parting out 1987 gta trans am--5.7tpi
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
Re: parting out 1987 gta trans am--5.7tpi
How well dose the engine run if at all?Out of curosity,if it dose run how much you getting compleat with harness ecm and exsaust manifolds.
Car: 89 iroc/90 iroc conv./06 ram
Axle/Gears: 3.27/3.27/3.91
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
if it has dual fans i need the lower fan mount or bracket whatever you call it... the plastic thing the fans attach too on the bottom
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
How much for the driveshaft shipped to 62959
Car: 1989 iroc-z
Engine: chevy 355 ci
how for the strut bar that ging over tune port and ship to miami fl 33137 pm
Car: 1989 iroc-z
Car: 91 RS
Engine: Vortec 350 TBI
How much for the entire front accessory mount setup without the AC and air pump. Both sides with the PS pump included.
Car: 91 RS
I am at 66226. Any chance to see pictures of these and what all you would include? Thanks, John
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
I need a proportiong valve for the smaller 9 bolt disc brakes. Also posted on another of your threads about same part.
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
How much for the torque arm mount. Is it a 700r4 tranny?
Car: 1989 iroc-z
i want to now if you have the shift cable bracket that on the left side of tranny how much shipped to miami fl 33137.
Car: 1989 iroc-z
send me picture just to make sure its the rite one and paypal info thanx.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If it has a digital dash, how much for the heater control panel and the soleniods on the heater box that operate the heater box doors?
Car: '84 Z28
Engine: '02 LS1
Transmission: '02 T56
Axle/Gears: LS1 10-bolt 3.73 w/Auburn Pro
I am looking for an ESC module. I also need the wiring harness pigtail that plugs into it with a few inches of wiring. It will be located on the driver's side firewall and looks like this:
I also need the knock sensor with the pigtail and a few inches of wiring as well.
Would you be willing to grab those for me and ship to 98258? Let me know how much you would want.
here are some pics $50 shipped for all 3 pieces
Never mind. I already got one (Torque arm mount).
Car: 1988 PONTIAC GTA TRANS AM
Engine: 305 TUNED PORT INJECTED
Transmission: T5 BORG WARNER 5 SPEED
Axle/Gears: 3.45 Positrac
Hey interested in some parts Call me up 206 612 8510
