T5 7 and 9 tooth speedometer gears
Old Apr 14, 2014 | 08:46 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
I now have the T5 speedometer drive gears in stock both 7 and 9 tooth.
Cost is $20 each plus shipping. Priority mail is $5.80.
Old Apr 14, 2014 | 11:57 PM
chiz420's Avatar
Car: 1991 RS
Engine: 383 stroker
Transmission: t56
Re: T5 7 and 9 tooth speedometer gears
Which one is needed for 3.42 gears. I would like to buy that one. Thnx
Old Apr 15, 2014 | 07:16 AM
alloy's Avatar
Car: 87 IROC-Z28
I need to know what your rear tire size is to calculate what gears you need.
Old Apr 15, 2014 | 07:49 AM
chiz420's Avatar
Car: 1991 RS
Engine: 383 stroker
Transmission: t56
Curently 16 but in the future up to 18.
Old Apr 15, 2014 | 08:21 AM
alloy's Avatar
Car: 87 IROC-Z28
I need to know your full tire size not just the rim diameter. Like 245/50/16?
Old Apr 15, 2014 | 09:53 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Old Apr 15, 2014 | 10:03 AM
chiz420's Avatar
Car: 1991 RS
Engine: 383 stroker
Transmission: t56
235/55/16 currently set up for 3:08 but changing to 3:42
Old Apr 15, 2014 | 10:11 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Can you come up with a set of drive and driven gears for a T5 with 3.27 rear gears and 275/40-17 tires?
Old Apr 15, 2014 | 10:13 AM
midias's Avatar
Old Apr 15, 2014 | 10:15 AM
alloy's Avatar
Car: 87 IROC-Z28
You need a 7 tooth drive and 18 tooth driven gears.
I will pm you with my PayPal and get your shipping info from you.
Old Apr 15, 2014 | 10:21 AM
Mongoose's Avatar
Car: 90 Formula
Forgot to mention these are needed for a VSS car,electronic speedo.
Old Apr 15, 2014 | 10:45 AM
alloy's Avatar
Car: 87 IROC-Z28
The drive gear will work, but the gears for the VSS have been discontinued.
Old May 24, 2014 | 05:01 PM
90camaro355rs's Avatar
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
I have a 90 Camaro rs that had a V6, when I bought it it had nothing, no wiring no computer, I installed a v8 with all msd components plus a 5 speed, it was originally an automatic, what all do I need to get my speedo to work, I believe it to have 342 rear gears. tires right now are 205 60 15, will be changing to 235 60 15. Thanks for any help you may give
Old Jun 3, 2014 | 12:20 AM
gregl316's Avatar
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
I have a 91 that I am putting a T5 in rite now. What gears do I need? I am running 275/40/18's with a 3.73 rear end. I also need to know if the VSS off the 700r4 will work or do I need a new one.
Old Jul 10, 2014 | 04:40 PM
twoofakind's Avatar
Want a title? Post!
Car: 1985 Z28 X2
Engine: 350 290HP crate
Transmission: T5 WC / 700R4
Axle/Gears: 4.10
Do you still have these in stock? I am pretty sure I need a 7/22 tooth combination for a 4.10 gear with 245/45/17 tires. Thanks.
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
roysatikas
Sep 7, 2015 08:08 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
