[WA] WTS AC Delete Box. $80 SHIPPED (PIC of the box posted)
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Have a Factry GM AC delete box (Heater only)
you get a few goodys with it like the fan vent and plug.
so you dont have to hunt forthe small parts
paypal add $2.70 (fee) from them not me.
Re: WTS AC Delete Box. $80 SHIPPED
getting harder to Dig Up in Good shape like this.
and at $80 shipped a deal
the first ..ILL TAKE IT... gets it
Jeff
seal on back of box is in Good shape. can clean up the Face and Bolt it On!
Jeff
Re: WTS AC Delete Box. $80 SHIPPED (PIC of the box posted)
do you ship intl??? no motor with it? The AC motor will not fit the non AC box.
Yes it is the same you just swap the none ac fan blad onto your ac motor and pop it in any none ac s10 none ac blade works or you can cut your ac fan blade down and use it
no the case is different
I have installed 4 others and installed one in my 92 z28 and all the others fit with just swapping the fan blades gm did not make alot of diff blower motors and the only diff is how long/deep the fan is.
Pm sent with PayPal info.
I took some pics, just to discuss. The motors are different, the bolt pattern is the same but the case is not. The AC one sits 90 deg clocked in respect to the non AC one. The hose will need to be modified to fit. Also, the squirrel cage can not be exchanged since the motor itself is different. Took a pic w/ the squirrel cage swapped and one does not bolt down the other does not sit flush.
wow i dont know what to tell .ya..like i posted. i have installed a few (4)
and the only thing i had to do was swap in the Box. and install the short Gray Green Fan Housing/blade onto My AC Fan Motor.
Even the Vent tube fit. clocked right in. (NONE AC Vent tube) on AC Blower motor.
this is a pic of my 1992 Z28. showing a 92 AC Blower motor installed on/into a none AC Box. notice even the Motor Vent Tube lower right.about the 5 oclock postion. also fit like a glove.. all i did was install the short Fan Blade. and my fan speed plug into the Box.
East Easy...but yes the diff is the blads are to long by almost a full inch. i have seen others cut there fan blades down by 1" and that also works (cutting the outer ring down by 1 full inch).ILLtake my motor out and see what fan we installed on it. when i did my swap 92/93 i got every thing from GM. Brand new. and it's close to 20 years now...but the fan in the pic below is my factry 92 AC blower motor. with a 1" shorter fan installed on it..
also Note the 9 years of crap from sitting..dont have to look hard to see it..
Box is sold!!
Joel07
Thank you
Joel07
Thank you
It looks like your box is different from mine, the resistor bridge is in a different location also. Maybe the later boxes do use the same motor. I see you have a weatherpack motor, my non a boxes came with the earlier style motors w/ a little ground tab behind one of the bolts and the round connector. Maybe that's the difference?? I did 3, all mine were like this.
I can see you have an AC motor because of the pointy shape. It mounts differently on that box, the ones I ahve mount like in my 1st pic, with the pointy side up. The flat on the bottom is so you can sneak the motor past the inner fender and slide it in the opening. Another thing was, this last bo I had to modify the opening for the ressitor bridge to fit it in. The other one was bolt in. I swap them over so I can retain the high speed blower relay, they only come on AC equipped not on non AC. With the non ac wiring your fan does not even blow very hard at all @ full blast.
Just checked ebay...sure enough there is a difference. This one has a large hole for the resistor:
but it does use the early style motor
iv seen a S10 truck None AC blower motor also work. (think it wasa 89 s10)
wanted to Keep the Diff in parts down has much has i could.
so years down the road. when it was time to get another Blower motor.
i could just get. what was stock. on my car. and get it from anyplace.
BikeFarm
Aug 11, 2015 11:35 PM
