aluminum drums
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
aluminum drums
if anyone else is looking for aluminum drums. I just bought a set from hawks @ $25 ea. now for the polishing!!!
Car: 86 IROC
Engine: 5.0 TPI
Re: aluminum drums
there is no link.you call them and ask if they have.......whatever you need for your car. they keep many many used parts that are not in their catalog or listed on their website.but they have them ,or should i say 2 less than they had monday morning.SCORE!!!
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: aluminum drums
by no way is this , my comment a slam . I have never understood the desire/need for aluminum drums . sure they are a little lighter , but enough to matter for performance ? (I don't think so) polish up nice ? O.K. , i'll give you that . used ones are not able to be turned (in most cases) more than once . finding NOS ones , impossible (at a reasonable price) . so why , are they sought after ? a few months ago I did my rear brakes . bought new drums , cleaned casting slag , took to machine shop to assure true . after very lite touch-up had them hot tanked . took back to my shop primed and painted with hi-temp cast alum. paint . I'm happy with appearance , good luck .
1 Post
Car: '84 Berlinetta T-Top
Engine: 305 V8 LG4
Axle/Gears: 3.08
Re: aluminum drums
They can be relined. This company has information on their site about it.
http://www.jgrelining.com/#!services/crfi
Car: 86 IROC
Engine: 5.0 TPI
Re: aluminum drums
Car: 86 IROC
Engine: 5.0 TPI
Re: aluminum drums
1 Post
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
I got mine for $20 for the pair at the pick and pull by me. For 20 bucks I wouldnt care if they were good or not. Turns out they were pretty much perfect. After installation I noticed that braking was better. Whether that was due to bad steel drums ill never know.
For $20, it was money well spent. As for the reason for aluminum drums; rotational weight is more than static weight. Not much of a difference I might add, but alum driveshaft and drums in concert should in theory be better, though you may never feel the difference.
Engine: 4++,350 & 305 CIs
Re: aluminum drums
I have 2 sets of them just sitting
Car: 1988 Camaro
Re: aluminum drums
So 9 lbs of rotating weight is a good bit in the end for a drag car. It adds up quick. Rotating weight has 2-5 times the effect on accel/ET/Performance than dead weight.
The old rule of thumb is 100 lbs of static (dead) weight = 1/10th second drop in 1/4 mile ET.
10 lbs of dead weight has the same effect on performance as 1 HP.
Re: aluminum drums
I'm not much on rear drums.
I have about the same money in em as the Hawks parts cost
PM me if you or anyone wants them.
