parting out 1991 z28---5.0 tpi auto
Car: 89 iroc/90 iroc conv./06 ram
Axle/Gears: 3.27/3.27/3.91
Car: 2----91 z 28
Engine: 5.0 AND 350
Axle/Gears: 28 spline 4.11 ford 9 inch AND 373
Re: parting out 1991 z28---5.0 tpi auto
the shifter and all the trim peice that cover it ? shipped to 61738
Car: 2----91 z 28
Engine: 5.0 AND 350
is that with cable and everything to put in my car some one put and b and m in it and it suck dont like it
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
is this car not savable?? run and drive?
still have a bunch of stuff
COTM Editor
The drivers fuse panel door, or even the whole panel w/ the door?
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
how much for the fog light switch with bazle and under hood fog light wireing
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
I need a front driverside retractable seatbelt (just the shoulder piece) and also a rear buckle (red button one). how much shipped to 63116?
Car: 1992 RS B4C
Axle/Gears: 3.23 10 bolt limited slip
Rear end ? Gears. RPO? I live in Mass. We could meet half way in Marlboro. I'm from SS. How much?
89irocz355, looking at my last post I just wanted to clarify that I mean the whole front seatbelt and not the plastic shoulder thing that bolts to the seat. you got that, right?
[QUOTE=0pyders;5450226]89irocz355, looking at my last post I just wanted to clarify that I mean the whole front seatbelt and not the plastic shoulder thing that bolts to the seat. you got that, right?[/QUOTE
with xmas. give me a couple of days ad i will remove and send pics
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
Is it a 110 or a 145 mph speedo? If 145, is it available?
Car: 92 Camaro Z
Engine: LS 5.3 LM7
COTM Editor
Do you still have the factory grey floor mat set? Condition? Price?
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Interested in the main engine compartment bulkhead connector (both sides),
and as much of the wiring harness(s) as you can cut out. Just need some spare parts for custom circuits I want to install. PM if you can help out.
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
Just to give me some food for thought... How much for the engine? Can you give me a price for the longblock (just heads, no accessories) and also a price with the TPI on it still. Obviously picked up.
Car: 1991 RS Convertible
Engine: 377 w/Holley Commander 950 EFI
Axle/Gears: 2.73:1 with Auburn Posi
Do you have the trunk privacy cover? If its in good shape and black how much shipped to 61611?
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
How much for throttle body and throttle cable?
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Any power window switches? Or the connecting plates that connect the door lock actuator rod to to the door lock rod. Here's a pic to show what it looks like. I just need the pieces all the way to the right attached to the actuator rods.
Also black door cards for power windows and locks.
Thanks Don
Thanks Don
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Sanjay
Aug 12, 2015 03:41 PM
