[PA] 1988 Firebird Formula steering/suspension/ brake parts prices lowered
Old Feb 14, 2014 | 07:52 PM
dpmalibu's Avatar
All parts have been sold!!
Old Feb 15, 2014 | 07:40 AM
dlw310's Avatar
Want a title? Post!
Re: 1988 Firebird Formula steering/suspension/ brake parts
I AM INTERESTED IN YOUR BRAKE HOSES. HOW MANY ARE THERE?ARE THERE 3 FOR A DISC ,DRUM SETUP OR 5 FOR A DISC ,DISC CAR? WILL PICTURES BE COMING? THANKS DAVE
Old Feb 15, 2014 | 06:11 PM
dpmalibu's Avatar
There are 4. I think one is missing. I have 2 fronts, 1 rear and 1 rear center.
Old Feb 17, 2014 | 07:13 AM
dpmalibu's Avatar
Old Feb 17, 2014 | 07:18 AM
dpmalibu's Avatar
[/U
RL]
Old Feb 17, 2014 | 07:21 AM
dpmalibu's Avatar
Old Feb 17, 2014 | 08:13 AM
dlw310's Avatar
Want a title? Post!
if you could find the other rear line these are what I need. thanks dave
Old Feb 17, 2014 | 11:08 AM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
I am interested in the cross member mounted torque arm. Does the $275 include shipping? Also, do you have the magnetic angle finder for the pinion angle adjustment? PM me a total price to ship to 55432 and payment information.
Old Feb 17, 2014 | 07:18 PM
dpmalibu's Avatar
does not include shipping. I will get you a shipping price
Old Feb 17, 2014 | 11:57 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
How much for the torque arm it will cost me $125 to get it powder coated I have the crossmember with driveshaft loop so all I need is the torque arm and shipping is to 35120
Old Feb 18, 2014 | 03:51 AM
dpmalibu's Avatar
Not separating the x-member and torque arm at this time.
Old Feb 18, 2014 | 11:47 AM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
Last edited by BlackMamba; Feb 18, 2014 at 11:55 AM. Reason: wont work with set up
Old Feb 18, 2014 | 07:39 PM
dpmalibu's Avatar
Torque arm and x-member are sold!!!
Old Feb 19, 2014 | 01:04 PM
jrhaus76's Avatar
Car: 1989 IROC-Z28
Engine: L98 - 350 TPI
Transmission: MD8 - 700R4
Axle/Gears: GH3/G80 - 2.77 POSI
LCAs and panhard bar have any rusting at bushings other than surface rust? Any cracks? Are the bushings torn at all? They are pretty beat up looking but with done work could be refreshed.
If nothing is rusted, torn or cracked, I'll offer $150 shipped to Ohio for the LCAs and panhard. Shipping should run about $20.
Old Feb 19, 2014 | 05:46 PM
dpmalibu's Avatar
its just surface rust. Bushings are intact. Nothing torn. They are solid
Old Feb 19, 2014 | 08:37 PM
jrhaus76's Avatar
Car: 1989 IROC-Z28
Ok.
See your PM
Old Feb 19, 2014 | 08:57 PM
TennesseeIroc-Z's Avatar
Car: 1988 Iroc T-top
Engine: 350 w/typical bolt-ons
Transmission: 5 speed
Axle/Gears: 3.42 zexel, TEN chromoly 28 splines
If someone needed just the torque arm I could use the crossmember
Edit. Nvm. I see its sold
Old Feb 20, 2014 | 06:56 AM
dpmalibu's Avatar
LCA's and pan hard bar are still for sale
Old Feb 24, 2014 | 07:11 PM
dpmalibu's Avatar
TTT
Old Feb 26, 2014 | 04:49 PM
garagepro's Avatar
Car: '86 Iroc
Transmission: 5-speed
How much for the high pressure power steering line with pressure switch and metal tubing to the rack?
