# inj. and centerbolt valvecovers
Old Aug 10, 2010 | 07:11 PM
IROC86350's Avatar
Car: 1986 IROC-Z
Engine: 383 TPI
Distributor and coil are sold! Thanks TGO!
Old Aug 18, 2010 | 01:06 PM
IROC86350's Avatar
Car: 1986 IROC-Z
Engine: 383 TPI
Bump
Old Aug 18, 2010 | 01:18 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
pm sent!
Old Aug 18, 2010 | 04:01 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Are you sure its an edelbrock throttle body? Edelbrock only shows a TB for the LT1s. Also please post prices, this isnt ebay. Thanks. LMK about the throttle body as Im in need of a 52 or 58mm
Old Aug 19, 2010 | 05:27 AM
IROC86350's Avatar
Car: 1986 IROC-Z
Engine: 383 TPI
Ill PM you back i wanna say its a BBK by edlebrock I'll verify when I get home. Thanks
Old Aug 19, 2010 | 07:41 PM
quadrage400's Avatar
Car: 83 Z28
Engine: 383 10.5-1 afr 195
Transmission: full manual 700r4 3600 stall
Axle/Gears: 12 bolt
What brand is the torque converter and what is the spline count.
Old Aug 25, 2010 | 08:41 AM
IROC86350's Avatar
Car: 1986 IROC-Z
Engine: 383 TPI
I'm not sure of the brand of the converter. It was installed by HI-TECH Transmission where im from. I just told him what I wanted and thats what he installed. There is no name on it either. It worked really good for me. I'll do a spline count tonight.
Old Aug 26, 2010 | 02:29 AM
xdsone's Avatar
i would like more info on 8 Red injectors and the
Old Aug 26, 2010 | 06:56 AM
Can you look into the timing chain cover for me? Pic? Make?
Old Sep 10, 2010 | 10:44 AM
IROC86350's Avatar
Car: 1986 IROC-Z
Engine: 383 TPI
24lb injectors sold!
If i havnt replied to your post im sorry! I'll look at my torque convert today and do a spline count. Ill take some pics of the red tops and get the PN.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Reddeath210
Oct 6, 2015 08:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
