[Sold] 1.5/1.6 SA rockers
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
1.5/1.6 SA rockers
Eight (8) Used 1.5 SA Roller tip rockers Old style comp rockers
Eight (8) Used 1.6 SA Roller tip rockers Newer style comp rockers
- SOLD
Factory LS1 Beehive springs, good to approx .525 lift, - Sold
- SOLD
Transmission: Pro-built 700R4
Re: 1.5/1.6 SA rockers and Beehive Springs
PM sent for springs.
Car: 1991 pontiac firebird formula
Engine: 5.7L HSR, 58mm tb,24lb inj.,lt4 cam
Transmission: 700r4,3000 stall,stage 2 shift
Axle/Gears: 10bolt 3.23 ratio
will the 1.6 ratio springs work with l98 heads and will they clear the stock valve covers
1.6 ratio springs? I assume you mean the rockers. Yes these rockers will fit under stock valve covers with no modifications and they are self aligning so they will work with L98 and Vortec heads.
New2Chevy
Sep 28, 2015 12:35 AM
