[MI] Steering shaft upgrade
Old Jan 11, 2013 | 02:57 PM
DarrensCamaro's Avatar
Car: 1992 Camaro RS
Engine: 350 Carb'd
Transmission: 5 Speed
Got a bunch of GM steering shafts from Astro vans. All modified to bolt up to your f-body to replace the stock steering shaft.
If your interested let me know, all are painted black.
$70 shipped
Old Jan 11, 2013 | 03:33 PM
blackbmagic's Avatar
Car: 1985 IROC-Z
Axle/Gears: 3.42 10 Bolt Posi
Re: Steering shaft upgrade
What is the benefit to running these?
Old Jan 11, 2013 | 05:25 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
It eliminates the rag joint takes the slop and play out of the steering wheel. Very popular mod.
https://www.thirdgen.org/forums/susp...ing-shaft.html
Old Jan 12, 2013 | 09:27 AM
galletti's Avatar
Car: 1988 IROC Convertible
Isn't there an issue with steering wheel alignment with these? I may be wrong but I remember reading some threads a while back that debated whether these wound up with the wheel 90 degrees off. If you can provide information clearing that up I'm interested in one. Thanks.
Old Jan 12, 2013 | 11:39 AM
Car: 1992 Camaro RS
Engine: 350 Carb'd
That is if you don't modify them that's if you just bolt it on. These have been modified to correct that by taking one end and turning it 90 degress. As you can see in the picture the ends are opposit if eachother making the steering wheel stay straight.
Old Jan 12, 2013 | 02:32 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
I also do have one with the isolator as well...
Ready to go, have them posted other places as well shipping fast...
Prepped, primed and painted. Boxed up, ready to go.
Old Jan 14, 2013 | 11:19 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
bump
Old Jan 16, 2013 | 07:20 AM
Car: 1992 Camaro RS
Engine: 350 Carb'd
The one with the isolator is now sold, I have a few shafts left ready to go, and could go pull more if anyone is interested. I can get more with the isolator if those are more in demand.
Old Jan 21, 2013 | 06:04 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
Got a few shafts on the shelf still, also have another one with a rubber isolator in it, please let me know!
Old Jan 22, 2013 | 06:10 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
to the top
Old Jan 25, 2013 | 03:01 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
Just installed one of these on my buddies car, big improvements! Who needs one?
Old Jan 28, 2013 | 07:31 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
bump
Got some primed and painted ready to ship, have a few more on the shelf to be modified so if you want one let me know!
I do have one with the isolator in it if that interests you!
Old Feb 2, 2013 | 09:16 PM
BigJon88's Avatar
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
Bump!!!!!!!!!!
Old Feb 2, 2013 | 10:43 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
So now what's the benefit of running the isolator instead of the straight shaft? I want to eliminate all possible slop from my steering and I have had plenty of troy le with my rag joints in the past
Old Feb 5, 2013 | 03:27 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
I have not personally installed or driven a car with the isolator yet, I would assume its not much difference just a preference. I can tell you with the regular shaft I was very pleased with the feel of the steering wheel and slop was eliminated for sure. I have some of each if interested let me know!
Old Feb 9, 2013 | 12:05 AM
Car: 1992 Camaro RS
Engine: 350 Carb'd
Bump I know you guys need one of these. Have a few left.
Old Feb 9, 2013 | 10:23 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Have one in my car totally worth it.
Old Feb 12, 2013 | 03:24 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
Thanks I agree, big improvements in my opinion as well.
Have a bunch boxed up ready to be shipped!
Old Feb 19, 2013 | 01:00 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
bump
Old Feb 25, 2013 | 02:27 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
Bump, I have one left with the rubber isolator and I have some regular ones ready to go as well, painted and boxed up!
Old Feb 25, 2013 | 03:00 PM
jas2730's Avatar
Car: 89 IROC Z/88 IROC Vert
Engine: 350c.i./305c.i.
Transmission: 700R4/T-56
Axle/Gears: 3.42/4.10
Hardware included?
Old Feb 25, 2013 | 03:10 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
Originally Posted by jas2730
Hardware included?
Yes everything you need to bolt on to your car is included, bolt heads are also painted black (not the threads) to match and make it all look good!
Old Feb 26, 2013 | 11:21 AM
Grifter757's Avatar
Car: 87 IROC,
Engine: 370 LSx With Boost
Transmission: 4L80E
Axle/Gears: S-60 with 3.50s
I needs a GM one Stat
Old Feb 26, 2013 | 11:32 AM
Car: 1992 Camaro RS
Engine: 350 Carb'd
I have some! DarrenMHumphreys@gmail.com is paypal
Old Mar 31, 2013 | 11:25 AM
hardcoreZcar's Avatar
Car: 86 Z
Engine: 400 sbc
Transmission: t-56
Axle/Gears: 4.10
Still have have one for me?
Old Mar 31, 2013 | 02:54 PM
saprano's Avatar
Want a title? Post!
I want one with the isolator but I want it left unpainted. Let me know if you have anything available.
Old Mar 31, 2013 | 04:06 PM
Car: 86 Z
Engine: 400 sbc
Transmission: t-56
Axle/Gears: 4.10
What difference does the rubber isolator make?
