[Sold] Gauging Interest : New C4 Grand Sport Front Calipers
Old Jan 2, 2014 | 09:01 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
SOLD! Thanks Joe
Old Jan 2, 2014 | 09:08 PM
DiabloWS6's Avatar
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
Re: Gauging Interest : New C4 Grand Sport Front Calipers
Will they bolt up to a 1le
Old Jan 2, 2014 | 09:23 PM
norcalz28's Avatar
No, 1LE is a 12" setup. These are based on the J55 13" HD brakes.
Old Jan 2, 2014 | 09:27 PM
DiabloWS6's Avatar
Sucks for me bbetter in my case to stay with the standard 1le..great looking calipers have seen them before hope you sell them
Old Mar 14, 2014 | 10:30 PM
norcalz28's Avatar
TTT, still have them. Thanks
Old Mar 15, 2014 | 06:35 AM
TennesseeIroc-Z's Avatar
Car: 1988 Iroc T-top
Engine: 350 w/typical bolt-ons
Transmission: 5 speed
Axle/Gears: 3.42 zexel, TEN chromoly 28 splines
Interested, I'm doing the C4HD swap, front and rear. I just have the plain ole j55 calipers, would love these. How much? Brand new you say?
Old Mar 16, 2014 | 11:53 AM
norcalz28's Avatar
Yes, brand new. I've had them for years. Bought them from a local Chevy dealer before they folded. Had wanted to go 13" on the iroc, but the 12" c4's I have now are probably enough for how little I drive the car. Let me know. Prices have come down on them. I think I paid about $420-$430 for the pair at the time. I would take $300.00 plus shipping. That's about as cheap as they get. They're in storage so if you want them it would take me a few days to go grab them. Thanks
Old Mar 17, 2014 | 08:50 PM
88 350 tpi formula's Avatar
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I thought the grand sport used the same wider opening calipers as the 1le just the hose location and cosmetic looks were different?
they were used on 13" rotors but since they used the same pads and thickness dimensions worked on the 12" 1le
might be worth checking with ed would open up more potential cars
https://www.thirdgen.org/forums/brak...-corvette.html
Old Mar 17, 2014 | 10:02 PM
norcalz28's Avatar
I would think if they were that similar, more people would run J55 brakes. I'll leave it as is for now. Not in a rush. Thanks
Old Mar 18, 2014 | 01:41 AM
Twin_Turbo's Avatar
Those calipers are a direct swap for a 1LE, if you get a 13" conversion brackets, some 1LE rotors milled down to hubs and the vette J55 abutments you can use the 13" j55 rotor
Basically the GS caliper is the same as the Baer track 1 caliper with the baer logo on it., Same casting (the wide smooth one without the ribs)
Old Mar 18, 2014 | 01:06 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Yes sir, I have that brake setup on my 91Z. You can run those calipers with 12" rotors as well, using the correct bracket, as long as the rotors are 1.1" thick.
Old Mar 19, 2014 | 07:49 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Will the GS caliper fit in a factory 16" IROC wheel? Are the caliper bigger, radially, than the standard J55 calipers, which do fit.
Old Apr 1, 2014 | 10:35 AM
norcalz28's Avatar
Physically I believe they are the same overall dimensions, only have a wider channel to accept a thicker rotor. You would need to check with someone like Ed Miller. I'm just selling them for what they are. I'm sure they could be used, with proper brackets and modifications, to fit a number of applications. TTT still for sale
Will
Old Apr 1, 2014 | 02:23 PM
Twin_Turbo's Avatar
Yes, the caliper will fit a 16" IROC wheel, even a 13" Corvette J55 setup with those calipers fits a stock wheel:
crappy pic but this is a 13" j55 setup
Old Apr 1, 2014 | 03:08 PM
norcalz28's Avatar
Snug fit! Thanks
Old Apr 21, 2014 | 07:10 PM
norcalz28's Avatar
TTT. USPS Flat Rate shipping is about 12-14 bucks. Have them boxed and ready to go to a new home. Thanks
Will
Bubbajones_ya
Jul 6, 2024 08:32 PM
69GTOby
Apr 18, 2016 02:34 PM
codeysabatini
Nov 10, 2015 04:07 PM
codeysabatini
Sep 20, 2015 11:36 AM
gta892000
Sep 16, 2015 12:37 AM
