Console parts: 1982-1984 Firebird Trans AM
Car: 1991 Pontiac Firebird
Engine: 3.1L 189CUI
Transmission: 4spd Automatic
I looking to buy a 82-84 Center Console box Light Lens! Or part or Exchange number for better search!
I have one (mint) and do not have any number on it, and i do not find an other for my 2nd car
If someone have a spare or know where can i get one what will fit on that hole just let me know.
As i know this part not the same in the camaro console
Any info would be helpful.
Also looking for a front attachments for the console:
(Black preferred, but other color can be ok)
Car: 89 Iroc Convertible
Re: Console parts: 1982-1984 Firebird Trans AM
I have these available.All mounts are itact
Engine: 3.1L 189CUI
Sounds good for the tan part i offer 10 for this pair trim.
I do looking for a 82-84 center console glove box light lens too.
Don't you have one?
And i do looking for rear tan seatbelt straps 84-87 tan color
And front belt straps plastic neck (this cover the belt webbing and hold the strap in place) in any color for 84-92 type belts. Just be damage free!
Don't you have one?
I should have the rear seat belt retractors in saddle tan and I should also have a pair of front seat belt buckle plastic sleeves with no cracks.I dont have have the console glove box light lens
Engine: 3.1L 189CUI
Sorry i mean the rear belt strap side which accepts the buckles..
Please drop picture about the mentioned parts. Regards:L
Ok il try to get you some pics later on tonite after I get home from work
Engine: 3.1L 189CUI
LENS STILL WANTED!
I also looking for cheap:
a 82-89 fuse cover
Stock Fixed antenna mast
82-84 front bumper inserts (grills)
82-87 tan seat side trim. (Preferd 85-87 saddle tan!)
used, but useable (for a daily driver) door sill and outer window sweps
Will wait for any reply.
a 82-89 fuse cover
This piece?Drivers side seat trim
Engine: 3.1L 189CUI
Yes! And i do need the other side too. Just at that side i need this big and the lover smaller part too!
Do you have the bose kick panels? Or they already been sold?
And the other things what i looking for?
Engine: 3.1L 189CUI
Any news? you can reach me in email or pm too!
I found this light cover today in an 84 Firebird.I know of a place where they have an 84 and 86 Trans Ams.Both have tan interior.I can pull the seat trim for you when I go back there but it wont be for another week and a half
Engine: 3.1L 189CUI
Yes i do looking for this light lens!
How much you want for it?
I do have interest for the seat trims too to complete a full set.
I got the power lower from you so i need a drivers side upper and both passenger side!
Ok Ill let you when I go back there if Im able to get the parts
Engine: 3.1L 189CUI
Agreed. Prices for this and lens too?
Ohh i need 4 hatch glass screw too (the black cap ones)
And i do looking for an electric fan assemble (top bracket-radiator coverver, fan, lower bracket. And if it has wiring! Single or dual shouldbe ok for a V8 And i looking for a carb and intake too for a CFI carb swap. Here is the topic:https://www.thirdgen.org/forums/engi...ml#post5375036
I dont have any fans,carbs or intakes but I should be able to get the hatch glass screws.Will check tomorrow morning before I go to work.Are you still looking for a fuse box lid?
Engine: 3.1L 189CUI
No thx. i locally found one!
Engine: 3.1L 189CUI
Ok if the plastic cover are damage free it should be ok.
I also looking for:
Stock Fixed antenna mast (i have the base just missing the mast) ((I agree any mast which can be bolt on the stock base))
82-84 headlight motor relay (Located on the side of each opening motor, fixed with 2 screws)
82-85 windshield sprayer washer nozzle 2 or more piece i need 6! But i can agree any.
I also looking for:
Can you send a picture of where the headlight relays are?I'll also look for the sprayer nozzles
Engine: 3.1L 189CUI
Here a picture which show it. (i found here in the forum)
Ok....Ill look for them.Were they only used on 82-84 firebirds?
Engine: 3.1L 189CUI
May on 85 cars too. On those cars wich have his bigger turn cap motor. Others wiring are different.
I picked up 6 squirter nozzles and a fixed antenna mast this morning.no luck on the headlight relays.
Engine: 3.1L 189CUI
Ok just drop a picture of it and sum the parts and price with shipping to we can agree on it. You know my mail! Regards:László
Here are the 6 sprayer nozzles and fixed antenna mast...PM sent
Engine: 3.1L 189CUI
Belts and door seal found! Still looking for a pair power mirrors too any color! 91-92 hatch 3rd brake light, 91-92 firebird dash gauge bezel, a relay socket for 85-89 blower motor relay, and 2 stop light socket with some wire, and the others what i mention before in pms.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
