[PA] 86 Trans am part out built 700r4 transmission
Car: 1987 Trans AM
Engine: 355 4-bolt, L98 heads, Holley 650DP
Axle/Gears: 3.70 9-bolt
I'm parting out my 86 trans am. I have all the interior parts as well as a TPI top end setup. Holley dual 58mm throttle body, SLP runners, stock plenum, stock intake manifold, accel injectors 24lb an hour. $500 for the whole setup.
-The runners are sold.
-I have a built 700r4, corvette servo, kevlar bands, 2000 stall - $650 local pickup only Philly area
-New light gray carpet - $45
-Lots of other parts just ask
-I also have gta wheels with some curb rash. Not terrible but will need some tlc. Make me an offer local pick up only.
-The interior is light gray and mostly complete.
-The car is going to be scrapped very soon. Let me know what you need.
Car: 1987 Trans AM
Re: 86 trans am part out
Yeah I'd let them go for $225 Plus shipping to wherever your located. Send me shipping info and I can give you a shipping cost.
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
How much for the ecm? Condition of Carpet? Do you have the little screw that holds the 3rd brake light on. Its on the inside of the hatch. Its like a flat nut/ground/thing. Mine wont work without both since they act as a ground. Is it a 5 speed?
Car: 1987 Trans AM
Where is the third brake light mounted that you're looking for? Mine is mounted near the hinge part of the hatch on the glass. I know a lot of them are mounted on the lower part of the hatch under the wing. It's an automatic with a heavily built 700r4 with a 2000 stall converter. The carpet is new. It doesn't even have all the holes cut yet for seat belts and such. It's light gray. The only marks it may have are from where the seats mounted up to it. The car was a project that I'm just moving on from. A lot of stuff is new. I'll let you know about the ECM. I may end up keeping that. It's chipped for the engine that's in the car now. I'm still deciding if I'm selling that or not. It has about 7k into it.
86 is the only year with the 3rd brake light in that location. Mine is a 86 as well. And I only need the ECM. No prom. How much for that( if you are selling) and the front carpet?
Car: 1987 Trans AM
I'll do the ecm and carpet for $100 plus shipping costs. Send me shipping info and i'll let you know final price. Also i should have the third brake light parts. I'll throw in whatever you need with the carpet and ecm box.
