[WA] WTS Trick Flow Heads $600 shipped (larger springs and runners from trickflow)
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Have a set of Trick flow heads would pass for New but i have used them Low Miles I have had them from Day 1 from Summit. this is the larger set (big springs and runners)
they come set up the the Larger Duel springs from Trick flow.
even come with a 2nd set of Brand new Duel springs for the Heads! (good to 600 lift)
THE FIRST Ill take them gets them!
$600 shipped (lower 48)
paypal add 4%
also have comp cam promag moly 1.6 roller rockers if you want them
add $120
need Pushrods? Have a set from Comp Cams for the above setup
also Pro Mag Parts from compcams add another $60
this shot shows the ports..notice intake gasket is a felpro 1206 sorta big on this set of heads.
but it shows the head ports are a tad bit bigger then 195
paypal add 4%
add $120
Re: WTS Trick Flow Heads $600 shipped (larger springs and runners from trickflow)
btt
Car: 88 IROC-Z (L98)
Engine: Edel. Lwr, SLP Rnrs, Ported Plenum
Transmission: 700R, 2800 Stall
Axle/Gears: 3:42 Posi.(4th gen.) UMI R/Susp.
ANY PICS
What are thhey? G1, g2, 23s, intake cc? Comb. cc?
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
paypal add 4%
I'll take them ....if they are 195's center bolt valve covers.
paypal add 4%
ill post some Pic today: in a few.
63/65cc
202/160
info from Trick flow 200cc intake port (been so long i forget..could be 180?)
twisted wedg
angl plug
im going to say G1 From the 90's
non center bolt valve covers.
3/8 studs
still have the org smog OK decal emblem with them (if ya need it)
this set is the set i had Lingenfelters Go over/port work, and install on the 383 i had them do for My Car. back in the 90's. never had any probs with them.
was running 11.70 with this set. and street tires.
they work with good old Flat Top pistons.(what i had/still have the first Lingenfelter eng).
have one setting on a 427 sbc now, deg the cam.
and they fit even with the 13.1 pistons.and this cam is a smallish 620 lift.
every part on this set of heads looks like new. Low low Miles. did more storage then driving. was away in the USMC.
even the water jackets. only show a slight Green tint from the antifreez.
they have only been on 1 eng. till i removed them...
63/65cc
202/160
twisted wedg
angl plug
3/8 studs
G1s have stepped guide plates, the G2s don't
then i will say They are G1.
back when i had Lingenfelter do My car they wanted to sell me a set of Alum Vet Heads they work Over. and i wanted to try a set of Trick flows.
so i Asked for the the largest Set of heads they had at the Time.
so this set im letting go is that first set..
was 100% bolt on with all the facty GM parts on the car (surp/sensores.SLP Headers)
this shot is with felpro 1206 gaskets
At this Time they Are SOLD PEND FUNDS.
(10/15/12)
(10/15/12)
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
Still got the pushrods? part # and pics of those please ill paypal you tonight if theyre what i need.
If for some odd reason sale doesn't go through.. I may be interested in the heads..
Thx
Thx
They are sold
1992rs/ss
16
Jan 28, 2016 09:58 PM
355tpipickup
Aug 25, 2015 12:54 AM
86IROC112
Aug 17, 2015 02:00 PM
