[FL] Need 86 IROC t-top black parts
Old Aug 6, 2010 | 10:03 PM
dakotaram's Avatar
Car: '86 IROC-Z & '13 2SS/RS
Engine: LB9 TPI
Needed please :
STEERING WHEEL - DESPERATE!
Sun visors
Headliner and board
Black carpets
Window weatherstripping - inner and outer
Black upholsetery
Madrid Velour door panels
Shifter **** (auto)
If you have anything else in black....just PM me, I may need it too.
Thanks so much!
(also have a post in exterior parts)
Old Aug 7, 2010 | 03:49 AM
Superjustin13's Avatar
Re: Need 86 IROC t-top black parts
PM sent
Old Aug 8, 2010 | 09:37 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
you need the small square **** type, or the T handle type? i have one of both type **** handle assemblies, for auto trans.
i have a rear view mirror assembly also, a few of them actually.,
i have black pillar plastic trims for t tops from a camaro if you need those possibly?
i have many more parts also.
you or anyone else looking for anything then just let me know in PM or email or text me 217 671 7792 anytime
good luck!
Old Aug 8, 2010 | 07:43 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
PM sent
Old Aug 8, 2010 | 08:11 PM
dakotaram's Avatar
Engine: LB9 TPI
good luck!
Rearview mirror without maplights
Shifter **** is the round ball, with the push button on top. The big ball is cracked...
Old Aug 9, 2010 | 07:41 PM
dakotaram's Avatar
Engine: LB9 TPI
Originally Posted by dakotaram
Needed please :
Cargo carpet board (mine is warped?)
Thanks so much!
Well....guess the fiberboard was not warped after all. Lifted it to see what was up and low and behold the dumbs*it that had it before me decided to cut the sheetmetal and peel it back to replace the fuel pump instead of dropping the tank. Did they tack the metal back down??? NO, it just looks like a sardine can - that's all. Think they might have even left the o-ring/gasket off - it was tucked under the carpet hiding.
Anyways......
Anyone got any type of cool steering wheel too???
Forgot to put that on my list!
Old Aug 9, 2010 | 07:44 PM
Anyways......
I just emailed you with pictures, I also have a steering wheel depending on your interior
heres a picture of it too.
http://s4.photobucket.com/albums/y11...3.jpg&newest=1
theres the wheel.
i got quite a bit for sale, steering wheel is new too
check your email
Old Aug 9, 2010 | 08:41 PM
RCAR7395's Avatar
From: South Bend Indiana iphone CALL OR TXT 574-607-2389
Car: 2003 GMC 2500HD Sierra Pickup
Engine: 6.0 Vortech
Transmission: 4x4
Needed please :
Rearview mirror
Sun visors
Headliner and board
Door sills
Dash pad
Console pad
Front seatbelt receivers
Shifter **** (auto)
Passenger side air vents
Thanks so much!
Pm sent
Old Aug 22, 2010 | 08:09 PM
RCAR7395's Avatar
Engine: 6.0 Vortech
Transmission: 4x4
still need?
Old Aug 23, 2010 | 07:45 AM
dakotaram's Avatar
Engine: LB9 TPI
Originally Posted by RCAR7395
still need?
Still need everything mentioned in first post, I have edited it for things I have already received. Thanks!
Old Aug 23, 2010 | 04:45 PM
RCAR7395's Avatar
Engine: 6.0 Vortech
Transmission: 4x4
[quote=dakotaram;4636836]Well....guess the fiberboard was not warped after all. Lifted it to see what was up and low and behold the dumbs*it that had it before me decided to cut the sheetmetal and peel it back to replace the fuel pump instead of dropping the tank. Did they tack the metal back down??? NO, it just looks like a sardine can - that's all. Think they might have even left the o-ring/gasket off - it was tucked under the carpet hiding.
I have a nice Camaro steering while with the square horn pad on it. All is in great shape $50 shipped in USA
Lmk
Thx
Ray
Old Aug 23, 2010 | 04:56 PM
RCAR7395's Avatar
Engine: 6.0 Vortech
Transmission: 4x4
Needed please :
Sun visors
Headliner and board
Black carpets
Black upholsetery
Shifter **** (auto)
Thanks so much!
