Hellllpppp!! Clutch Reservoir Cap Needed
Old Oct 9, 2010 | 04:22 PM
mfeller's Avatar
Car: 91 Camaro RS/63 Chevy II
Engine: 305 TBI/355" Predator Carbed
Transmission: 5 Spd\T400 w/TBrake
Axle/Gears: Unknown/4.11
The cap on my clutch hydraulic reservoir came apart at the seams this morning. Anybody out there that is parting out a stick shift car that can come up with one of these caps for me? I'll buy the entire reservoir assembly if necessary.
Old Oct 10, 2010 | 06:56 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Hellllpppp!! Clutch Reservoir Cap Needed
I'm pretty sure I can find you one sitting around here somewhere, but are you sure you can't find one for cheaper than the $5 it would cost to send it? I'll look just in case
Old Oct 10, 2010 | 08:06 PM
ckeene502's Avatar
same here i should have one out in the shop, will check tomorrow.
Old Oct 11, 2010 | 08:46 AM
mfeller's Avatar
Checked local parts houses yesterday, Summit, etc. Checked with locak GM dealer this morning. No luck anywhere. If somebody will shoot me a PM I'll reply/call and try and get this on the way. Luckily it's not my daily driver!!
Thanx to all who responded.
Old Oct 11, 2010 | 09:18 AM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
you can get one from the local help section in your parts stores, they may not be stocked so you might have to order it. it also may not be listed under a camaro just chevy clutch cap. i picked up a black one, it looks diffrent but it fits.
Old Oct 11, 2010 | 12:43 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I know I have one in great shape. I remember seeing it while looking for something else last week. Too much stuff not well organized is the problem here. Any other small things you might need to make the postage more cost effective? Throw in a couple of bucks for gas and effort and I'll gladly send it. I'll get back to you when it's in my hands
Old Oct 11, 2010 | 06:27 PM
ckeene502's Avatar
i found everything but the cap!!! cup, rubber thingie, stuff i lost for years. will look some more.
Old Oct 12, 2010 | 03:42 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Hey, I found it. No signs of brittleness or aging that makes it look like it won't last indefinitely. It seems almost silly just to send that one thing. You want caps to anything else? Washer, radiator overflow,radiator, any other stuff I can toss in for free or almost? What would you like to do?
Old Oct 26, 2010 | 07:43 AM
mfeller's Avatar
Got one folks. A special thanx to henryd3!!!
1992 Trans Am
May 10, 2023 07:19 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
