3rd gen Camaro parts for sale in the Wasilla/Anchorage Alaska area...
Car: 92 Z28
Engine: L76 in the works.....
Axle/Gears: 3:73
I am selling the entire drive train out of my 92 Z28 camaro. It will include all brake parts, suspension, engine, transmition, K member, power steering parts, engine harness and ecm ect.
The car is an L98 and auto trans car.
The engine and trans are rebuilt with 0 miles.
The trans has a B&M stage 2 shift kit, 2500 rpm stall converter and a Lokar stainless steel kickdown cable.
Heres th list for the engine,
Edelbrock aluminum heads
bored .030
balanced rotating assembly
LT4 hot cam
comp cams double roller timing chain
aluminum timing cover
new aluminum valve covers
MSD 6al ignition
MSD plug wires (new)
MSD blaster 2 coil
Melling high flow oil pump
under drive pulleys
New water pump
LT4 Hot cam
ARP rod bolts
ARP head bolts
All new bearings
Pro comp air fuel gauge
I am going to try and sell all the engine parts together first. If they don't sell then I will be willing to seperate them.
Thats all I can remember for now.
The rear end has limited slip and disc brakes.-----SOLD------
I also have Brand new never used Hotchkis sub frame connectors
Hotchkis adjustable pan hard rod, lower control arms, and strut tower brace.
All parts are black except for the strut tower brace wich is red.
I don't want to ship anything becasue the cost just wouldn't be worth it so this is for local sales only.
Again this is for the Wasilla/ Anchorage Alaska area.
Thanks.
bored .030
LT4 hot cam
MSD 6al ignition
MSD blaster 2 coil
under drive pulleys
New water pump
LT4 Hot cam
ARP rod bolts
ARP head bolts
All new bearings
Thanks.
Car: 92 Z28
Axle/Gears: 3:73
Re: 3rd gen Camaro parts for sale in the Wasilla/Anchorage Alaska area...
Almost forgot. The ecm and harness is for sale as well, along with the stock rims. The rimas have been profesionally redone and have new center caps.
ECM and harness are sold.................
Sarah, is that you? Selling the 3rd gen to move to Arizona and make a run for the White House? Why not just pack it and bring it to Arizona with you? Easier to ship from there...
Car: 92 Z28
Axle/Gears: 3:73
LOL, No thanks.
You think she looks good on tv, you should see her in person.....
If she wins, it will be the first time I will actually WANT to sleep in the White House!!!
And THAT good looking huh??
Car: 92 Z28
Axle/Gears: 3:73
Well, I think she's hot. She doesn't have a chance in hell of winning though. I wouldn't vote for her. Not until she gets alot more experience.
Guess you are right- not as experienced as the guy in office at the moment, that's for sure! And you are right- I think she is SMOKIN'! We had better stop this now, since this board frowns on such discussions. Good luck with the part out... does look like a nice setup- pity you are so far up in the Great White North.
Car: 92 Z28
Axle/Gears: 3:73
Ok, I have decied to ship some of the smaller parts. Larger parts will be cheaper to find in the lower 48.
Let me know what your looking for and we'll go from there.
Car: 1986 Z28, 2006 Cadillac Escalade
Engine: 5.0 litre
Car: 92 Z28
Axle/Gears: 3:73
Want a title? Post!
Car: 1991 Firebird hardtop
Transmission: 5 speed manual
Axle/Gears: i know i got posi
how much are you looking to get out of the sub frame connectors?
Car: 92 Z28
Axle/Gears: 3:73
$150 plus shipping if need be.
All the parts are on craigslist in Alaska if you'd like pics.
Car: 92 Z28
Axle/Gears: 3:73
I don't have a fuel pump to sell.
Sorry......
Sorry......
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
Car: 92 Z28
Axle/Gears: 3:73
Car: 88 IrocZ Vert
Engine: 5.0 TPI
Bump
Thanks for the good deal on the rear end. It should get here today.
Car: 92 Z28
Axle/Gears: 3:73
No problem. I will get the proportioning valve mailed to you on Monday. I would have done it yesterday but I had to drive out to Willow and take a look at a truck for a customer.
Let me know if theres anything else you'll be needing.
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
