[FL] 305 TBI Intake Manifold & Throttle body.
Old Jun 26, 2012 | 08:47 PM
xxZ28xx's Avatar
Car: 1988 Camaro, Holley 600 series.
Engine: 350 w/350 TPI heads
Transmission: 90+ 700R4
Axle/Gears: not sure
Im selling my Intake manifold and throttle body because I'm converting back to a carb. They're both in great shape, I have the injectors too but I don't know how good they are.
I'm looking to sell it for $130.00 all together.
$100.00 for the intake manifold
$30.00 for the throttle body
They are both black.
Didn't take a pic of the intake manifold because its still in my car.
Attached Thumbnails 305 TBI Intake Manifold & Throttle body.-c360_2012-06-26-21
Old Jun 26, 2012 | 09:31 PM
xxZ28xx's Avatar
Re: 305 TBI Intake Manifold & Throttle body.
Its off an 1988 F body by the way.
Old Jun 27, 2012 | 10:29 AM
xxZ28xx's Avatar
The IAC is brand new on it also. I'm not taking that stuff off so it comes with it.
Old Jun 27, 2012 | 01:43 PM
blackjack12982's Avatar
Get me a shipped price to 40121 please, I'll take the throttle body! It's complete, with injectors, right?
Old Jun 27, 2012 | 07:20 PM
xxZ28xx's Avatar
I mean yeahh sure it comes with them, don't know how great they are. They ran fine with my car though so I guess they arent bad. I did snip the wires though so If you want I can put a lil extra wire on it for you or you an just get new wire w/e. Ill get the price.
Old Jun 27, 2012 | 07:25 PM
xxZ28xx's Avatar
Okay Im going through UPS...
UPS ground: 16.21
UPS 2nd day air: 39.67
Next day air: 86.05
Ups early air: 129.04
Im assuming you want ground lol those prices are crazy. Im shipping in from Clearwater.
Old Jun 27, 2012 | 09:31 PM
My plan is to send the injectors off to get serviced, and allow me to thoroughly clean the TB, but mine is a DD, so it's kinda difficult to do with with mine.
PM me your Paypal please.
Old Jun 28, 2012 | 06:56 PM
xxZ28xx's Avatar
Throttle body sold..
Looking for a taker on the Intake Manifold... It great condition just getting rid of it because I don't need it.
$100.00
Old Jun 29, 2012 | 04:18 PM
xxZ28xx's Avatar
100.00 or best offer.. Will go for 80.00 I think that's the lowest.
Old Jul 1, 2012 | 12:12 PM
xxZ28xx's Avatar
BUMP..
Old Jul 4, 2012 | 08:51 PM
xxZ28xx's Avatar
Heres a picture of the manifold.
Attached Thumbnails 305 TBI Intake Manifold & Throttle body.-c360_2012-07-04-20
Old Jul 6, 2012 | 06:35 AM
xxZ28xx's Avatar
The EGR valve will come with it because I think I need to buy a new one to fit on my new manifold. I also have a new coolant temp sensor that will go with it. Not a bad deal at all.
Old Aug 9, 2012 | 01:21 PM
xxZ28xx's Avatar
Still have the intake, comes with EGR valve, heater hose connection and the air thing on the back.
Old Oct 9, 2012 | 09:45 PM
OneQwickBird's Avatar
Car: '91 trans am cnvtble and '91 GTA
Engine: 305 and 355
Axle/Gears: stock
Interested in intake for 100 shipped. It should bolt up to an 85 block right?
Old Oct 14, 2012 | 08:06 AM
xxZ28xx's Avatar
Yeah it should bolt up to it, I wouldn't see why not. Send me info and ill get you shipping price.
Sorry for the delayed response I was in the process of rebuilding my engine.
Old Oct 14, 2012 | 11:09 PM
ruiterman's Avatar
Car: 91 Z28, 89 Formula, 85 IROC Z28
Engine: 305 TPI, 305 TBI, 305 TPI
Transmission: 5 Speed, 5 Speed, 700R4
I do not think it will bolt to an 85 block without modifications. The 85 block will likely have 4 bolt valve covers and the 88 will have center bolt valve covers. This means the center bolts on the intake are set at a different angle and will not fit unless you modify the intake manifold center bolt holes.
Ed
Old Oct 15, 2012 | 03:02 PM
xxZ28xx's Avatar
Ed
yeah hes right. My valve covers are center bolts, so if yours are then you can buy it or if your willing to make those modifications.. Just let me know.
Old Oct 16, 2012 | 11:53 AM
7thdarkangel's Avatar
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
if the intake is still avalible ill take it.
Old Oct 22, 2012 | 09:15 PM
1989blueirocz's Avatar
Car: 1989 camaro iroc-z
Engine: 305 5.0L TBI
I have a 1989 camaro iroc-z, and I have a problem. My car will start just fine when I go out to start it, & I can drive around & it runs smooth and perfect, but if I shut it off & park it for an hour or two, it WILL NOT start AT ALL. But, if I take the intake pan completely off, it will sputter around and start right up. (my question is why is it doing that?) and if I park it over night it will start right up in the morning with the pan on and everything. another question is when I'm starting it, are the jets on the throttle body supposed to pulse gas into the motor, or is it supposed to be a constant mist? and another thing, if it gets down to about 1/4th tank, it will idle at like 2,000 rpms? but if you have 3/4 full or half tank it idles around 750 rpm?
to all these problems, could it be the fuel pump? the air/fuel mixture? or what?
and aside from all of that, It leaks transmission fluid around where the speedometer cable goes into the tranny, is that an O-ring or what?
Thank-you in advance for any help.
-Jonathon.
Old Oct 28, 2012 | 08:45 AM
xxZ28xx's Avatar
The intake is still available. Whats your zipcode so I can get you a price.
Old Oct 31, 2012 | 10:38 AM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
06770. What is the manifold off of? Thanks.
Old Oct 31, 2012 | 03:41 PM
xxZ28xx's Avatar
Its off of an 1988 camaro TBI
Old Oct 31, 2012 | 03:47 PM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
will you take $90 shipped to 06770?
Old Nov 5, 2012 | 09:18 PM
ruiterman's Avatar
7thDarkAngel, Seeing your location, I hope you didn't get hit too hard by the storm last week.
jhawkeye
May 25, 2022 06:33 PM
pimp2303
Jul 27, 2017 02:03 PM
Fast355
Dec 2, 2016 06:33 PM
justin57
Aug 20, 2015 07:05 PM
