[IN] L98 block and heads 88GTA
Old Jan 12, 2013 | 11:21 PM
fireeater's Avatar
Car: 88gta
Engine: 350tpi
Terre Haute Indiana
email tex@fire-eater.net
Pick up only for block and heads want you to inspect b4 you buy.
Make me an offer come and get it.
I had 700 dollars worth of machine work done to this block and heads a couple of years ago and I am never going to build this engine. I had it magnafluxed. had it bored .030 over, line bore, decked, new cam bearings installed. hd the heads modified for 2.2 and 1.6 valves, and valve seats machined for comp cams valve springs part no 986-16 recommended for the cam(08-423-8) I never started the pocket porting though. I dont kn ow how much was taken off the head and deck, but my machinist said would be 10:1 with flat top pistons.
I coated the block and heads with lucas to protect from rust but there is some light surface rust. I think it will clean up fine.
Other parts I have flat top
hypereutectic pistons
Forged rods
Cam
Springs
Stainless valves
Polished 52mm throttle body
original throttle body
chrome high cap oil pan
melling high vol pump
aluminum ball milled valve covers
new unpainted steel valve covers
etc
Old Jan 14, 2013 | 11:44 AM
Rabble's Avatar
Re: L98 block and heads 88GTA
Will you seperate the block and heads? I only need the heads. And how much are you looking for?
The pistons, are they standard bore?
I'm located over in Portage
Old Jan 14, 2013 | 12:16 PM
fireeater's Avatar
Car: 88gta
Engine: 350tpi
I will separate, pistons are .030 over like the block. youknow the heads are modified right? do you need the valves or springs that fit it?
Old Jan 14, 2013 | 02:12 PM
Rabble's Avatar
All I will need is the valves. I need standard bore pistons, so nevermind on them.
Old Jan 14, 2013 | 03:26 PM
fireeater's Avatar
Car: 88gta
Engine: 350tpi
First, I need to correct the typo intake valves are enlarged to 2.02 not 2.2 so I understand if you are no longer interested. would take 180 for the heads. 80 for the new stainless valves. I dont care if you buy my springs as log as you understand that these heads are modified for these springs and the stockers may not work would take 80 for the springs and retainers and other spring hardware if i can find other hardware caps and such. I could ship the heads if someone pays actual cost and they are heavy.
Old Jan 14, 2013 | 04:19 PM
Rabble's Avatar
This is the cam I have, http://www.compcams.com/Company/CC/c...x?csid=87&sb=2 and I have the matching springs and everything for them. Will these work?
Old Jan 15, 2013 | 05:23 AM
fireeater's Avatar
Car: 88gta
Engine: 350tpi
The second set of springs listed are the ones i have so you should be good to go.
Old Jan 15, 2013 | 02:49 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Interested in the block, pistons, rods, heads and valves.
What brand and part number for the pistons and rods?
Price for all, I can meet. I'm about 3 hours away in the same state.
Old Jan 15, 2013 | 02:56 PM
fireeater's Avatar
Car: 88gta
Engine: 350tpi
I will try to get that info for you but will probably be thursday night. I work 12 hr nights and go to class during the day. The pistons came in a plain white box and the rods came bundled in plain packaging. I will look for markings though. I I also have piston rings and bearings I think are sealed power. will let you know if you have a little patience. Thanks in advance
Old Jan 16, 2013 | 10:26 AM
Car: 1971 Camaro
Engine: 427
I'm in no hurry, but definatly in the market for said items. Let me know what you find.
Are the pisons installed on the rods already? Did the machine shop bore the block to match the pistons?
Do you have a crank?
Old Jan 23, 2013 | 09:48 AM
Car: 1971 Camaro
Engine: 427
E-mail sent.
Old Jan 25, 2013 | 08:11 AM
Car: 1971 Camaro
Engine: 427
Any info?
Old Jan 26, 2013 | 10:44 PM
fireeater's Avatar
Car: 88gta
Engine: 350tpi
Rabble. Still interested in these heads and valves? I never heard back from you.
Old Jan 26, 2013 | 10:54 PM
fireeater's Avatar
Car: 88gta
Engine: 350tpi
blocl is bored .030 over pistons are flat top .030 overPistons are sealed power guess I lied about the box. no brand on the rods. markings are 2 411 very light surface rust on the rods from storage bearing surfaces still look good 180 for heads 150 for block 80 for valves 75 for pistons 90 for the rods. 20 for sealed power rings. 550 for all
Old Jan 26, 2013 | 10:58 PM
fireeater's Avatar
Car: 88gta
Engine: 350tpi
Sorry it took so long. been super busy. new job interviews. class overtime at work. liquidating my rifle collection etc. was ball milled valve covers in the plain white box.
Attached Thumbnails L98 block and heads 88GTA-dsc_0029.jpg   L98 block and heads 88GTA-dsc_0030.jpg   L98 block and heads 88GTA-dsc_0031.jpg
Old Jan 26, 2013 | 11:04 PM
88FormulaF_Bomb's Avatar
Car: 1988 firebird formula 350
Axle/Gears: 2.77
liquidating rifle collection??? pm me
Posted from Thirdgen.org App for Android
Old Jan 27, 2013 | 12:09 AM
fireeater's Avatar
Car: 88gta
Engine: 350tpi
Sorry, dont know how to pm. is my e-mail visible to you? we can exchange numbers.
Old Jan 27, 2013 | 09:03 AM
Car: 1971 Camaro
Engine: 427
I'm definatly interested in the block, pistons, rods, rings and bearings and ghe heads with valves.
Im about 3 hours away, it would be this coming weekend before I can make the trip.
Old Jan 27, 2013 | 09:05 AM
Axle/Gears: 2.77
emailed you my number
Old Jan 27, 2013 | 11:38 AM
fireeater's Avatar
Car: 88gta
Engine: 350tpi
I will be here. If you are very serious, I can hold them for you. also have most of a felpro gasket set and lotss of other stuff if ur interested.
Old Jan 27, 2013 | 12:12 PM
Car: 1971 Camaro
Engine: 427
I'm serious, I can come up Sunday, if you were willing to hold, I could paypal you a deposit tommorrow if neeeded.
May be interested in other stuff too, I'm pretty much starting all over after removing a big block from my camaro, and going back to tpi.
Old Jan 27, 2013 | 12:33 PM
fireeater's Avatar
Car: 88gta
Engine: 350tpi
No deposit. your word is ok. if my email is visible to you. shoot me one directly with your number and then I'll text u mine.
Old Feb 10, 2013 | 07:38 PM
Car: 1971 Camaro
Engine: 427
Thanks for the parts today!
Great seller.
Old Feb 10, 2013 | 10:16 PM
fireeater's Avatar
Car: 88gta
Engine: 350tpi
Johny Blaze is a stand up guy. Thanks again.
lt500r55
Sep 1, 2021 01:30 PM
Jake_92RS
Jan 28, 2020 10:37 PM
CRFred
Feb 7, 2016 11:39 PM
lakeffect2
Aug 23, 2015 08:44 AM
anesthes
Aug 8, 2015 09:37 PM
