[OH] lots of f body parts and some convertible parts too.
Car: 1987 Iroc-z Convertible
lots of parts check them out there is prices under the pics. If not just make an offer. http://www.flickr.com/photos/1839044...7625094165253/ I can send individual pics if needed but am short on time. check them out and pm me if interested in anything. The tpi setups and front pulley stuff I can seperate just let me know what you are interested in. Thanks. Here are some pics to show examples of what I have sitting around. I am willing to part out either tpi setup or the pulleys and pump and stuff the tpi wiring harness look to be pretty much intact the 86 tpi harness had around 4 wires cut but the PO said they were the trans wires.
87 convertible camaro spoiler and 3rd brake light
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
Re: lots of f body parts and some convertible parts too.
Whats the lowest you will go on the AC delete box shipped to 75007?
Want a title? Post!
Car: 89 Corvette
Transmission: 700 auto
Axle/Gears: 3.08
Hi interested in throttle body what price please pm.
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
price on the gauge cluster, i can pick it up if the price is good.
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
how much for the convertible interior molding pieces?
I was looking for $100 a piece or $175 for both of them together, (I can split actual shipping with the buyer)for both of them but if you are planning on getting them for your 91 in your profile they won't work. these came from an 87 so they are only good for an 87 or early 88 unless your top frame is from either one then they won't work, but if you have an 87 or early 88 asc vert get back ahold of me. If you have the screw down handles for the top and not the flip out handles they will work.
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Do you possibly have an AC Delete pulley? If so how much shipped to T5X5Y4 Edmonton AB?
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Can the MAF be sold with the pigtail and relays? If so, how much to 14482 zip?
which one? also if the engine in your 91 is stock either tpi setup the intake will need modified because they are both pre 87 so the 4 center holes will need elongated to fit. not really hard to do but will need done. The machine shops around here normally charged around $50 to do it.
Car: 1990 GTA, 75' Formula 400
Engine: 305 TPI, BB400
Transmission: Automatics in Both.
Axle/Gears: 2.73 in the GTA, soon to be 3.42
Is the A/C delete box gone?
1992 Trans Am
May 10, 2023 07:19 PM
