GM 7.5" CHEVY 10 BOLT 7.625" 3.23 RING AND PINION
Car: 84 Camaro Z28
Engine: 5.3
Transmission: Tremic 6 Speed
Axle/Gears: 3:43 posi
I am in need of a used set of 3.23 ring and pinion for my Chump car Camaro.
My housing took a beating at the last race and broke and bent a bunch of pieces.
Needs to be in good condition.
If you have a set please email me at stumptown@mail.com.
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Re: GM 7.5" CHEVY 10 BOLT 7.625" 3.23 RING AND PINION
Damn, I have a set of RIchmond 3:42's if you were willing to go that route.
Car: 84 Camaro Z28
Engine: 5.3
I am limited to 3.23s for the length of the straights at PIR. With the tire height and rpm i can only use the 3.23 maybe a 3.08.
Thanks though!
Thanks though!
Car: 84 Camaro Z28
Engine: 5.3
Same carrier as 3.23s isnt it?
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I'm almost positive that I've still got a good set of 3.23's........ I'll re-post once I can verify. What is your ZIP code ??
Car: 84 Camaro Z28
Engine: 5.3
Racetech Motorsports
4040 SW Macadam Ave
Portland Or 97239
I found a complete rear end for a very good price and will be here at the Shop Friday. I could use back up parts or rear ends.
Thanks, let me know.
4040 SW Macadam Ave
Portland Or 97239
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
i have 2 complete rear ends. 1 9 bolt 3.2 ish disc brake posi and a 10 bolt 2.7 ish disc brake posi too. best part i'm in clatskanie rite down the road. i also have the spacer to instal 3.3 gears on a 2.7 carrier. att taken apart for inspection. text me 360-560-2163 i dont check this often.
Car: 84 Camaro Z28
Engine: 5.3
I am still in need of a ring and pinion in 3.23. Anybody?
Here's a set:
Shipping = $15.50 for Medium Flat Rate postage + insurance. If your interested make a realistic offer for them.
hectre13
Dec 11, 2023 08:14 AM
lt1z350
Sep 29, 2015 01:50 PM
gixxer92
Sep 1, 2015 04:32 PM
hectre13
Aug 26, 2015 08:17 AM