Old Mar 31, 2013 | 05:28 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
I have one with the isolator but i believe it has been painted black already. I could sandblast it for you if you would like?
Yes i have a few available.
Old Apr 1, 2013 | 12:38 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
I want one without isolator. pm me your paypal info please.
Old Apr 1, 2013 | 12:52 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
To be honest I am not 100% sure, as I have not installed one with a isolator on my car yet. I have been told it reduces noise and vibrations. Although I didnt notice noise and vibrations with my GM one...
Right now the one with the isolator that I have is spoken for, I can see if I can get more but I do have other GM ones ready to go.
PM coming.
Old Apr 3, 2013 | 02:56 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
I have 2 left as of right now, if anyone else wants one let me know. I have this weekend off and I can go get more if there is the interest. Shoot me a PM or speak up in here!
Old Apr 4, 2013 | 06:35 AM
KhaosTactic's Avatar
Car: 1985 Black z28 T-top, 09 eclipse
Engine: Carb'd 305 soon to be a 400 sc
Transmission: 700r4 to T5 swap
Interested, pm sent
Old Apr 4, 2013 | 08:21 PM
Car: 86 Z
Engine: 400 sbc
Transmission: t-56
Axle/Gears: 4.10
Got mine in the mail today. Finish is great, clean grease and zero plan. Great rebuild, highly recommended!
Old Apr 5, 2013 | 09:00 PM
Car: 1990 Camaro RS
Got mine today as well. Very impressed with the quality. Definitely worth purchasing.
Old Apr 9, 2013 | 10:00 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
Thanks guys going to head out and get some more ready to go!
Old Apr 10, 2013 | 05:23 AM
Kurtis2short's Avatar
Pm sent
Old May 17, 2013 | 02:24 AM
thunder57's Avatar
Car: 1987 IROC
Axle/Gears: 3:42, 10 Bolt LT1
Just getting around to installing the shaft... real solid piece! I'm having trouble getting the steering wheel to be dead center. When I compare the old to new shaft, when the gearbox side has the flat part on the bottom the old shaft would be 90 degrees at the steering column. The new shaft would have the steering column part be up straight up and down. I'll try to get pictures tomorrow. Any help would be appreciated. Thanks!
Old Oct 8, 2013 | 04:42 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
I responded to your PM sorry for being so late.
Been away from the site for a bit but I do have 4 shafts modified, painted and ready to go if any one is interested in them. I will also be making a trip this weekend to get some more.
Old Oct 16, 2013 | 07:05 AM
Car: 1992 Camaro RS
Engine: 350 Carb'd
bump
Old Oct 18, 2013 | 09:06 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
Bump
Old Nov 2, 2013 | 04:31 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
BTT
I have these boxed and ready to be shipped out!
Old Nov 10, 2013 | 08:01 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
TTT!!
Old Jan 22, 2014 | 01:26 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
If anyone is still looking I have a few on the shelf ready to go if interested.
Old Jan 25, 2014 | 01:10 AM
codyscamaroz28's Avatar
Car: 1982 Z28, 1991 RS
Engine: 350 Carbed, 305 TBI
Transmission: 700r4, t5
Axle/Gears: 3.23s posi Limited Slip, 3.08 posi
would this work for a 82 z28.. i got some play in my steering..
Old Jan 25, 2014 | 08:16 AM
Car: 1992 Camaro RS
Engine: 350 Carb'd
Yes it sure would. I replaced my steering shaft and cleared up a lot of the play in the steering wheel.
Darren
Old Jan 25, 2014 | 08:58 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Hmmm replacing the shaft itself wouldn't reduce play unless yours was bent or something. Replacing the rag joint (the piece that couples the shaft to the steering box) with a solid ujoint for example would make the steering more responsive. If your rag joint had play in the first place then it will obviously make a bigger effect.
Sent from my iPhone
Old Jan 25, 2014 | 09:47 AM
Car: 1992 Camaro RS
Engine: 350 Carb'd
Originally Posted by hellz_wings
Hmmm replacing the shaft itself wouldn't reduce play unless yours was bent or something. Replacing the rag joint (the piece that couples the shaft to the steering box) with a solid ujoint for example would make the steering more responsive. If your rag joint had play in the first place then it will obviously make a bigger effect. Sent from my iPhone
You replace the rag joint entirely with a solid shaft there for it does reduce the play in your steering and makes it more responsive.
Old Feb 1, 2014 | 05:08 PM
WTR388's Avatar
Car: 87 Trans Am
What's your trick for getting the shaft out of the van? I have it off the steering wheel side and the bolt off the input shaft on the steering box... Tried to pry it open with a hammer and chisel. Had to give up as the yard was closing and it was a blizzard.
Its one with an isolator.
Old Feb 19, 2014 | 02:24 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
Just un bolt them and yank them bad boys off...
TTT
I have some painted, greased and boxed up ready to be shipped out immediately in anyone is in need. I also just installed one in my new 1992 camaro this past week!
Old Feb 23, 2014 | 02:09 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
Bump
Boxed up ready to go get your car ready for spring!