I have visors but may be hard top DECENT $35 Shipped in USA per set. Can u send me pics of style door panels u want? Decent rear black carpet only, $60 each shipped in USA, Dont want to mess with weather strip. Most used is trashed at this age. But if i find good , will let u know. You need whats on the door panel top rails and the strip on the outside bottom of driver and pass side glass. I think its a strip inside the window glass slot held on by 7mm screws, price all depends when its found in decent shape.
Lmk
Thx
Ray
Old Aug 27, 2010 | 08:57 PM
dpmalibu's Avatar
I have black Sun visors from an 86 Z/28 T-top car. $20 plus shipping. i also have an aftermarket st. wheel for $30 plus shipping
Old Aug 28, 2010 | 04:23 AM
RCAR7395's Avatar
Engine: 6.0 Vortech
Transmission: 4x4
Lmk if interested in the other parts.
Thx
Ray
Old Aug 28, 2010 | 09:37 AM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
We have some black interior parts available on our site and will be listing more this weekend.
Old Sep 4, 2010 | 09:04 PM
dakotaram's Avatar
Engine: LB9 TPI
Do you have pics? dakotaram@gmail.com
Thanks,
MJ
Old Sep 4, 2010 | 09:06 PM
dakotaram's Avatar
Engine: LB9 TPI
Lmk
Thx
Ray
Madrid Velour is the Velour on top with diagonal lines through it, and carpet on the bottom half. All colors black. I will probably just purchase the entire weatherstripping kit from 1A Auto.
Old Sep 4, 2010 | 09:07 PM
dakotaram's Avatar
Engine: LB9 TPI
Thanks! I will check it out!
Old Sep 4, 2010 | 09:08 PM
dakotaram's Avatar
Engine: LB9 TPI
[quote=RCAR7395;4650500]
Lmk
Thx
Ray
Pics please? You still have my email ....right?
Old Sep 4, 2010 | 09:52 PM
dpmalibu's Avatar
$15 for steering wheel plus shipping$20 plus shipping for visors
Old Sep 9, 2010 | 10:44 AM
dakotaram's Avatar
Engine: LB9 TPI
That is the same exact wheel I have right now, and I don't like it. I may take you up on the visors...shipping to 33556?
thanks,
Old Sep 9, 2010 | 04:42 PM
cam91rs1's Avatar
Suspended
Car: 91rs camaro conv
Engine: 305 tbi
Transmission: 700r4 w/shift kit
HEY I GOT 3 MORE IROCS IF U WANT A WHEEL
Old Sep 10, 2010 | 03:36 PM
dakotaram's Avatar
Engine: LB9 TPI
Course I do....did you find me a condenser? Or any of the other stuff? I can come out this weekend.
Old Oct 10, 2010 | 01:48 PM
upandcoming's Avatar
Car: 88gta
Engine: 357
Transmission: 700r4/3000 stall convertor
Axle/Gears: 9 bolt 3.27
I may have all your interior parts in black if you still need them...pm me
Old Oct 10, 2010 | 06:39 PM
RCAR7395's Avatar
Engine: 6.0 Vortech
Transmission: 4x4
still need a steering wheel?
Lmk
Ray
Old Oct 11, 2010 | 10:22 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Is the list at the top of the page the most current list ?
What's your ZIp code ??
Old Oct 11, 2010 | 10:24 AM
Z2887's Avatar
Soon as I find a cowl hood. I'll have a stock black 87 Z hood in EXCELLENT condition. If you need one.
Old Oct 11, 2010 | 01:48 PM
dakotaram's Avatar
Engine: LB9 TPI
Yes, I have edited it for what is still remaining. Zip is 33556 (commercial)
1992 Trans Am
May 10, 2023 07:19 PM
IMissMy86TA
Aug 31, 2015 08:40 PM
mustangman65_79
Aug 11, 2015 03:17 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
