ZZ383 with TPIS Mini Ram
Car: 91 RS and Jaguar XJS
Engine: ZZ383 with Mini Ram
Transmission: Tremec 3550
Axle/Gears: 3.42 with Tru Trac
I just put a ZZ383 with TPIS Mini Ram, Hedman mid length headers, 32# injectors, full exhaust with Borla multi core muffler, high flow fuel pump, and Street and Performance Integrator (converts the TBI injection wiring to multi port) in my 1991 RS. It makes 389 rwhp and 403 rwtq. Some people say the Mini Ram doesn't make torque but I have almost 350 rwtq at only 2,000 rpm. Check out the attached dyno sheet.
dyno.pdf
dyno.pdf
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
Re: ZZ383 with TPIS Mini Ram
Nice combo you've got there! I wouldn't need nearly as much, but it's good to know that the MiniRam doesn't totally kill TQ...
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
I am running a 383 with a mini ram, with some shorty headers and there zz409 cam. I am making 408 rwtq and 396 rwhp.
It is cam that came in the ZZ383. Same heads too. All I did was bolt on my intake and headers. Using stock ignition with MSD coil. I used to have same setup on a ZZ4 with hot cam and fast burn heads that did 360 rwhp and 340 rwtq.
Car: 92 Z28
Engine: 383
Transmission: soon to be T56
Built my own 383 and used a Mini Ram. Seems to work good went 10.92@ 122mph in 1/4 mile. Best advice call Jim at TPIS these guys are great and will answer all your questions. Listen to those guys thew make you one fast car.
Wow look at how flat the torque curve is. You have a lot of torque through out the whole powerband. Makes me want to get a miniram.
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
I'm running a homemade all forged 383 Miniram with ported TF heads, ZZ409 cam, 58mm tb, Hooker 2210 longtubes and Mufflex 4" cat back making 413rwhp and 398rwtq.
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
I just wanted to bring this back for the Miniram crowd like myself.
I want this combo! zz383 and miniram!
can I also get a new ecm and harness from tpis???
Look at my sig with my Miniram. It make very good power. No loss of torque.
Attachment 195234
Attachment 195234
Would love some pictures and install infos etc if you got the time.
also have a look at my page for pictures and info on my ride http://camaroirocz.net/
Thanks again, and again awesome numbers in the dyno
Engine: 4++,350 & 305 CIs
Nice numbers!
I bought the Mini Ram from www.tpis.com. I'll take some pictures but it looks like an LT1 engine from a 4th Gen Camaro. It is an easy swap and can be done with the engine in the car. TPIS will give you all the parts needed.
Arthur
Arthur
Mini ram out of car
Mini ram in car.
Mini ram in car.
Why stop with a 408 :-)
I'd argue that most of our cars are in better mechanical condition than the average car that's on the road today but, that makes no difference with the smog laws.
Car: 1986 z28
Engine: 350 hsr
Transmission: probuilt 700r4/edge 2800
Axle/Gears: stock 4th gen 3.23
To the OP, have you experienced any oil consumption issues that some have claimed to had with the ZZ383? Looking at buying one but reading about those issues makes me second guess. Thanks
ambainb
04-25-2016 09:21 PM
gixxer92
09-01-2015 04:32 PM
Sanjay
08-12-2015 03:41 PM
L98GTA87
08-11-2015 06:55 PM
