[TX] drivetrain partout (t56, and more)
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
EDIT; UPDATED 12/13/2011
covered my griffin radiator and had a k&n throttle body filter so i have the blank plastic piece for in front of the radiator (1 crack in it)
(25 dollars)
stock steel driveshaft and stock torque arm (25 dollars each)
powermaster starter (60 dollars)
stock throttle body (40 dollars)
brand new, charged and used for a day... sad (75 dollars)
(25 dollars)
Car: 90 z28
Transmission: t56
Re: drivetrain partout (t56, and more)
has a bolt hole/ear missing on the back, worked fine for years (30 dollars)
t-56 from 94 trans am, will eventually need a rebuild because you can hear some grinding but works great. short throw, ask if you need pedals/clutch parts (750 dollars obo)
ram hdx clutch, pressure plate, and billet aluminum flywheel. tell me if you want me to toss the disk in the trash (200 dollars)
Car: 90 z28
Transmission: t56
edelbrock VICTOR water pump (25 dollars)
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
rebuilding the drive train, or getting rid of the car? i want the rad hold down. i dunno when ill make way to arlington though. probably wont be till mid next week.
Car: 91 Camaro RS
i also might be interested in the t56 bell housing if youre willing to seperate it.
Car: 90 z28
Transmission: t56
Which pedals and if you just want the clutch ill give you that pedal and master parts for 40 bucks. And Travis I can deliver if you're in ft worth, I'm parting out the car, tons of threads in the classifieds.
Car: 91 Camaro RS
i work every day from 9am to 9pm, and yea, id rather just wait till my next day off and come get it...how much you wanting for the trans out of curiosity? and im guessing you already sold the HSR.
Car: 2500hd,is300,91z,03pete379
Engine: 6.6,3ltr,lt1,600hpC15
Transmission: auto,auto,t56,13spd
Axle/Gears: 373,?,410,370
800 for the alt,bracket,ps pump, and t56?
Car: 90 z28
Transmission: t56
Car: 90 z28
Transmission: t56
i have a guy interested in picking it up for 800 so i'll let you know if that falls through, shipping is going to be close to 200 freight though fyi
Car: 90 z28
Transmission: t56
Car: 90 z28
Transmission: t56
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
pedals still available?
Car: 90 z28
Transmission: t56
It's a 4th gen clutch and I'll throw in the master and reservoir
Car: 91 Camaro RS
ill be heading to alrington sometime tomorrow afternoon/evening. i want the rad cover and the STS if you still got them. hows $50?
Car: 90 z28
Transmission: t56
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
And was the T-56 sold? I didn't see a definitive answer, just "updated" and "edited."
bigjay89gta
Oct 15, 2015 08:04 AM
