[IL] New Holley Street Avenger & HP, Trans Cooler, Many More Misc. Parts
Old Mar 26, 2012 | 04:59 PM
SoCo80p's Avatar
Brand new in the box Holley 750 street HP carb with vacuum secondaries. Sells for $509.98 from Jegs with their handling, Will take $450
I also have a brand new Holley 770 street avenger. Sells for $413.98 from Jegs with their handling, Will take $350
NOS nitrous super powershot/cheater plate for spreadbore/q-jet. New, never used $100
Huge trans cooler, almost a foot tall and over a foot wide, $30
***Updated*** various items
1" 4-hole carb spacer, $10
Chrome alternator bracket, $10
MSD pro billet distributor wire holder cap, $5 Sold
Chrome timing tab with adjustable pointer for small block, $5
Points/dwell/tach meter tool, $10
Staggered mount starter, Used once, $30 Sold
Sears power drill, $25
Standard 3 wire alternator, worked when pulled, $10
Master heat gun, $80
Comp cams adjustable pushrod length checker for small block, new in package $10 Sold
0-8,000 RPM with adjustable shift point arm tachometer, unknown brand $10
1 cowl vent for non-a/c, $20
Set of ARP main studs to covert to use of a windage tray, SBC, $30 Sold
Not sure of the exact name for it, but the piece that screws into the back of the quadrajet carburetors with the vacuum piece for the brake booster and other vacuum accessories, $20
Pair of new starter bolts, $5
5 piece gauge ring set for 2nd gen firebird $20
USA made craftsman 1/4" ratchet, $10
New autometer sport comp fuel level gauge, $30 Sold
Chrome thermostat housing, $5
Two pieces of braided ~8an line with fittings, $12 each
A/C recharge vaccum pump and gauge line, $25 Sold
Pair of new energy suspension poly swaybar bushings 7/8" $10
One unopened pack of operation desert storm trading cards, $3
Craftsman 1/2" to 3/8" adapter, $3
Pair of heavy duty rear axle u-bolts, $10
Pair of adjustable coil spring helpers to lower or raise, $5 Sold
New in package dewalt 4" knotted cup brush for angle grinders. This bad boy will annihilate any rust or other crap $20
K&N valve cover breather, $8
Set of 5 flex ratcheting wrenches, size 3/8" to 7/8", unknown brand, - Sold
Pair of craftsman flare wrench holders, $15 for the pair
TH400 kickdown switch with bracket, $30
Craftsman beam type torque wrench, $15
3 piece set of new hardshell socket/ratchet cases (1/4", 3/8" and 1/2"). Lids can be removed to allow them to be used as drawer organizers, $40
Old Apr 2, 2012 | 05:59 AM
SoCo80p's Avatar
Re: New Holley Street Avenger & HP, Trans Cooler, Many More Misc. Parts
bump
Old Apr 2, 2012 | 08:43 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
Very interested in the street avenger carb, I will be buying one this summer, if it's still available I'll but it from you then
Old Apr 4, 2012 | 08:48 PM
SoCo80p's Avatar
Sounds good, feel free to get in touch with me.
Old Apr 7, 2012 | 07:09 PM
SoCo80p's Avatar
Back up
Old Apr 12, 2012 | 03:42 AM
SoCo80p's Avatar
Bump
Old Apr 16, 2012 | 04:38 PM
SoCo80p's Avatar
up again
Old Apr 19, 2012 | 12:14 PM
SoCo80p's Avatar
Bump
Old Apr 20, 2012 | 10:18 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Would you do $18 shipped on the Dewalt 4" Knotted Brush Cup?
Old Apr 21, 2012 | 11:03 AM
SoCo80p's Avatar
PM sent
Old Apr 24, 2012 | 04:35 PM
SoCo80p's Avatar
Back up
Old Apr 25, 2012 | 03:45 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Thermostat housing and valve cover bresthers
Old Apr 27, 2012 | 09:08 AM
SoCo80p's Avatar
PM sent
9192camaro
16
Feb 3, 2019 12:21 AM
Reddeath210
Oct 6, 2015 08:20 AM
86IROC112
Aug 17, 2015 02:00 PM
TreDeClaw
Aug 14, 2015 06:58 PM
1nastygta
Aug 8, 2015 07:38 PM
