[Sold] AFR 1040's 60cc Chambers
Old Sep 9, 2013 | 08:38 PM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
AFR 195 L98 Street Ports, 2.05/1.6 valves, bought these as they sit from anesthes about a year ago. He idled them less than 2 hours in his garage and switched set-ups, Im now going LSX. They are 60cc combustion chambers done by AFR so they are still covered by AFRs lifetime warranty! They have the standard #8017 valve springs, these are good to go. $1200 Shipped to lower 48!
If anyone has any questions on these, Anesthes was kind enough to provide the original order# from AFR in post# 15 and can be used to bring up there build sheet.
Old Sep 9, 2013 | 08:39 PM
Car: '89 IROC-Z
Engine: LSx
Re: AFR 1040's 60cc Chambers
Old Sep 20, 2013 | 04:24 PM
Car: '89 IROC-Z
Engine: LSx
Bump!
Old Sep 21, 2013 | 07:37 PM
Car: '89 IROC-Z
Engine: LSx
Really need these gone, will do $1200.00 shipped to the lower 48.
Old Sep 27, 2013 | 06:29 PM
Car: '89 IROC-Z
Engine: LSx
Bump!
Old Oct 5, 2013 | 09:29 PM
Car: '89 IROC-Z
Engine: LSx
Bump!
Old Oct 11, 2013 | 08:00 PM
Car: '89 IROC-Z
Engine: LSx
To the top!
Old Oct 19, 2013 | 09:01 PM
Car: '89 IROC-Z
Engine: LSx
Bump!
Old Nov 4, 2013 | 04:42 PM
Car: '89 IROC-Z
Engine: LSx
TTT
Old Nov 5, 2013 | 08:28 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Probably didn't even idle them that long. I drove the car in and out of the garage like 5 times, and ran it long enough to do a hot valve adjustment. I got a killer deal on a procharger and needed to reduce the compression ratio to run it. Switched to big chamber AFR 210s.
With the 60cc chambers, these are basically a direct replacement for L98 vette motors. Do this and a cam and make serious power. They go for $1517 from summit new, which these basically are, and consider the couple hundred bucks for AFR (not some lame local hack) to mill 'em to 60cc.
-- Joe
Old Nov 5, 2013 | 08:44 AM
Car: '89 IROC-Z
Engine: LSx
-- Joe
Thanks Joe, I've been getting alot of low ballers, then they say theyd rather just spend the $1500 for them new and not have to worry about problems etc, . Personally I'd LOVE to keep them for a rainy day but I want to get this IROC done, it'll be 2 years off the road in January.
Old Nov 5, 2013 | 09:18 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
eh. They have a lifetime warranty. If anyone has any concerns they can contact Jim Barth.
I kinda wish I had kept those heads. When I went to the 210s I had to get a special intake because most off the shelf wouldn't cover the ports. It ended up costing me twice as much in the end over the "deal" I got on the supercharger. Live and learn.
-- Joe
Old Nov 14, 2013 | 11:20 PM
Car: '89 IROC-Z
Engine: LSx
Bump!!!! Hate to see them sit here!
Old Nov 15, 2013 | 11:27 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Are these the "newer" 195cc Eliminators?
Old Nov 15, 2013 | 01:30 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Yes. Original order # was 068983, you can call AFR and get the build sheet on these heads.
-- Joe
Old Nov 16, 2013 | 12:59 PM
strc09's Avatar
Car: 1988 Pontiac Firebird Trans AM GTA
Engine: Tune-port Injected 6.3L
Transmission: Borg-Warner T56 six-speed
Axle/Gears: Borg/Warner 9-bolt with 3.70:1
Will these bolt up to a 1206 TPIS Mini Ram? What is the compression ratio on them? What size valves do they have? Do they have any sort of valve job on them? How much better are they than the 113 heads?
Old Nov 16, 2013 | 04:51 PM
watajob's Avatar
Car: 92 T/A 'vert
Regarding the 113 heads, even in the hands of an accomplished machinist, during the wettest of a wet dream, will the 113's ever come CLOSE to these in terms of flow or combustion efficiency.
Old Nov 16, 2013 | 08:11 PM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Old Nov 16, 2013 | 08:19 PM
Car: '89 IROC-Z
Engine: LSx
You might have to port match to the intake a little on a 1206 im pretty sure they recommend a 1205 as they sit. Compression depends on your displacement and what pistons you have. Valves are 2.05" intake, 1.6" exhaust and AFR does 4 angle valve cuts.
Everyone else already answered your questions regarding the 113's, and I agree.
Old Nov 24, 2013 | 09:58 AM
Car: '89 IROC-Z
Engine: LSx
Sunday Bump!!!
ULTM8Z
DIY PROM
Oct 2, 2015 01:25 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
355tpipickup
Sep 28, 2015 05:50 PM
tuningnewb
DIY PROM
Sep 23, 2015 07:06 PM