Old Feb 26, 2014 | 06:18 PM
dpmalibu's Avatar
$20 shipped if I can get it off without twisting the metal part of the line.
Old Feb 26, 2014 | 07:27 PM
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
How much for steering wheel shipped to 35674
91' firebird .. 305 TBI .030 over , balanced bottom end , speed pro hyper flattops , 10.6:1 CR , all ARP rod bolts and main studs , melling HV oil pump , trick flow super 23 175cc heads, Howards HR 214/218@.050 .488/.495 lift on 114 LSA , full roller 1.6 RR = .520/.528 lift , summit dual plane intake port matched , shorty headers into 2.5" Y w full 3" flow master system and 3" cutout in front of axle , msd billet dizzy, 620cfm TBI , custom CAI , tubular adjustabke LCA pan hard , umi torque arm wonder bar , BMR trans cross member , COMP engineering SFC's, disc rear w 4.10's, drilled an slotted rotors, EBL flash , VRFPR, WBO2,
Old Feb 26, 2014 | 07:35 PM
dpmalibu's Avatar
Pm sent
Old Feb 26, 2014 | 10:26 PM
garagepro's Avatar
Car: '86 Iroc
Thanks for the reply on the PS hose however I only really needed the metal tubing part to a t-fitting for the pressure switch and I just found it new from NAPA.
Old Feb 26, 2014 | 11:32 PM
dpmalibu's Avatar
No problem
Old Feb 28, 2014 | 11:33 AM
dpmalibu's Avatar
Pan hard bar, lowering springs and rear sway bar are sold!!!
Old Feb 28, 2014 | 05:30 PM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
Would you be willing to separate the front SS brake lines? How much shipped to 90638?
Old Feb 28, 2014 | 08:38 PM
If you end up splitting the lines up, I may want the rear center or the both of what's left, dependent on price...
Old Feb 28, 2014 | 11:01 PM
dpmalibu's Avatar
I guess I will split them since I have two people who want them, I wills end PM's to you both
Old Feb 28, 2014 | 11:48 PM
Car: 1991 Camaro RS
Engine: L98 350 TPI
Pm replied
Old Mar 1, 2014 | 08:09 PM
dpmalibu's Avatar
Got it. Sent you one back
Old Mar 3, 2014 | 03:41 PM
dpmalibu's Avatar
Earl's braided brake hoses are sold!!
Old Mar 7, 2014 | 11:26 PM
dpmalibu's Avatar
Re: 1988 Firebird Formula steering/suspension/ brake parts prices lowered
ttt
Old Mar 10, 2014 | 08:25 PM
jersyboyy's Avatar
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
sell the torque arm?
How muchfor steering box shipped to71105? whats the codes onit?
Old Mar 10, 2014 | 08:40 PM
dpmalibu's Avatar
The torque arm is sold I will check the information on the steering box tomorrow and get your shipping price
Old Mar 11, 2014 | 06:11 PM
dpmalibu's Avatar
Old Mar 11, 2014 | 06:12 PM
dpmalibu's Avatar
numbers on the front of the box is : 7800715
Old Mar 13, 2014 | 03:38 PM
dpmalibu's Avatar
Price lowered again
Old Mar 14, 2014 | 02:54 PM
dpmalibu's Avatar
LCA's are sold
Old Mar 21, 2014 | 09:31 AM
dpmalibu's Avatar
ttt
Old Mar 24, 2014 | 07:14 PM
dpmalibu's Avatar
Sway bar sold.
Only thing left are the e-brake cables
Old Mar 25, 2014 | 08:15 AM
RaysUpRacing's Avatar
Car: 84 Camaro Berlinetta
Engine: 350 bored and stroked
PM sent
Old Mar 26, 2014 | 07:12 PM
dpmalibu's Avatar
Everything is sold. Thanks to everybody who bought parts from me!!!
Thanks Thirdgen.org!!
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
theshackle
Mar 5, 2017 06:37 PM
1nastygta
Aug 8, 2015 07:38 PM
